Question about Bunn A10 Coffee Maker
Water running slow brew - Bunn A10 Coffee Maker
Water coming thru coffee maker very slow
If the spray head is clean and clear and you have run the spring the the brew tube till you can push it almost all the way in (leaving only 1/4") then it should not have issues.
Dec 29, 2012 | Bunn NHB Coffee Maker
Tip
Cleaning a coffeemaker/tea brewer
Every month or so, run a complete brewing cycle using white vinegar in place of water. Follow with 2 complete cycles using plain water.
Water quality in many places is not so good. The heat of the brewing process causes the solids (calcium, lime, &tc) in the water (especially HARD water) causes scale to form on the inside of the tubing. This not only affects the taste of the coffee (or even tea), but slows the brewing time by preventing water flow due to decreased diameter of the tubing.
on Feb 07, 2010 | Coffee Makers & Espresso Machines
Gevalia 12 cup coffee maker slow brewing
The pipes are blocked with build up scale or water dirt. You can try to descale the machine by adding in the water half cup of lemon juice and brew it without coffee leave if for 20 min and the clean it by brew it with fresh water these will make a diference then try this again in a week.
May 16, 2012 | Gevalia CM-500 12 Cup Coffee Maker
My tim hortons coffee maker is not brewing as quickly..s there a wayto clean it
Make a 1/2 pot 50/50 mixture of cold water and white vinegar then run it through the machine in normal brewing fashion. Place a clean filter in the brewing cup to catch the white deposits that are removed. Allow the mixture to cool, then repeat the process several times while using the same filter. Finally, run several pots of fresh water through to work out the taste of the vinegar. Repeat whenever the brewing time seems to be excessive.
Feb 02, 2010 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
My hamilton beach brew stations quits after brewing 2 cups of coffee.... we have to turn it off and turn it back on several times to get the whole pot brewed. help.
You just need to run white vinegar through it. Put white vinegar in the same way you do water (but don't put any coffee grounds in the basket). Run it as many times as it takes to get all the vinegar out, and then run it again three or four times the same way. After it runs normally, run water through it until the vinegar smell is gone.
The cause of the slow brewing is that the water you normally use has some amount of hardness to it, and over time the hard water minerals build up on the heating element inside the machine. The buildup prevents the heating element from heating the water as fast as designed. The vinegar will dissolve the minerals and let the heater work at full capacity again.
If you want to avoid this in the future, just run the white vinegar through it once a month or so even if it's not running slow.
Jan 31, 2010 | Hamilton Beach BrewStation 47224 Coffee...
Coffee maker is not pumping water fast enough. takes over a minute to brew a 8 oz. cup. pumps water real slow.
have you tried cleaning it? Minerals from the water build up inside the tubing and make it run slow. Take a pot full of white vinegar and run it through a brew cycle. follow this by a couple of pots of cold water and you should be good to go.
Nov 04, 2009 | Keurig B60 Coffee Maker
My GE coffee maker is very slow making a pot of coffee I need to clean it. Its digital
run some vinegar thru it a couple of brews and see if this speeds up the water, you will want to run a third brew of plain tap water to rinse vinegar taste out
Oct 02, 2009 | Coffee Makers & Espresso Machines
Francis francis X1 the water supply seems to be lacking pressure
I would go ahead and run a solution of 50% distilled white vinegar and 50% water through the machine. If the machine still runs slow after that, pour another 50/50 vinegar/water solution into there - let it run just enough so that the vinegar water starts to drip out, then cut the machine off. Let the vinegar/water sit in the machine for about 20 minutes. Then cut the machine on and let the rest of the solution run through. Then run plain water through the machine to clear out the vinegar. Try brewing a batch and see if the machine behaves normally.
If the above fails to resolve the issue, the FrancisFrancis machines are now owned by illy, so would need to contact them for further TS.
-Tha Mp3 Doctor
Mar 08, 2009 | FrancisFrancis! X1 Espresso Machine
Machine kaput
Try turning on the frothing wand ... the water light should reset once the water has come through.
Mar 14, 2008 | Gaggia Super Automatic Espresso Machine...
Brew time
If you have hard water, minerals may have built up in the unit, slowing down the flow. You should be able to find some sort of mineral-dissolving treatment for it at your local grocery or hardware store. Make sure to run a few pots of plain water when you are done, to get any residue out!
Feb 21, 2007 | Mr. Coffee FTXSS23GTF Coffee Maker
Bunn A10 Coffee Maker Logo
19 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
Jim Y
Jim Y
pawnpower
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
