Power up problem
I own a Hisense tv model number TL 1700 the problem is when i shut the TV off and then try to turn it on later in the day it will not go on. The power red / blue indicators on the TV are not lit. The power supply light is not lit either. I must unplug the TV and then replug and it will work fine until i shut it off. If i shut it off i must repeat the upluging process. Is this a bad power supply?
  • 20 Answers
The problem is in the relay built into the power supply. It is magneticly sticking into the off position. Unplugging it kills the field and let's it set back to a neutral position. I doubt the relay is serviceable by itself.
Probably need a new power supply.
Posted on May 08, 2009
Why does my Hisense tv randomly shut off
For a TV set to shut off randomly, it generally means that you have to ask for a technician to check its Power Supply Board.
If you have some knowledge about electronic, just open the TV and check for the PartNumber of the Power Supply of that specific model, and do a proper search on Gloogle_Search_Engine related to the same issue: BOARD NUMBER + ISSUE (stop working, works for a few minutes only... etc.) + SOLUTION.
This will offer a better understanding about the problem, so you may be OK to solved it alone.
Information is for all us to share, and you will surely find some about it. Good luck.
Mar 20, 2016 | Hisense Televison & Video
Power went off and now red light is flashing on tv and cant turn it back on. cant remember how to reset tv after power outage
Tries tv unplug,replug it back like an hour later.That way to reset the tv back to the factory setting.The tv should work now,if not than the tv power supply board is problems and the causes.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Nov 28, 2010 | Hisense LCD1504 15 in. Television
Programming remote to hisense tv model # LCD1504US
Cable remotes and TV remotes often are incompatible.
Sep 27, 2017 | Hisense LCD1504 15 in. Television
Hisense tl2020 will not power on
power supply issue..may be some bad capacitors simply replace them....dada....your prob solved
happy to help
Aug 18, 2017 | Hisense TL1700 17 in. LCD Television
INPUT GOING CRAZY
It could well be the accumulation of dirt/dust behind the buttons causing them to stick. If you are able to carefully remove the board that the buttons are located on and use a cleaner that will de-grease at the same time. Be sure that everything is dry as can be before re-assembling and then check if the problem persists. If you are not capable of doing this trust a competant technician. Hope this helps.
Aug 04, 2008 | Hisense TL-3220 Television
HiSence Flat Panel TV, Model TL 2020
Hey Billy Lee,
If you're unsure how to unlock your TV, you may wish to check out Hisense's online documentation for the TL-2020 through the following link:
http://www.hisense.com/en/Support/download_manual.jsp
Instructions on how to disable any feature locks should be included in downloadable files on "page 9" and "page 10" of Hisense's support forums.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jul 22, 2008 | Hisense TL-3220 Television
Hisense TL2020 TV repairing
To unlock your Tl2020 with a universal remote just go into the menu and select V chip setting. The password from the factory is four zeros (0 0 0 0 ). Once you get in you will the letter "B" nect to everything. Set everything to the letter "U". Then, turn off the television. The set should be unlocked now. Good luck !
Frank
Sep 15, 2007 | Hisense TL1700 17 in. LCD Television
Televison & Video Logo
240 people viewed this question
Top Televison & Video Experts
Electro Med Services...
