Question about Protron PLTV-32 Television
Component 1 displays a split screen with a green band in the middle.
When using Component 1, the protron display is relatively scrambled with a green line in the middle separating the pictures into two exact images. By the way, there is no problem using component 2 but I don't have the same adjustment options as component 1.
  • 3 Answers
In my manual it says that if you have problems with Component1 to use Component2.  I had the same problem running progressive scan devices, i.e. a dvd player, playstation2 etc.  I bought an amplified component switch from RadioShack for 29.99 and it now allows me to have 4 progressive scan devices plugged into Component2.  I no longer have anything plugged into Component1.
Posted on Oct 12, 2007
SOURCE:
How do I get rid of the following from screen... Main: Component 2 Sub: TV Note the main, component 1 failed years ago...
If you want to get rid of the display, you should have a DISPLAY button on the remote, just press that.
Feb 25, 2011 | Protron PLTV-32 Television
Laptop screen scrambled and now won't turn on
maybe overheating graphics card, check the fan is actually turning on, usually you can hear it whirring around.
Mar 21, 2010 | HP LCD Display for Compaq Presario R4000
I have a 2inch wide band down middle of screen on
1) Have you installed new drivers or software or drivers? If so, remove them and restart the computer.
2) Try applying pressure with your fingers on top of the screen. If the band dissapears or dimishes, you may have a broken screen and it will need to be replaced.
Mar 19, 2010 | HP Pavilion zd8000 Notebook
Onkyo TX-SR706 Setup Display Problem
For adjustments to receiver you can always run a component or composite cable to your plasma tv. After adjustments are made just return to HDMI input.
Feb 24, 2010 | Audio Players & Recorders
No picture on tv when i turn on dvd. get split screen black & whi
Give this a try. Using your user's manual, locate the "Configuring your recorder" section. Under this section there will be "System setup - general" subsection. Being that you are unable to see anything on your tv display you will need to use your manual as your display. Press the "SETUP" key on your remote. Once again using your manual as your display, scroll down to "Restore factory settings" and press "ENTER" As long as you are located in North or Central America and using interlaced video outputs you should have your normal display back.
Hope this helps.
Nov 24, 2008 | Protron PD-DVR100 DVD Recorder
Scrambled screen
well it is a hardware problem, you might change your lcd, or the flex or the display ic
Apr 21, 2008 | Motorola Mobility RAZR V3c Cellular Phone
Sony DVP NS71 Component Video split frame
You've inadvertently turned on the progressive scan. Look up in the manual, or ask customer service online, how to turn off progressive scan.
Jan 27, 2008 | Sony DVP-NS71HP DVD Player
Weird problem not convergence
Mine is doing the exact same thing! have you found a fix yet?
Apr 23, 2007 | JVC AV-48WP74 48" Rear Projection...
Protron PLTV-32 Television Logo
102 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
