Question about Dishwashers
Dishwasher does not drain properly after rinsing
Kenmore dishwasher model # 587-15193401.
The machine does not drain completely after rinse cycle. I removed the spinner apparatus and checked for something blocking the drain hole at bottom of tub and could not find anything
    President:
  • 1,136 Answers
Hi, Check the drain hose to see if there is a parcial blockage. If not, check the drain check valve where the drain hoseconnects to the pump.
Hope this helps
Posted on May 08, 2009
I have a new stainless steel Samsung dishwasher. It doesn't seem to be drying properly. Dishes and dishwasher still very wet after cycle is completed.
Hello
Your dishwasher has been designed to use a liquid rinse aid. Pouring a liquid rinse aid into the proper recepticle in your dishwasher when you add dish detergent greatly improves drying performance. You can further improve drying performance by selecting the Sanitize option, in addition to the other options you've selected, and increasing the water temperature.For Best Results, use Jet-Dry Turbo
Spots and film form in your dishwasher's rinse cycle, when detergents are already down the drain. FINISH® JET-DRY® Rinse Agent works in the rinse cycle, lowering the surface tension of water and causing it to sheet. Better rinsing results in less spots and film.
If these recommendations do not improve drying time, please contact Samsung Customer Care
Sep 07, 2011 | Samsung 24 in. DB5710DT Stainless Steel...
Water is not competed drained out after all wash rinse and dry cycles are complete. No signs of any leakage on floor or under machine.
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Waterwill not drain out
heatman101
Mar 20, 2011 | Kenmore PRO 24 in BuiltIn Dishwasher with...
Kenmore Model 22722 will not drain
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 01, 2010 | Washing Machines
Won't complete cycle, stops at rinse. and can't get hot water.
Are you on well water? turn off the cold water to the washer and clean the screen filter out. do not leave filter out.
the machine probably has a cold only final rinse so it won't work properly.
Mar 22, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore Ultrawash QuietGuard 3 Dishwasher not draining or rinsing
Hi Claire,
Are you using rinse aid?
that may help with the film.you may also have stuff down in the trap causing the water to drain slow.
Nov 05, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore dishwasher various problems
The portable dishwashers of the 70's and 80's often had one area of problem, and that was the pump getting jammed with debris and food.
To eleminate this problem, you will need to open up your dishwasher carefully, and drain all the water and gunk from your dishwashers rinse hose. I recommend taking the machine outside and use a low setting pressure hose (garden hose). With the hose off the rinse side, run the water through and see if it comes out of the pump's housing. Let it run for a few minutes.
The pump also has a switch that also goes with the run cycle. This switch thinks there is not enough water or it thinks it has done its job.
Sometimes replacing the timer helps, but first eliminate the lower hose situation first. If that doesn't help, you will need to then replace timer. If this doesn't help, most likely your pump is most likely jammed or malfunctioning.
May 24, 2008 | Dishwashers
GE Nautilus won't drain after Rinse Cycle
Check disposer plug. If a garbage disposer has been recently installed, it is possible the disposer drain plug was not removed. The drain plug is a plastic piece in the disposer that blocks the hole where the dishwasher hose connects. Also check the hose connected to the disposal. Mine apparently had a kink in it. When I straightened the hose the dishwasher drained at full speed (I recently had a plumber re-route a hot waterline. He must has bent the hose). Hope this helps. If not go to the GE website. That's where I found my answer.
Nov 03, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
Dishwasher
Check to see if you have any switches on your dishwasher that could by pass a rinse cycle. Use a hotter temparture when washing, Check your water level,check your filters on your inlet hose top and bottom. When it gets to a rinse cycle you should hear it drain out and bring in fresh water. you could change to a liquid detergent. Dont over load your dishwasher. make sure you are using rinse aid and try adjusting it up one setting. Shiney glasses means your rinse add is working. NZL
Jan 04, 2007 | Kenmore 18 in. 14432 / 14439 Built-in...
Dishwashers Logo
374 people viewed this question
Top Dishwashers Experts
