Question about Gigabyte GA-H61M-S2PV Socket 1155/ Intel H61/ DDR3/ A&GbE/ MATX
GA-H61M-S2PV blue screen - Gigabyte GA-H61M-S2PV Socket 1155/ Intel H61/ DDR3/ A&GbE/ MATX
No bootable device is detected system will enter the bios setup utility
Look to see if a floppy disk is in the drive. If not , then the hard drive cable or the power connector on the hard drive isn't making a good connection
Jul 16, 2014 | Gigabyte Ga-H61m-S2pv Rev. 2.0 -...
Gigabyte h81m-s2pv driver
http://www.gigabyte.de/products/product-page.aspx?pid=4664#dl
May 20, 2014 | Gigabyte GA-H81M-S2PV Desktop Motherboard...
Showing nothing but black screen when start up no bios screen no windows screen not even brand image when start up gigabit GA H61M DS2
Are there no beeps you hear when starting? Some error code or so?
try to reset it by pulling the battery on the motherboard, leave it out for 30 seconds and put it back in, sometimes there is also a reset pin you have to place the jumper on for a few seconds, but i don't see that in the pictures for the motherboard you have.
If that doesn't work, try a different videocard.
If that doesn't work, check the memory, if you have multiple sticks, try with only one.
If that doesn't work, maybe try a different powersupply
If that still doesn't work, perhaps CPU module and otherwise you might be SOL
Apr 19, 2014 | Computers & Internet
Ga-h61m-s2v-b3 not coming on using power switch
I agree with Mike, but would like to add a couple of things. I had the same problem with a Gigabyte board (new install) and found that I had to change the CMOS battery. I put in a new batter, and "voila" it worked fine after that. Also, not knowing your level of experience, make sure the front panel connections are on correctly. Generally speaking, if you look at the lettering on the plastic ends that plug into the board pins on the front panel connector, the lettering should face the edge of the board and not be facing the middle of the board. That too has caused a similar sounding problem in the past. Other than these two potential solutions, more information is definitely needed.
Mar 20, 2014 | Gigabyte Motherboard Ga-H61M-s2P-B3 Core...
Processor cold
Did you mean the CPU was not operational? The motherboard failed to Boot? The power supply did not function? No post beep when you turned on the computer? Be more specific about your problem?
Jan 13, 2014 | Gigabyte Motherboard GA-H61M-S2P-B3 Core...
I cannot access my Bios setup when pressing the Delete on start up
Try pressing the esc key if that doesn't work use the f12 key
Nov 11, 2012 | Intel Motherboard
I have upgraded to Windows 7 and also a new Gigabyte GA-H61M-D2-B3 Motherboard. 4GB DDR Ram I have plugged my Cambridge Soundworks SW320 in but I only get some sound, eg all music and back ground sound is...
Gigabyte GA-H61M-D2-B3 Motherboard supports 2/4/5.1/7.1-channel HD audio, whereas Cambridge Soundworks SW320 is 2.1 (only). Hence, the PC should be configured to provide 2.1 Channel output. The audio of your system may be configured to 2.1. So, please check the Realtec Audio sound manager/ configuration from the control panel or from tray (near clock) and set it to 2.1 (2 Channel Stereo Output).
Moreover, audio on your PC may be running on default HD Audio Drivers. So, you may also download/ install the latest drivers for Gigabyte GA-H61M-D2-B3 Motherboard.
(Refer to download section at the bottom of the page). After installing audio drivers, you would be able to configure the audio.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Sep 13, 2011 | Creative Labs SoundWorks SW320 Computer...
Open Questions:
Gigabyte GA-H61M-S2PV Socket 1155/ Intel H61/ DDR3/ A&GbE/ MATX Logo
52 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Gbenga
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
