Question about Ovens
Balay hob unlock? - Ovens
Where do i find the unlock lever on a frigitare stove
Spell 'Frigidaire' correctly and Google
Frigidaire make model manual
It is usually a combination of two buttons pressed or one button pressed and held for 5 seconds to unlock the hob.
If it is the oven that is locked after a clean cycle. Unplug or flip the breaker from 20 seconds. It is an electronic lock.
Jan 20, 2018 | Ovens
What products can I use to clean my aeg hg795540xb gas glass top hob? The instructions say neutral products and no hob scrapers
Please, follow this link:
http://www.amazon.co.uk/AEG-Electrolux-50296742005-Ceramic-Cleaning/dp/B002LJDJ7Y
25358477-ou0pu244fjwiiyewsm5u145c-2-0.jpg 6. CARE AND CLEANING WARNING!
Refer to Safety chapters.
6.1 General information
• Clean the hob after each use.
• Always use cookware with clean bottom.
• Scratches or dark stains on the surface have no effect on how the hob operates.
• Use a special cleaner applicable for the surface of the hob.
Dado
Jan 06, 2015 | AEG Ovens
Gas hob will not light on my leisure gas hob
At the rear of the oven is a gas cut off valve. Try twiddling it
Nov 24, 2013 | Ovens
The childlock key sign is on when i try to use my Tecnik TKH4050/3 hob. How do i unlock it
Most control panels have a button that can be held down to lock and unlock the controls. Do you see one that has this function.
Mar 23, 2011 | Tecnik Ovens
Hi, 3 of the 4 oven hobs have failed to work on the 720ef. only 1 of them heats up now. when you turn the knob of the failed hobs only 1 out of the 3 makes the click noise but still doesnt heat up,...
Normally the 720ef is the oven, the hob is a separate unit and in my case is a STOVES 600G gas unit. Your unit may have a built on hob but the handbook for the 720ef does not detail this. In my case the hob ID is on the lower right hand side of the unit.
I think you will find that the elements may have failed but you will need to identify the hob to ensure correct replacements. Normally the element rating is on the base of the element. The handbook will tell you how to take the thing to pieces. It is possible that the hob element controls have failed but unlikely for all three or it may be a combination of both parts. I think you may have to contact an electrician to test everything to sort this out.
Mar 08, 2011 | Stoves 720EF Electric Double Oven
I have bought a Balay Electric Oven 3HB 516XP and the user manual is in Spanish how can I get an English one.
http://portal.bsh-partner.com/portal%28bD1lbiZjPTA2MA==%29/PORTALFRAME.HTM
Pick the one that says EN to download
I’m happy to help further over the phone at https://www.6ya.com/expert/adrian_14bdf3baf2fd61b6
Mar 03, 2011 | Ovens
PRODUCT DETAILS For MSP60SS
Matsui MSP60 Stainless steel Built-In Oven and Gas Hob Package. Matsui MSP60 with Hob: 4 Burner Gas Hob, Fan oven, Minute Minderand B Energy rated top oven. Matsui MSP60 Stainless steel Built-In Oven and Gas Hob.
Product Features
•Dimensions (cm): (H)59.0 x (W)59.5 x (D)57.0
•Ovens: Fan oven
•Timer: Minute Minder
•Hob: 4 Burner Gas Hob
•Colour: Stainless steel
•Energy rated top oven: B
Hope this helps. Your generous rating will be much appreciated.
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Oct 20, 2010 | Ovens
Is this oven suitable to have a Induction Hob
Provided there is a space between the top of the oven and the hob, it should present no problem.
You will of course need a seperate plug outlet for hob
May 21, 2010 | Neff B1421 Electric Single Oven
Candy sprinter hobb all on L locked?
Ours started doing the same Displaying L on four hob displays. I figured to press the bottom right hob and the minus button at the same time should unlock it.
Thanks
Trev
Oct 07, 2009 | Candy Ovens
Ovens Logo
13 people viewed this question
Top Ovens Experts
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
