Question about Motorola Canopy 5.2 GHz Wireless Access Point - AES Encryption (5201AP)
CANOPY CONFIGURATION AS ACCES POINT - Motorola Canopy 5.2 GHz Wireless Access Point - AES Encryption (5201AP)
Cannot access my linksys admin consol
try to shut down the acces point to access the admin point
the ssid its the ssame as the one from the acces point so the nearest is going to conenct
Apr 27, 2010 | Linksys Wireless-G WAP54G 802.11g/b...
I have the mc 70 how do i get started if i wanted to send my orders using wifi
i thank that you have to configure you acces point first, and configure also your unit to communicate with your acces point in setting( ip adress,subnet mask,ssid,keys...) and and connect your acces point to your system( switch,modem ,,,)
Feb 03, 2010 | Symbol MC70
Im using Motorolla canopy 5.4 and 5.7, both ,they are confiruged whith ip addresss in the range of class A, my problem is that in lot of them i cannot access thru web page, what should be wrong on this...
I would advise you to be sure that your routers are MDI/MDIX Compatible, (i.e it can allow you to use either a straight-through or cross-over cable).
If not, then try using a cross-over cable when connecting the routers together.
Also, try making your router's LAN configuration to be DHCP and the one for your Wireless Access Point Static.
Then make sure that they are all in the same Subnet. This is also very important.
Try out these few troubleshooting steps first and keep me posted about the problem.
Hope it helps.
Goodluck
Nov 14, 2009 | Motorola Canopy 5.2 GHz Wireless Access...
I have conected 4links by motorolla canopy in a
try to check firewall settings whether it is enabled or not
Aug 28, 2009 | Motorola Canopy 5.7 GHz Wireless Access...
I want to see my canopy speed beacause my signal is very low
I would visit the speed test site www.bandwidthplace.com and select speed test and then select server nearest you. Hope this helps
May 10, 2009 | Motorola Canopy 5.2 GHz Wireless Access...
Motorola canopy
Just go to the configuration tab then QoS (quality of service) and set your sustained up and download links at 20,000 each. that will open you up to all thats available.
Sep 24, 2008 | Motorola Canopy 5.2 GHz Wireless Access...
Dismantleing canopy
If this is for the Graco Snugride (I have the Windsor model from the Quattro Travel System), this will work:
1. Push the Graco canopy to one side, exposing the plastic support bars that hold the canopy in place.
2. The center of the support is where the canopy comes apart. Using both hands, pull the canopy support
bar apart (as if you were playing tug-of-war). It's best to grab the curved ends and pull HARD (and point it away to the side so that you don't hit your face).
3. Once the support bars are apart, remove the old Graco canopy and slip on the new/freshly washed canopy.
4. Secure the support bars by snapping them shut, and then slide the canopy into place.
Aug 26, 2008 | Graco SnugRide - Clover
Factory Default Motorolla Canopy 900mhz. AP
all you need is a phone cord (that you dont want to use anymore) just ground the number 4 and 6 wire together and leave the rest alone. plug it in the canopy and then power it on. It should then be at the default ip. I think its 169.254.1.1 or 192.168.100.1.
Jun 16, 2008 | Motorola Canopy 5.2 GHz Wireless Access...
Wa 612 Wireless Navigator utility
plz le mee know in detail , r u noot able to go into the interface of yor wless accesspoint,,,, or ya r not able to connect to the acces poing from yor wireless computer. if you ar using an wless acces point then yor computer should also have a wirelless adapter/interface/card in most recent laptops its coming inbuilt. lets assusme that ya have the wlees adapter/card/ interface on your computer but you are not able to connect wireleesly to yor access point--- thenya need to check wireless zero configuration (WZC)service of windows xp.(assuming that you r using xp or above)--steps to enabe WZC are -- START , RUN -TYPE "services.msc" without quotes, check the service from the bottom to top , ya will find wireless zero configuration , double click it n check startup type should be- automatic- and service staus should be-- running. click apply n ok , n if there are some wireless singals approaching to your this computer ,it will show ya a message like signal detected from your accesspoint. n ya ll be able to connect wirelessly ,,,,,,,, +++++ note : if this doesnt work the do le mee know the details of the complete setup n default ips on acces point n your comps ip , wired one or chat with with me online , i m online t ill 11- pm indian time thru samrat101@yahoo or same id on msn mesngr also. take care .. samrat
Mar 09, 2007 | LanReady (WA612-I)
Motorola Canopy 5.2 GHz Wireless Access Point - AES Encryption (5201AP) Logo
Top Motorola Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Motorola Computer and Internet Expert? Answer questions, earn points and help others
