Question about Grilling
Charmglow heater Charmglow CGL200TB LP gas heater - Pilot lights and stays lighted when sensor heats up, however, as soon as thermostat trips on, gas cuts off. What's wrong?
  • 10865 Answers
SOURCE: charmflow patio heater will not fire
turn the knob on very slowly just enough to fire up the heater. once it is fired up slowly adjust it.
Posted on Jun 24, 2009
  • 432 Answers
SOURCE: My living room gas heater will not stayb lit
Try replacing the thermo coupler.There should be a little bulb shaped part(like a pencil eraser) that the pilot light heats up .The other end screw into the gas valve.If this is going bad or has gone bad the pilot light will not stay lit.Most of these are under$10.Well good luck and try to stay warm.
Posted on Feb 02, 2010
SOURCE: My Charmglow patio heater's pilot light will light
Charmglo (heater) pilot goes out in 1-2 minutes. Then won't even relight. What a **** product!!!!!!!!!!!!!!!!!!!! Never again. If it says Charmglo anywhere, I am walking away. I have had this problem for two years. Usually, I have to COMPLETLY dissamble the unit, use a high pressure air hose and start all over again. Fix usually good for 1-2 months. Terrible product!!!!!!!!!!!!!!!!!!!!!!
Posted on May 01, 2010
  • 494 Answers
SOURCE: charmglow propane patio heater class iiia2
Ok, let's get the easy to check things out of the way first.
1) Is the tank empty? Take it out and weigh it on a bathroom scale. Most empty tanks weigh approx 18 lbs. The TW (tare weight) of your cylinder is stamped on the collar. If it weighs within a few lbs of your tare weight, then you simply need to refill it. Propane weighs 4.25 lbs/gal, so it would weigh approx 22 lbs with 1 gal of gas left.
2) Did you turn the tank valve on too fast? Close the tank valve, disconnect it and reconnect it. Then very slowly turn the tank valve back on. Try lighting the pilot and see if that helped. If not, try #3.
3) Your pilot orifice is dirty or has a spider web. Grab a can of compressed air (like you use to clean computer keyboards) and blow out the dust or web from the pilot assembly, which is where you light the pilot flame. Try lighting it and see if that solves it.
One of these 3 tricks should fix it. Douglas
Posted on Jun 10, 2010
  • 3 Answers
SOURCE: Charmglow 810-7400-S Propane Grill: have a charmglow patio heater, the pilot comes on ...
I have a Charmglow Patio Heater Model SRPH02, it needed a Thermocouple and searching the net was hard to find an ariginal part, but here it is, call 1-866-814-0585 $3.95 +6.00 shipping the original part.
Posted on Jun 17, 2011
Charmglow ventless lp gas fireplace model CGL300TQ pilot light wont stay lit, how do i know if its thermocouple or regulator?
if the therocouple has packed up pilot light will not light thermocouple has long small diameter pipe leading to a larger end this needs to be above the pilot flame also for safety have a small bowl of soapy water with a brush wet the nut with soapy water in no bubbles appear then try lighting heater thermocouples don't last that long
Jan 26, 2013 | Rheem 36" Water Heater Thermocouple Kit
I have a Charmglow ventless gas heater after it reaches temp, the pilot light goes out.
I have had a Charmglow for about five years and was doing the same thing. I called a plumber that worked with gas fireplaces and he came out, clean the pilot light and now it works great. Cost was $99.00
Jan 09, 2011 | Heating & Cooling
May 16, 2010 | Brinkmann Charmglow 810-7400-S Propane...
Feb 02, 2010 | Grilling
The yhernocoupler would snuff the pilot if bad. What ignites the overhead burners? and what regulates the overhead gas supply? Look into this. Too much gas will not light as easily as proper balance gas and air. Even more so in a tower type heater.. Turn the gas on low and the pilot should grab it. Good luck
Jun 05, 2009 | Coleman (5040B750) Patio Heater
Looks like the knob or the contacts are faulty.
Nov 07, 2008 | Williams 2509612 Ceramic Mid-Size Heater
Well, I just went out this morning and worked on the heater after it would not light last night. Turns out that a spider or moth set up camp in the pilot light intake housing and plugged up the two small mixer holes that pull in air for the pilot light. This would explain the 'yellow-flame'. I took a punch awl and some compressed air and cleaned out the hole, then re-installed the cover and knob. Lastly, I turned and depressed the knob and the pilot light ignited almost instantly, stayed on when I let the knob up, and the heater turned on normally after that. Good luck, I hope this helps.
Oct 20, 2008 | Williams 2509612 Ceramic Mid-Size Heater
Charmglow gas patio heater
My charmglow heater is a yeAr old and the pilot will ignite and stay lit for ever,but when you let up on it it goes out! What cam I do?
Mar 16, 2008 | Coleman (5040B750) Patio Heater
Grilling Logo
103 people viewed this question
Top Grilling Experts
paulcarew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
