Question about Radio Communications
I HAVE JUST FITTED A SECOND HAND MIDLAND 77-095 CB WHEN YOU TURN THE SQUELSH ROUND TO MAX IT ISNT MAKING A NOISE LIKE OTHER MIDLAND CB I HAVE USED??/ IS IT AN AREIAL PROBLEM???
Shuttle83
  • 1139 Answers
SOURCE: midland 75-785
Given the fact that when you key up the mic you should not hear any thing because the receiver section is "turned off" (no antenna and the speaker is muted). This would seem to indicate that the switch the headset controls which allow the change over from RX to Tx is bad or that the circuit in the CB unit which the head set plugs into is having a problem. Do you hear the same flutter without the headset? Try to get another headset or test one out just to see if the problem is eliminated by using a known good headset.
Posted on Sep 04, 2007
wyoed1
  • 211 Answers
SOURCE: midland cb model 13-895
Hi Frank, It sounds to me like you may have a bad dectector diode. Other possibilities are cold solder joints in the stand up boards in the IF section. Good Luck
Ed
NC Electronic
Mills, Wyoming
Posted on Jan 08, 2008
  • 13 Answers
SOURCE: midland cb radio
NO. I SORRY. YOU COULD GET IT FROM THE MANUFACTUREE. THANK YOU
Posted on Sep 16, 2008
One Wire
  • 126 Answers
SOURCE: converting a different brand of mic for a midland CB
This should be a typical Midland pinout. If you are using a generic 4 pin mic that is wired to cobra/Uniden, all you have to do is switch pin 1 & 2, then 3 & 4.
Not all mics are color coded the same with their wires.
Posted on Oct 06, 2008
Ironfist109
  • 3018 Answers
SOURCE: midland 75-822 CB
Hope this helps.
Posted on Nov 03, 2011
Midland 77-118 cb/ weather radio
sounds like the cb section is way off frequency. Check it out first.
Feb 11, 2014 | Midland Radio Communications
I have a Midland 75-785 hand held, It was working fine then I went to use it and the squelch control is not working ( I get lots of static) radio still works. Sends and receives, but when I turn the...
what time of day are we talking here? usually skip is so heavy from 0800 until 1600 that no radio has a chance of transmitting or receiving.If you turn the squelch the other way what does it do?
Jun 22, 2011 | Midland 75-785 Handheld CB Radio
I have alot of squelch on my cb until i connect ground then nothing.
this is not common it only means you have a good ariel and ground.the preset for the squelsh inside the rig needs turning up if you really need to turn the squelsh off.
Jan 18, 2011 | Midland 1001Z 40-Channels Base CB Radio
Midland cb radio. when i turn on my wipers i get a noise over the cb radio
This is usually caused from a poor ground. Try to reground the radio to a better location and it should fix it.
Jan 06, 2011 | Midland 1001Z 40-Channels Base CB Radio
I cant be heard when i speak through my midland 1001z cb radio?
hello have you checked the swr on the antenna have you checked the output of the radio with a power metre it should be reading 4watts max if yes problem might be the microphone make sure there are no wires shortening in the mic socket entering the radio and check inside the mic aswell
cheers and goodluck
Jun 26, 2010 | Midland 1001Z 40-Channels Base CB Radio
New hand held Midland CB Model #75-785 that will not transmit
Try asking any onrt CB'ers if they can hear you at all.
Could be 2 things -
#1 - you are really too close.
#2 - you've blown the output stage of your rig by keying the mic without an aerial fitted.
- This is very common, and most repair centres are used to dealing with this.
If you are up to electronic repair, it's possible to DIY repair.
Could also be an antenna mismatch or fault.
Mar 01, 2010 | Midland 75-785 Handheld CB Radio
GETTING INTERFERANCE FROM TRUCK,SQUELCH IS TURNED 3/4 ROUND TO STOP NOISE .HAVE TRIED CHANGING BOX,ARIEL,CABLE AND MOUNT,ALSO TRIED TAKING POWER STRAIGHT FROM BATTERIES, NOT SURE WHAT ELSE TO TRY?
Try this. While with the engine running and radio on, while you hear the noise, disconnect the antenna wire from the radio. (DO NOT KEY IT).
If the noise is gone, then the noise is coming in from the antenna. A new location may be needed.
If the noise is still there then its coming in from the power line. You need to get a ground loop isolator. Make sure its not one for RCA cables. You need one for the power line. It connects to your power source, and then your radio connects to it. this will take most of the noise out.
Oct 23, 2009 | Midland 1001Z 40-Channels Base CB Radio
Roger bleep kit
throw that annoying noise maker away
Jul 07, 2008 | Midland 1001Z 40-Channels Base CB Radio
Radio Communications Logo
268 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
