Question about FINN KNIVES Marttiini Condor Timberjack Fixed 3-3/4" Carbon Steel Blade, Rubberized Zytel Handle
WINCH WILL NOT RELEASE
PUT A TIMBERJACK T40 WINCH ON A 518 CAT SKIDDER GOT 600LBS TO WINCH CONTROL STILL WILL NOT RELEASE
    Genius:
  • 1,198 Answers
If reversing the lines doesn't help, see if the winch wants a bleed line, back to tank.
Posted on Nov 28, 2013
How to change o ring in control valve in a timberjack skidder
Doesn't say where the O ring is located, if it is between the valve bodies then separate the valve bodies and install new O rings, If it is on the valve spool then remove the spool out of the housing and use a seal pick to change the O ring
Aug 21, 2016 | Cars & Trucks
John Deere 2012 648g3 skidder winch will let out, when you try to winch in it will roll slack out of cable, but winch won't lock up and pull hard. How can I fix it?
if your saying that winch will take in and let out ok but wont hold a load in tension , then your winch directional valve or the winch motor is worn out and is allowing oil to pass right thru it regardless of it not being activated as skidder winches don't have a brake like electric winches do it uses the power of the oil locked into motor to hold a load ( that's also why id never stand under a load suspended by one !!!)
Nov 15, 2015 | John Deere Garden
I need to know serial number of engine in TIMBERJACK SKIDDER 240A with machine serial number 240ASEAX 847182 7300
contact the manufacturer on line and quote the machine serial number and ask for an engine serial number that engine.
Jan 13, 2015 | Cars & Trucks
What is serial # of DUETZ engine THAT is in 240A timberjack skidder
Not sure if you mean engine size or not . Each engine has it's own serial number. Anyway the Duetz engines were 130 HP 6 Cylinders. Now Duetz had 912 and 913 engines the 913 was the model with a turbo and they produced these engines in 3,4,5,and 6 cylinders. Most of what I've seen is the 6 - 130 HP. This particular unit was built in the mid 80's or so. Other Timberjacks different models/years, etc, also had 4 cylinder cummings, then some John Deere also. If my memory serves me correct it seems like I ran up on an old Timberjack in the woods hunting one day and it had a Detroit 353 in it. Great little engines.
Jan 01, 2015 | Cars & Trucks
Hercules winch on timberjack 230 won't pull or hold a heavy load
check for failed sheer pin in the drive shaft attached to the winch brake.
Mar 02, 2014 | Cars & Trucks
1998 timberjack 360 skidder shifts into 1,2,5,6 but not 3 and 4 how can it be fixed
my timberjack 360 wont shift into 3and4 but will shift into 1256. any people know whats wrong
Jul 09, 2013 | Cars & Trucks
518 cat skidder gearmatic winch keeps turning when put in free wheel 1985
pull the secondary clutch apart on the winch and clean with emory cloth or sand paper and u should see a change in this problem
Sep 08, 2009 | Heavy Duty Associated Equipment 6002B...
FINN KNIVES Marttiini Condor Timberjack Fixed 3-3/4" Carbon Steel Blade, Rubberized Zytel Handle Logo
665 people viewed this question
Top FINN KNIVES Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a FINN KNIVES Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
