Question about Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0 Tecumseh Engine
The gas line is leaking and I need a new one, where can I purchase an OEM part?
  • 246 Answers
Hello:
Most Small Engine Service Centers Carry the Fuel Line as Do All the Automotive Parts Retailers in your Area.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
John
Posted on May 10, 2009
The rubber gasket on bottom of gas tank where fuel line exits is torn and leaking. The valve is fine.
You cannot just buy that gasket, but will need to purchase a new Fuel Tap Petcock.
You can purchase it here: http://www.generatorguru.com/northstar/
Aug 04, 2015 | Northstar Electrical Supplies
Why does gas cap light come on even after replacing with new oem cap
Thats because there is a bad sensor (vacuum pressure) located on the top of the fuel tank. Could be a vacuum leak somewhere else, improper vacuum line connection @ intake vacuum source,or a bad solenoid vacuum switch. my guess-bad snsor.
Jul 06, 2014 | 2004 Mazda Tribute
My Husqvarna 41 will run fine for a while (up to 3 tank fulls of gas) then other times it will start and run but then bog down like under a load (but I just holding it and not cutting anything. Other...
Does this describe your problem.? 'Engine does not deliver full power or runs erratically'
Possible faults - Muffler carbonized, Piston rings leaking or broken, Secondary air seepage through leaking gaskets on carburetor spacer flange / poorly mounted or faulty manifold.
Aug 04, 2013 | Husqvarna Garden
It's leaking gas from the fitting no holes in the gas line
check the o ring inside the fitting see if damaged. also the factory line sometimes wont fit aftermarket filter. i have run into this before . you are probly gonna have to replace the line if you want to keep the pressure fitting. if not cut the rubber hose if it is flexable and slide the hose over the inlet on the filter and use a metal hose clamp to fasten the hose. this should work check 4 leeks. if it leeks bite the bullit and get the new hose oem.i hope this will help you good luck
Mar 21, 2013 | Cars & Trucks
New Maytag MGC7430 gas cooktop leaks gas when lit
First it could be leaking from the control knob when it is on . There could be a leak at the base off the burner letting out gas or on the burner line . You need to get back on to your installer or where you purchased the cook top . This basic gas fitting leak detection .
Jun 15, 2017 | Maytag Cooktops
Service engine light comes on at 1/2 tank. Sometimes prompts me to tighten fuel cap. Have replaced with new OEM fuel cap.
Hello and welcome. this indicates a problem with the evap system, which a gas cap can be the problem, along with allot of more causes. could be a bad gas cap, vent sol. purge valve or one of the evap lines leaking. two things that need to be done to help find the problem. first thing, have the system scanned for trouble codes, the system will store trouble codes. this helps in isolating the problem. the second thing, is to have the fuel tank system smoke tested. this will will isolate the evap leak.
Oct 23, 2010 | 2004 Chevrolet TrailBlazer
Whirlpool DU943 leaks heavily when filling from
I doubt the H2O tank temp would have any affect... to fix the problem you will need to pull the unit out and replace the supply line from the valve to the elbow... I would recommend braided line.
If your talking about the fill tube that loops up the side of the unit it usually is just seperated at one of the fittings and can be pushed back intp lace or recalmped... otherwise you will have to purchase a new oem tube.
Sep 02, 2009 | Whirlpool DU943PWK - Multiple Color...
Yamaha yzf600 wont start
Hi, John and the usual suspects are:
1. Damaged or restricted fuel tank venting system.
2. Loose float bowl screws.
3. Damaged float bowl o-ring.
4. improper fuel level in the float bowl.
5. Worn or dirty inlet valve or seat.
6. Damaged or leaking float assembly.
7. Particle contamination in inlet fitting cavity.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
YZF600R Forums View topic Carbs overflowing
Carbs leaking Here is how to fix it
Yamaha YZF600 YZF600R 1994 2007 Service Repair Manual PDF Download Manuals...
OEM parts for Yamaha
Yamaha YZF600RP Owner Manual
Mar 08, 2009 | 2003 Yamaha YZF 600 R thunder cat
Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0 Tecumseh Engine Logo
75 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Mike Squire
Tim Whalen
Are you a Troy Garden Expert? Answer questions, earn points and help others
