Question about Home Security
How do I change the receiver battery of a faber serene gas fire?
What can be done about a gas fire that comes on by itself?
yes it is operate manually there is a manual on line which helps . have read it easy operation .
Dec 09, 2017 | Televison & Video
Parts -- # 133.0073.597
i need the same part. where did you order it from? thanks.
Jan 19, 2014 | Euro-Pro Faber Axia Isola Plus Kitchen...
Carol LeBlanc
please follow this link to find a servicer: http://faberonline.com/service.html
Nov 25, 2013 | Faber Inca HC SS Stainless Standard Insert...
Need a manual for a procom ventless gas fire place,FBD400 RTCC M MO,wont turn with remote,changed all batterys.
ProCom manuals should be easy to locate since they are still being distributed and sold. Have you already located one? I am uncertain how to load one here but if you have not located one contact me and i'll get a copy to you.
Every time the batteries are changed in the receiver and transmitter the transmitter has to be "re-learned" to the receiver. To do this locate the "learn" button which will look like a tiny hole so you have to stick the end of a pin or a pen in the hole to press the button. Hold the button down until it beeps at you 5 times and release. press the button again and release and then press Any button on the transmitter.
Once the receiver is set into its "learn" function it does not matter what button is pressed on the transmitter because the next signal the receiver picks up will be the frequency it is attached-to.
In order to change the transmitter simply hold the learn button down until it beeps 5 times again which tells us it has wiped out its memory. Then press, release and press the transmitter.
Aug 21, 2013 | Real Fyre 30" Evening Fyre Ventless...
Where can I find a manual in English for a Faber Casteel slide rule?
Welcome to Fixya.
Please follow the link below for the slide rule manual :
Slide Rule Manual
Thanks for using Fixya.
Aug 19, 2011 | Faber Castell Toys
Problem changing halogen bulbs on perla rangehood
The more I worked with it, the more I discovered that the real problem was that a screw was not all the way screwed in and it was preventing the panel from sliding. Another problem I may have is finding the glass covered halogen bulb.
May 13, 2009 | Faber Perla 602599 Kitchen Hood
Home Security Logo
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
