Question about Brother Lay-In Thread Serger Mechanical Sewing Machine
Lower looper and upper looper stuck together and machine stopped working
4 Suggested Answers
SOURCE: My 1034D serger has a broken part that holds the lower looper.
call brothers hot line 1-901-373-6256 tell them your problem and part no, if you know it if not they should be able to help you
Posted on Mar 13, 2008
  • 323 Answers
SOURCE: brother serger thread
The lower looper thread MUST be threaded before the needles are threaded. You must also be sure the lower looper thread is pushed and staying all the way to the left before it is threaded through the looper eye. Double check the threading diagram and count the number of guides the thread passes through. Count how many guides you have actually passed it through. It must be the same. The dealer you bought it from should be willing to show you if you can't figure it out.
sewman7
Posted on Jun 18, 2008
Tally Girl
  • 1133 Answers
SOURCE: lower looper thread gets stuck
does this Serger have a moveable threading part on the lower looper and if so, is it in the correct position? It sounds like the clip is in the wrong place if it is catching the thread, so this could be the cause if so.
If not, then I would suggest that you recheck the threading, and thread in sequence, top looper, bottom looper, then needles, checking all thread loops are being used in the thread path, review carefully using the manual's threading diagram.
If you still can't resolve the issue, then take it in for a service, it is possible to knock the loopers out of time and if so, you'll need a technician to rectify.
Posted on May 23, 2011
Toyota overlocker sl3000 ; 3rd thread keeps snapping. How do I stop this ?
Third thread--is that the upper looper? Remove all the threads from the machine. Clip them below the thread tree, RAISE the presser foot, and then pull all 4 threads down through the needle. (Never Pull Up!!)
ALWAYS RAISE the presser foot.
Rethread beginning with the Upper Looper, then Lower Looper, then the needles. Be sure to ALWAYS thread in this order!! (On most newer machines, when threading the Lower Looper, always finish with the Lower Looper "draped" over the top of the Upper Looper.)
If a thread breaks, remove the threads and start over from the beginning as trying to fish a thread through the existing threads very SELDOM works.
Verify each thread path is correct.
When threading each thread and to insure the threads are seated in the tensioners, give each thread an extra little tug when going through the tension disk.
Be sure to oil your machine frequently to keep it operating smoothly!
Make It Handmade Threading Your Serger or Overlocker
Serger threads Threads Magazine Gatherings Forum Sewing Questions Answers
May 03, 2017 | Toyota Sewing Machines
Upper looper hits lower looper
The upper/lower looper need realignment, requires a qualified technician to do this.
Oct 21, 2013 | Brother 1034D Serger Sewing Machine
Upper looper stuck?
Had the same prob once. I needed to find the screw that ataches the looper to the machine and readjust it. If you are not machine savey then you may need a professional. I needed the hubby to help me.
Feb 18, 2013 | Brother 1034D Mechanical Sewing Machine
I have a bernina overlocker and whenever I use it the lower looper (marked in red) thread breaks. How can I fix this? It was serviced yesterday and when other people used it before me it worked fine!
Then it's one of two things. First try setting your lower looper tension on 3 and see if that works. If not set it back on 4 and cut ALL your threads and re-thread the machine STARTING with the UPPER looper, then the lower looper, then the right needle, last the left needle if you're sewing a 4 thread overlock stitch. Make sure the threads aren't twisted in the thread guide. Make sure the lower looper thread is OVER the elbow on the upper looper and over the upper looper thread. Let me know if this works. We'll work until we get it fixed!
Sep 14, 2010 | Sewing Machines
JUKI MO 134 SERGER
How to Thread Juki MO-134 Serger from watching lady at Lyles. Turn upper blade up. Push in first then turn up.It makes threading easier. Blue Thread upper looper first. Pull thread through tension knob. Don'tjust lay it there. (She thought that is what I must have done) Orange Thread lower looper next. Pull thread through tension knob as inthreading upper looper. Adjust lower looper so it is right nextto upper looper so that their points are almost together and directly belowsewing needles. Lower looper will be in front of upper looper (I believe). With tread from upper looper pulledback, slightly lift lower looper above upper looper and thread. I think this isright. Pull thread back with other thread. Tension is the key. Remember that. Yellow: Thread left needle first.Remember tension. Pull thread through curled wire on left side of needle arm. Green: Thread right needle. Rememberabout tension. Pull thread through curled wire on right side of needle arm. b> Note: Before sewing turn the wheel tomake sure the stitches are going together correctly.
Apr 16, 2010 | Juki MO-644D Mechanical Sewing Machine
I had to rethread my Singer Ultralock serger and now it won't sew correctly. Best I can tell the lower looper keeps coming unthreaded, but this doesn't happen until I put material in. I have rethreaded it...
I had read where someone said their lower looper tension dial had pulled apart. Sure enough, mine had too. We snapped it back together and Voila problem solved!
Dec 06, 2009 | Singer 14SH654
How to thread an overlocker - bernina 2500dect
Here's a manual to download:
BERNINA Support Machine and Accessories Finders and Software Support...
NOTE: Be sure to thread each spool in the order SPECIFIED in the manual. Usually the upper looper threads first, then the lower looper second. Make sure when you finish threading the lower looper that the lower looper thread CROSSES OVER the upper looper (and thread) before going under the presser foot.
Nov 02, 2009 | Bernina Sewing Machines
Threading a husqvarna huskylock 1001L serger
Solution taken from "Handbook for Huskylock Sewing Machine Models 1001L/1000L/1000"
1. Raise the presser foot by using presser foot lever. When the presser foot is raised, the two thread tension discs in the thread tension control panel are released so that thread passes freely between them. Otherwise thread tension may not be correct.
Important! When threading the needle, always be sure to lift the presser foot lever, and also take care to thread in the proper order.
Threading order:
1. Upper looper thread (green)
2. Lower looper thread (blue)
3. Double chain stitch looper thread (purple) in case of 5 thread stitch or double chain stitch
4. Right needle thread (red)
5. Left needle thread or double chain needle thread (yellow)
Caution!
Because the left thread tension dial (yellow) is used for either the left needle or the double chain stitch needle, these needles will never be used at the same time.
Upper looper (green) sequence:
1. Thread holder (silver triangle openings attached to thread holder stand)
2. Thread guide (flat silver clips just behind thread tension disc)
3. Thread tension disc (circular knobs with numbers for tension setting)
4. Pull thread around upper looper guide and upper looper
5. Pull thread into hole of upper looper
Lower looper (blue)
Repeat 1, 2, 3.
4. Pull thread around guide (see color coded chart inside front serger cover).
Easy threading mechanism (for lower looper)
1. Pull out the lower looper threading lever
2. Thread the lower looper and position the thread on hook of the lower looper
threading lever.
3. Push the lower looper threading lever back to its basic position while
holding the end of the thread.
Caution:
When returning the lower looper threading lever, always make sure that the two
blue triangle marks (directional arrows) meet each other.
Left needle thread (yellow)
Important: Thread the needles after threading of lower looper and upper looper.
First raise the presser foot lever, and then thread the needle threads in order shown in color coded thread guide.
Jun 24, 2008 | Sewing Machines
Upper and Lower Looper Rub Together!!
Your loopers need adjusting, impossible to explain how to do this, you need to be shown. Can I suggest you contact a sewing machine tech, sure it will cost but if he is a decent guy he will show you how to adjust the machine.
Apr 23, 2008 | Singer 14SH654
Lower looper threader
check to make sure it is not wraping around the upper looper. just stitch without the material and you will see it. but then you must rethread the upper looper and the lower looper again in the right order. hope this helps
Apr 14, 2008 | Brother 929D Mechanical Sewing Machine
Brother Lay-In Thread Serger Mechanical Sewing Machine Logo
67 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
