Question about Fargo HDP5000 Thermal Printer
Fargo hdp5000 error 170 - Fargo HDP5000 Thermal Printer
2 Suggested Answers
SOURCE: we just bought Fargo HDP5000.
hola hermano tengo problema con mi impresora hdp 5000 cada vez que boy a imprimil me da un error 103 y 105 me dice en la pantalla del monitor de mi pc que el sensor no detecta el movimiento del cabezal
Posted on Aug 26, 2011
ERROR MESSAGE 246
There was a communication
failure between the Printer
and Laminator.
FARGO Electronics HDP5000 User Manual Page 96
Feb 25, 2016 | Fargo HDP5000 ID Card Printer Dual-Sided -...
Hdp5000 colour problems
Update the printers firmware. This is always my first step when servicing these printers.
Drivers Downloads
On this same page, make sure to download the Fargo Workbench Utility (towards the bottom, under "misc"). This application is needed in the updating process and is very useful when dealing with settings issues, like this.
Jun 23, 2014 | Fargo HDP5000 Thermal Printer
Fargo HDP 5000 heater error 161 fault
This error usual occurs after a large print job (50 prints in a row). Try shutting off the printer, and leaving it off for a good 15 minutes. Turn back on and retry.
If the problem persists, then you should contact a service center. It seems to have a failure in an internal sensor.
May 06, 2014 | Fargo HDP5000 Thermal Printer
How can i turn on or off my fargo hdp5000
Fargo HDP500 didnt make any power on or off button you just need to remove the power cable direct from the printer and retuning it their also it will turn the power on
thanks
ED
Aug 30, 2012 | Fargo HDP5000 Thermal Printer
Ribbon miscue on cyan fargo hdp5000
There are a few things which could lead to a ribbon miscue. The most obvious would be your firmware. Go to Fargo's site and download the latest firmware patch. Your printer may driver be corrupted, so uninstall and then re-install it. One other possibility is that your printer has a faulty ribbon sensor which would need replacing. I hope this helps
Aug 11, 2012 | Fargo "HDP5000 Single Sided Card Printer,...
Error fargo hdp5000 # 218
can somo one help I have Fargo HDP5000, showing an error LAM2 HEADLIFT ERR 218
Apr 21, 2011 | Fargo HDP5000 Thermal Printer
We just bought Fargo HDP5000. on first installation now its bringing error code 97 and 99 which when we calibrated the printer the error 99 was solved. but the error 97 is still there. pls help
Apr 19, 2011 | Fargo HDP5000 Thermal Printer
Ribbon error code 97
Fargo HDP5000 is the most stupid unpractical product and it waste our time and effort
I think HID must stop production of all Fargo Printers
I had a lot of problems everyday from this stupid expensive useless HDP5000
Jul 08, 2010 | Fargo HDP5000 Thermal Printer
Fargo HDP5000 HDP5k H5k Ribbon Breaks Error 97
You need to update the printers firmware. 9 times out of 10, this is the issues I see.
Go to HIDglobal.com. Under the support tab, select Drivers & Downloads. From here, populate the drop down menus with Make and Model. Compare the available firmware with the firmware version current installed on the printer.
Hit [Options] then [Next] on the printer to figure out the version.
On this same web page, make sure to download the Fargo Workbench Utility. It gives you the ability to update.
Aug 06, 2009 | Fargo HDP5000 Thermal Printer
Edge to edge print problem
The Fargo DTC550 will not be able to print an "over the edge" card. Any Direct To Card printers will have a white line on the edges. There are several printers that are able to print covering the entire card, those printers are called Reverse Transfer or Fargo's High Definition Printers. One printer that I do recommend is the Fargo HDP5000, you can read more about it at: http://printers.idcardgroup.com/productdetails.aspx?item=hdp5000
Apr 22, 2009 | Fargo DTC550 Thermal Card Printer
Fargo HDP5000 Thermal Printer Logo
42 people viewed this question
Top Fargo Office Equipment & Supplies Experts
Safe-Card ID...
Are you a Fargo Office Equipment and Supply Expert? Answer questions, earn points and help others
