Detail all keyy of casio calculator dj-120 - Office Equipment & Supplies
5 Suggested Answers
SOURCE: casio jf-120er euro rate set
Press AS
Hold Down RATE SET (%) for about 2 second and the correnty rate appears on the display
Imput the conversion rate and the press rate set (%) to store it in memory.
Best regards
Alberto
Posted on Jan 18, 2008
  • 7993 Answers
SOURCE: Hi, I have a Casio calculator fx-991MS giving me wrong answers!
I am only looking for a plausible cause of the error, because I do not believe your calculator can make such a mistake. I think you accidentally activated the Exponential display format and did not pay attention to the small, raised -03 that came at the end of the number displayed. It is a common mistake for those not very familiar with Scientific or exponential notation.
Let us try to reset your calculator to the normal (floating point) format.
Press the [MODE] key a number of times until you reach a screen that has FIX, SCI, NORM and under each one a number (FIX 1, SCI 2), Norm 3). To have the number of decimal place you gave in your result (4 decimal digits), you press 1 to select Fix then 4.
Be aware that scientific calculators usually stop displaying results in floating point format ( 0.0000045 ) if the number is smaller then 0.001. So basically, 0.00099 will be displayed as 9.90-04, -04 being raised above the level, and in smaller size.
Hope it helps.
Posted on Oct 02, 2009
Testimonial: "Thanks so much, its working now:) I thought I was going to have to buy a new calculator!"
SOURCE: Percenteg Function problem in my Casio MJ - 120 Model Calculator
I found it by myself, I can help you.
1. Press (AC)
2. Hold (Rate) for about 2-3 second
3. Press (Set / TAX+)
4. Input the tax rate
5. Press (Set / TAX+)
6. Hold (Rate) for about 2-3 second again
7. Press (Set / TAX+) again
And Then you can test the rate .
From Thailand
Posted on Oct 19, 2009
SOURCE: i have a casio dj-120
Hold the rate set[%] key for 2-3 seconds.
Press the tax key.
Input the tax rate.
Press the rate set[%] key.
Posted on Aug 23, 2011
What does the MU/MD key on the Casio HR-100TM do?
Here's how to use the MU/MD key. Say you want your item that COSTS you $120 to be priced such that you end up with a 40% margin. MU'MD calculates the final price to achieve the margin.
Enter: 120 X
Enter: 40 MU'MD
Result: 200.00
Proof: 200 - 120 = 80 / 200 = 40%
Essentially the same as using the COST/ SELL/ MAR keys.
The Casio HR-100Tm manual is pretty pathetic. Expected a better one on their website, but alas.
Jan 03, 2017 | Casio HR-100TM Printing Calculator - 12...
WHAT IS THE FUNCTION OF MU BOTTON IN CALCULATOR CASIO MJ-120D?
It is used for calculating markup. For example, if you have an item at $100 and have a 20% markup, you get $120.
http://support.casio.com/storage/en/manual/pdf/EN/004/MJ-100D_MJ-120D_EN.pdf
Sep 20, 2015 | Casio Office Equipment & Supplies
How do I get all the factors of a constant using my calculator?
There is a program on page 253 of the manual (http://support.casio.com/manualfile.php?rgn=5&cid=004002013) to get the prime factors of any number. You could modify the program to get all the factors.
Another way would be to do it manually. I start with the number 1 and go up to the square root of the number. The square root of 120 is 10.95, so let's go up to 11. Using 120 as an example:
120 /1 = 120 thus factor is (1, 120)
120/2 = 60 thus factor is (2, 60)
120/3 = 40 thus factor is (3, 40)
120/4 = 30 thus factor is (4, 30)
120/5 = 24 thus factor is (5, 24)
120/6 = 20 thus factor is (6, 20)
120/7 = 1.7 thus 7 not a factor
120/8 = 15 thus factor is (8,15)
120/9 = 13.3 thus 9 is not a factor
120/10 = 12 thus factor is (10,12)
120/11 = 10.9 thus 11 is not a factor.
Good luck.
Paul
Jul 05, 2015 | Casio FX-9750GII Graphing Calculator
How do i change tax rate in DJ-220D ?
Follow the instructions in the fourth column of the instruction sheet. If you need a copy, you may download it at http://support.casio.com/storage/en/manual/pdf/EN/004/DJ-120D_Plus_etc_WB_EN.pdf
Mar 03, 2015 | Casio Desktop Calculator - DJ-220D
How come i dont get the right answer for example 120 divided by tan68 = -58 instead of 45?
Make sure your calculator is set to the desired angular mode.
The quotient of 120 divided by the tangent of 68 radians is about -58.82, as your calculator is giving you.
The quotient of 120 divided by the tangent of 68 degrees is about 48.48 . The quotient of 120 divided by the tangent of 68 grads is about 65.97 .
Oct 06, 2014 | Casio FX-9750GII Graphing Calculator
I have a casio dj-120 and want to set the tax rate how do i do this
Press the tax key.
Input the tax rate.
Aug 03, 2011 | Office Equipment & Supplies
I purchased a casio fx-115 ES calcullator. When I use it to calculate total resistance of a parrallel circuit, I use the formula: 1 over the sum of the reciprical of resistances in the circuit. When I...
There seems to be two completely different issues here.
By default the calculator will try to show a symbolic result. 1 divided by 120 is 1 over 120, after all. If you don't want to see fractions at all, press SHIFT MODE 2 to switch to the LineIO mode.
The other is the display mode. 1/120 is about 0.0083. Again, by default, the calculator automatically switches to scientific notation for numbers whose magnitude is less than .01, so it shows the number as 8.3x10-3. To change this, you have two choices. Press SHIFT MODE 6 to select the fixed decimal mode, and the calculator will prompt for the number of digits to the right of the decimal. Alternatively, press SHIFT MODE 8 2 to select the Norm2 mode. This won't switch to scientific notation until the magnitude of the number drops below 10-9.
Calculators only have two choices when a number gets close to zero. It can either round it off to zero, or switch to scientific notation. It doesn't matter how many digits the calculator can display, at some point it has to make the choice.
Nov 30, 2010 | Casio FX-115ES Scientific Calculator
Need to change the vat rate on casio hr-150tec calculator
I have a j-120 Casio, and the following worked on that:
Press and hold the 'rate set%' button (next to "Tax-" button).
The currently held rate will display.
Type in 17.5, then hold down the 'rate set' button again.
Voila!
Sep 09, 2010 | Casio HR-150TER Calculator
How do I set the tax rate in my Casio DJ-120T-w calculator
Press AC
Type the tax rate you want. For 17.5% vat type 17.5
Press RATE. RATE flashes in the display.
Press TAX+
Nov 06, 2008 | Casio Computers & Internet
Casio jf-120er euro rate set
Press AS
Best regards
Alberto
Dec 10, 2007 | Office Equipment & Supplies
15 people viewed this question
jasbo
jasbo
