Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
How to adjust belt tension 42" raftsman lawn tractor cutting deck
Belt seems too loose it slips when I engage to cut the grass can it be adjusted or do I have to replace it thank you
  • 1 more comment
  • Richard Sedor May 09, 2009
    I have the same problem with my 15.5 hp Craftsman 42 in
  • Richard Scordino May 11, 2010
    check to see if all the pulley tension springs are on and in good condition. Don't work under deck unless plug wire is disconnected.
  • Ismael Abad Jun 07, 2013
    this sucks!
    Problem Solver:
  • 12 Answers
Note: This is about a different mower, but it might be similar enough to yours.  If not, please disregard.  Thanks!
I had a similar issue with our mower, a 2006 Troy-Bilt Pony model 13AN77TG766 (17.5 HP, 42 inch deck): when I pushed the handle down to engage the blades, it took a good ten seconds or so to start the blades turning; even then, they didn't have enough power to cut the grass.  And on any height setting lower than 5, they wouldn't turn at all.
The cause was on page 19 of the manual <URL:http://manuals.mtdproducts.com/mtd/DocGetter?doc=769-02243a.pdf>: Figure 17 shows the "PTO" cable attaching to a hole on the edge of the deck idler bracket, but it was shipped from the factory attached to a hole in the middle of the deck idler bracket, about 3 cm (1 in.) closer to the front end of the machine.  I reattached the cable to the original hole, and the belt is now good and tight; the blades engage as soon as I push the handle down.
Now, today, I'm having problems with the belt popping off the right-hand idler (hopefully just needs the deck stabiliser rod adjusting).
Always remember to remove the spark plug wire before you go near the blades; and watch for hot, sharp, and/or pinching surfaces.
Posted on May 19, 2009
    New Friend:
How to put a cabil sparge on
Posted on Jun 29, 2013
  • 246 Answers
Hello:
Depending on the Model of this Unit it May have an Adjuster or the Belt May be Tensioned by a Spring and Idler Pulley.
>>To View a Breakdown of this Unit Go to this Site Addy, http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080114x00001 and Enter the Model Numbers and Click Search. From this Page you can View Diagrams and Parts Lists for you Equipment Using the "View Sub Components" Section Near the Bottom Left.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
John
Posted on May 10, 2009
Why would a riding mower have the blade turning slow?
If speed varies depending on how much grass you are cutting, look for loose or badly worn belt. If constant slow speed when engine is running at full noise can only be a slipping on pulley or clutch. Most likely clutch. Normally slipping generates much heat so look to your clutch or pulleys. If drive key has separated there will be damage to shaft with metal dust showing.
Jul 21, 2014 | Toro Garden
Lawnmover blades engage when shouldn't
on the linkage to tighten the belt one of them is adjustable look for a rod with a lock nut on it
Aug 23, 2012 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Need a troubleshooting manual for a craftsman mod. 917.287070
Went out to cut grass and the blades will not engage and when I put it in gear it does not move. Belts are intact. I cleaned the deck of dirt and grass. Still nothing. Just replaced the cable to engage the blades last year. Cable seems to be working.
Jun 25, 2012 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Blades won't stay engaged in any length of grass
Sounds like a broken shear pin in the drive pulley. Check the belts and see if they are slipping. Broken shear pin will not let the blades spin under pressure. .
Aug 09, 2017 | Toro Garden
Why do cutting blades start slipping in heavy grass?
either the engine speed is to low or the belt is slipping how old is the belt is there a oil leak that got the belt wet with oil?
May 20, 2012 | Garden
Husqvarna too slow when mowing
Some self-propelled mowers include a speed control, but sometimes it may seem that no matter how you adjust it, the mower just creeps along at a snail's pace. Most likely this isn't a mechanical malfunction, but an adjustment is probably needed.
Very tall or thick grass can bog down a self-propelled mower, but adjusting the height of the blade may allow it to roll through and cut the grass at normal speeds. If the blade is low, the amount of cutting required may slow down the movement of the entire mower. The frame of the mower may also stick in the high grass. Raise the blade little by little until the mower rolls at the appropriate speed. Going up hills may cause a similar response.
It's possible the drive belt on the mower can slip. Inspect this part to see if it is loose or cracked, and replace the belt to restore power.
May 08, 2012 | Garden
I have a 17hp craftsmans lawnmower with a 42 inch deck. The motor runs fine, I just cant get the deck to engage. How do i fix this?
I hope you didn,t put wd40 on the belt that will cause it to slip, also with the motor OFF you should be able to engage the belt, so try that just to make sure it does engage and check the tension on the belt it should be snug. Again only with the motor OFF.
Mar 26, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
When I engage the blades on my ez4824 the blades intermittently stop cutting particularly in higher grass. Do you think this is a loose belt problem? Thanks.
That is the most likely cause of the problem - taller and thicker grass the blades encounter more resitance and the drive belt slips and it doesn't cut. This would likely cause a juddering of the machine when it occurs.
Hope this helps.
Jul 11, 2011 | Husqvarna EZ4824 24 hp 48" Zero Turn Lawn...
My Craftsman Lawn Tractor is making a whining sound and a burning odor when I have the cutting deck engaged. It stops as soon as I dis-engage the blades.
it sounds like the deck and or the belt needs to be adjusted and aligned. 1st make sure mower is OFF and blades are disengaged. check to make sure the deck/blades are free of harden grass, twigs, branches, and that they are free moving. 2nd make sure belt is in its correct path. 3rd make sure the deck can be lowered and raised without obstructions 4th make sure no parts have been bent and the pulleys are parallel to the deck and the deck is not cracked or broken by the blades hitting something hard and the deck being damaged. 5th the belt adjustment needs to be tight but not over tightened (see a service dealer).
hope this has been helpful. contact me if you need further help.
Thank you.
Jun 26, 2011 | Craftsman 20 Hp 42" Deck Lawn Tractor
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
4,608 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
