posted by jewelie on Oct 10, 2007
water keeps coming into machine even if the power is off. Noticed this during final spin cycle. water was still coming into machine during final spin
Best Solution
posted on Oct 10, 2007
I don't know this specific machine model but it sounds like something has gone wrong with the water level sensing, which is usually controlled by a pressure switch, probably at the top of the machine. Look for a small diameter (<10mm) rubber tube come loose or broken, perhaps an electrical connector come off from the pressure switch and failing that the pressure switch itself. It is also just possible that the solenoid valve where the water inlet pipe connects to the machine has stuck open - but I would expect it to fail shut.
ADC
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Samsung WF337AA Front Load Washer
Email this problem
Email this problem
Can you Help with these Washing Machines problems?
Samsung Front Loader Washer Out...
I just bought a Samsung... Answer This...
SAMSUNG FRONT LOAD WASHER
uses very little water the... Answer This...
how do you get rid of alarm...
samsung washing machine Answer This...
Repair Service
Find Washing Machine Repairman Near You:
