Question about Garden
Hello i have a karcher k21.20 pressure washer got a problem with it when i put it on from the on/off button the motor comes on and does not go offcontinous motor on and no pressure when u use it
  • 313 Answers
SOURCE: I have a Karcher electric
see www.pressureparts.com for karcher
Posted on Jul 08, 2008
  • 389 Answers
SOURCE: I was using the pressure washer and it stopped
This problem, where the unit continually switches on and off when the handgun is closed, is quite common. Unfortunately it has at least six different possible causes, only two of which are easily checked.
The first thing you can do is look for leaks.  Even the slightest leak will cause this pulsing because the unit gets up to pressure, switches off, loses pressure, switches back on again, comes back up to pressure, switches off... and so on.  This repeated switching is not good for the motor and should not be allowed to continue for longer than necessary to observe what's happening.
So... 1. Does the handgun shut off completely, or does it drip? If it drips, it may simply be because a seal has failed. The handgun can be dismantled, checked, and any defective parts replaced; be sure to lubricate O-rings with silicone grease when reassembling. As a last resort, the whole gun may need to be replaced.
2. Are there any visible leaks at the high-pressure hose screw connections?  If so, most likely an O-ring needs replacing - again lubricate the new one well with silicone grease.
3. If there are no visible leaks, either from the gun or from the connections, all other possible causes are internal within the cylinder head or control head of the pump. New parts will be needed and this normally calls for a professional repair, although it's not beyond the scope of a truly competent amateur.
I hope this helps. Any further questions, just ask! Please remember to rate this response.
Posted on Apr 17, 2009
  • 33 Answers
SOURCE: karcher pressure washer k2.89
pressure relief valve is stuck. can't have an air lock.
Posted on Apr 21, 2009
SOURCE: my karcher pressure washer has lost its water power
I have the same problem. With mine I have to remove the tip that I am using then pull the trigger and then replace the tip and pull and pressure should return. I believe that one of my valves is sticking causing me to reprime the pump frequently. I am trying to clean or replace my valves to fix the problem.
I hope this helps.
Posted on Apr 25, 2009
SOURCE: Unloader Valve - Karcher Pressure Washer
where is the unloader valve locaed on a Briggs Stratton pressure washer?
Posted on Oct 03, 2009
How do I fix a problem with my Karcher K4 pressure washer.
Sharon, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Grumpy gits and useful tips
How to FIX Karcher pressure washer
Karcher North America Home Garden Online Help
Aug 09, 2016 | Karcher K 5.85 M Electric Pressure Washer
Karcher pressure washer doesn't work
it;s normally a switch interrupter must replace with actual with for motor protection.
Aug 14, 2014 | Karcher Garden
HOW MUCH OIL DO WE PUT IN KARCHER3030B AND WHAT SORT OF OIL
you need to know where oil is coming from. pump or motor? both will use normal motor oil
Mar 30, 2014 | Karcher Garden
I own a Karcher 3000 pressure washer. There is no water pressure. I've checked the obvious...hose to house, kinks, attachment is tight....Enging runs, no water pressure.
I had the same problem. On the top of the pump there is a little nickle colored button cap. It is attached on both sides with a screw. What this actually does I don't know but when I took it off with the motor running and put my finger over it the pressure come up. I also discovered that having the motor running and taking the nozzle tip off and pulling the trigger would clear the pump to work until you let of the trigger again. Weird but it works for me.
Aug 06, 2010 | Karcher Garden
Hello there.My Karcher pressure washer motor constantly runs with no pressure coming out of trigger gun.I have tried another gun with the same result.The motor should stop/start when you press gun.The...
The valve that admits more water to be compressed is stuck. It is likely the O-Rings on it need replacing. No water to the pump, no pressure!
The motor will stop when pressure is up to the designed pressure.
Oct 03, 2009 | Karcher Garden
Karcher prssure washer motor will not start
try going to www.karcher.com
then click on europe
the international,
then service and will then see spare parts, enter k620
tick the button for you are a engineer and you are on your machine
download.
micro switch might be at fault.
Mar 25, 2009 | Karcher Garden
I have a Karcher 3.99 Pressure Washer. The motor appears to be working and water is passing through the machine when turned to the detergent application setting. However when the lance is tightened to turn...
Hi I have a karcher 3.99 the motor comes on and water comes out however thre is no pressure i have tested the lance on my brothers washer and this is ok what is wrong
Feb 21, 2009 | Karcher K 5.85 M Electric Pressure Washer
Karcher pressure washer k2.89
May 31, 2008 | Karcher 2500 PSI Pressure Washer
Reset Button
your testing the no fault short or motor overload feature. the red light indicates you have power. no light no power.
Apr 02, 2008 | Karcher 2500 PSI Pressure Washer
Garden Logo
18 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
