Question about GE Washing Machines
Ge washer model gcwp1800 doww does not fil up on rinse
Water leval is too low on rinse cycle needs more water to rinse clothes out
  • 1294 Answers
SOURCE: ge washing machine
When your rinse cycle does not work it is your outlet filter that is clogged. If this is a front loader the small door is in the bottom front side of machine. Be prepared for some water to come out when u open the door. Unscrew and clean out filter and refit.
Posted on Sep 21, 2007
mikedurland
  • 481 Answers
SOURCE: Ultimate Care II - Rinse Cycle does not start
sounds like a lid switch problem. is there a clicking noise when you open and close the lid?
if not then the lid switch may need to be replaced; inexpensive.
this could also be caused by a bad timer.
also try a different speed for the rinse cycle, it may be a bad motor and it is not going into a certain speed. instead of gentle or slow speed try fast or normal, something like that.
Posted on Jun 28, 2008
SOURCE: GE washer won't fill with cold water
Cold water pipe had become frozen. FYI this model of washer has a nice feature whereas you can test each component i.e. valves, by setting the timer and reading the LED's on the front panel. Instructions are in the schematic.
Posted on Jan 19, 2009
  • 188 Answers
SOURCE: Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Posted on Mar 03, 2009
  • 351 Answers
SOURCE: Roper top load washer Fills, agitates but stops at rinse cycle.
you are welcome
Posted on May 01, 2009
Will not spin the water out of the clothes
call a repairman sounds like a controller problem or transmission not getting final rinse signal
Mar 15, 2015 | GE Profile PTWN6050MWT 27" Top-Load Washer...
Washer continues to run
Ok. So you are getting ZERO water in the washer or just in the rinse cycle?
Apr 07, 2014 | GE Washing Machines
GE washing machine rinse level is too low
if its still under the makers cover call them out ???
Jan 21, 2014 | GE Washing Machines
Washer doesn't run all the way thru cycles. It's
Removed hose connecting to water pump at tub. Removed clog (ink pen, coins, etc). Replaced and ran washer. Ran through all cycles - no leaking, no pausing of cycles. Problem is resolved.
Oct 01, 2009 | GE Energy Star 3.7 IEC Cu. Ft. Front Load...
My GE front loading washer Model WCVH6260 does not start the rinse cycle spin. It has a motor sound and some water seems to be draining but the rinse cycle does not spin and the motor continues to make a...
This has happened to us also. Our machine is 27 months old. I just had a non-GE repairman out and he showed me the mutilated belt. I was wrapped around the pulley. He said that the pulley had to be out of wack in order for this to happen because the belt looked in great condition (besides being in 3 pieces). Then the metal wheel (don't know the official name) is now warped and had gouged 3 grooves into the cheap plastic outer tub. So badly that it went thru to where the water is. So NOW, I have a big piece of scrap metal in my basement. I need a new outer tub, pulley, belt and at least 2 hours of labor. So a bill of 4-500$. I think GE can take this hunk of metal! But of course, GE has to send out their service man to inspect it. So I have to pay another service fee. They need to scrap this model and possibly others. What a waste of a whole lot of money. NEVER again.
Oct 01, 2009 | GE WSXH208A Front Load Washer
Manual claims machine has ability to spin out water but there are no options on the control panel
There are different models withing this line by GE. There is one model that have a "Drain & Spin" cycle on the main cycle selection knob, but on the higher end models, you'll need to use the "Rinse & Spin" cycle.
This will add some water to the washer, but the basic cycle will give items a quick rinse and spin.
If you're trying to use just a spin cycle to wring out towels, etc. and you don't have the "Drain & Spin" cycle, (which you shouldn't based on your higher end model #), just use the "Rinse & Spin" cycle and it'll do a nice job of getting out a lot of moisture from your clothes, towels, etc.
I have this same washer in my own home and refreshed my memory by reading my manual (again) to see that this is what you need to do, to spin out stuff.
Hope you find this Very Helpful and best regards!
Aug 22, 2009 | GE WCVH6260FWW
Stiff clothes in my GE front load washer
Add two cups of white vinegar to the tub and run the hottest and longest cycle. this will clean out your machine thoroughly.
After that add one cup of white vinegar to the wash to prevent stiffness
Aug 05, 2009 | GE WSXH208A Front Load Washer
Ge front load washer won't go into rinse cycle.
Check the cold water hose. My brand new machine had this behavior until I discovered a kink in the cold water hose - works great now.
Jun 03, 2009 | GE WSXH208A Front Load Washer
Washing Machines Logo
53 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
