Question about HP DeskJet 1200c InkJet Printer
HP Deskjet 1200C
The Check Paper light comes on after it goes through the warm up cycle and starts the feeding process. I have taken apart the printer and checked the paper prox switch, it seems to be clean and mechanically funtioning.
The paper will go through and stop at the point where its ready for printing but the check paper light comes on everything stops.
Anyone seem this before?
Ben
inkjet1@bellsouth.net
5 Suggested Answers
brandonboyce
  • 84 Answers
SOURCE: repairing tips for Hp deskjet 1125c Inkjet Printer
It may be the rollers that grab the paper and pull them into the tray, over time they start wearing down and losing their grip, kind of like a car tire. There are rejuvinator pads available that will give the rollers a little big of their grip back but I don't know how effective they are because I've never used one.
Posted on Jul 12, 2007
Ajkill
  • 2035 Answers
SOURCE: paper feed problems hp PSC 1510
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Posted on Oct 17, 2008
komguy
  • 2306 Answers
SOURCE: Paper feeds into printer 1/2way, stops, check paper light flashes
Yes, there is a sensor on the right side of the carriage that points down at the paper, you use a Q-tip moist with water and wipe the underside of this sensor, you may need a couple since quite a bit of ink sprays onto this sensor.
Posted on Jul 20, 2009
  • 108 Answers
SOURCE: HP Deskjet 1200c will not feed paper. Fails to
This sounds like a problem with the paper pick up rollers. I would suggest cleaning the rollers with a little isopropyl alcohol. Please make sure the machine is turned off when doing the cleaning. Let the rollers dry for a few minutes. If this does not work, The rollers would probably have to be replaced.
Posted on Aug 28, 2009
Hp deskjet 2050 can't take paper in..check every piece of jam paper, but still it can' t take paper
That reminds me.....Mine does the same darn thing....I'm going to take it apart and see what's up right now....I may return to tell what I find later...
Mar 27, 2015 | HP Deskjet 2050 All-in-One Printer
HP deskjet 920 c crooked feed
there should be a rear panel to remove and check to see if there is any small peices of paper caught in the rollers or obstructing one side, if not the grip on the the roller is worn or the paper aligning bar is open too wide and allowing the paper to tilt. This is a more common problem with shiny surfaced paper, so try a more matt rougher quality paper.
Jun 04, 2007 | HP DeskJet 920c InkJet Printer
HP deskjet 3845 will not feed paper to print. Is the green light suppose to blink? Not sure where paper needs to go to get proper feed
Paper goes in the bottom tray. Take a small stack and place it in the bottom tray and push it in until it stops. It will feed out of this tray, print it and output it to the top tray.
Jul 12, 2010 | HP Deskjet 3845 InkJet Printer
Printer does not print
try different paper ,check for any loose parts that may be interfering with paper feed,if theres nothing obstructing it and you have tried new paper ,take it back ,its defective.
Sep 30, 2009 | HP DeskJet 1200c InkJet Printer
HP Deskjet 1200c will not feed paper. Fails to pick up paper from tray. If force pickup by hand can get it to start printing but moves paper in wrong direction as as positions for printing. Does not...
Aug 28, 2009 | HP DeskJet 1200c InkJet Printer
Hp deskjet constantly says out of paper. As far
Each printer has a sensor that determines when there is no paper, on cheaper printers like deskjets it tries to feed the paper and when it fials it gives this error. The feeder for the printer is most likley bad, replcaement is the most cost effective solution , repairing it would be more then a new unit.
Aug 25, 2009 | HP DeskJet 612c InkJet Printer
Light Blink
if you go on the the hp website you can chat to them live and they will show you how to reset your printer
Mar 09, 2009 | HP Deskjet 2460 InkJet Printer
No pRINT
cartridge is faulty or may be the circuit touching the cartridge surface is not clean.try to clean n reinstall cartridge.or if needed reinstall driver after that.wish u success.
Oct 17, 2007 | HP Deskjet 2360 InkJet Printer
HP DeskJet 1200c InkJet Printer Logo
56 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
