Question about Canon imageRUNNER C3200 Copier
Not scanning I am trouble scanning to the pc. I successfully used the scanner yesterday, however today it is not scanning and is instead printing a sheet of paper with the message 'tx image not set to display'
  • 7 Answers
SOURCE: tx image set not to display
getfile.asp?rid=1258 September 11, 2008
getfile.asp?rid=3215 Product : imagePRESS C1, All Fax Capable imageRUNNER Models Title : Setting the TX Terminal ID print options Question :
What are the options to print the TX Terminal ID on received pages?
Answer :
The TX Terminal ID settings enables you to specify whether the sender information is printed at the top of every document that you send via i-fax. Information such as your i-fax address is printed, enabling the recipient to know who sent the document.
Note: If you set TX Terminal ID to 'On' you can also set the position of the Terminal ID information which is printed on the recipient's paper.
The default settings are:
TX Terminal ID: On
Printing Position: Outside
Display Destination Name: On
1) Press Additional Functions
2) Communications Settings
3) TX Settings under Common Settings.
4) Press the up or down arrow keys until you see TX Terminal ID
5) Select On or Off
If you select ON:
Select the printing position of the Terminal ID information, select 'On' or 'Off' for display Destination name, press OK.
Printing Position:
Inside: The Terminal ID information is printed inside the image area on the recipient's paper.
Outside: The Terminal ID information is printed outside the image area on the recipient's paper.
On: The destination's name registered in the Address Book is displayed in the Terminal ID information.
Off: The destination's name registered in the Address Book is not displayed in the Terminal ID information.
If you select OFF
Press OK
6) Press Done repeatedly until the Send Basic features screen appears.
Canon USA, Inc. Systems & Technical Support Division 1-800-528-2830
Posted on May 05, 2009
  • 117 Answers
SOURCE: HOW TO SCAN THE DOCUMENTS IR4570 TO P.C ????
On the device you want to chose the SCAN option and set it to ONLINE.
You then need an application that does TWAIN scanning and aquire image data. Set your scanner device yo "Canon Color Network Scangear".
A freeware product you can use to test is irfanview
You would otherwise need to do an aquire / TWAIN scan from MS Word or Adobe Acrobat (full/pro) or another software that does TWAIN scanning.
Posted on May 06, 2009
komguy
  • 2306 Answers
SOURCE: Canon MP480- 5011 - Printer Error Has Occurred After Scan/Prt
You need to carefully clean the encoder strip. It's the clear strip behind the carriage that runs all the way from right to left. A damp Q-tip should remove any grease or fingerprints.
Posted on Jul 16, 2009
  • 341 Answers
SOURCE: scanner scans 9.5x11 paper into 3 seperate images
set up the scanner paper size to 9.5 x 11 before scanning
Posted on Mar 28, 2010
SOURCE: Canon MP 270 spooler problems paper jam problems scanning probs
I have had problems with this printer, too. See my Amazon review here:
http://www.amazon.co.uk/product-reviews/B002LVUKL0/ref=cm_cr_dp_hist_1?ie=UTF8&showViewpoints=0&filterBy=addOneStar
(Mine is the second one down).
The Canon MP270 does seem to have a few problems. It's not one of Canon's finest products, to say the least. It seems to be getting a reputation for problems, problems...
I gave up and bought a HP Deskjet printer instead. I know that's not a fix, but I found it was the best solution!
Posted on Aug 05, 2010
I have a mac book and have always successfully been able to print wireless. The scanner however would never work. Yesterday I needed to scan a document so i plugged the printer into my mac and scanned...
Check the settings on the printer to see if you have to switch from scanning to printing, also if you have the original setup disk for the printer just run it again and that will solve the problem.
Mar 19, 2011 | Computers & Internet
I bought an HP Scanjet G4050 as recommended (by John Lewis?s) for use with my new Macbook Pro laptop bought at the same time. This was somewhat over a year ago, and I have used the scanner lightly, but...
Hi there, you are very near in the solution. Just today i solve the same problem manually. When the system ask this message "where I want the image saved " 1st select the path -- My computer/C:/program file/HP scan jet/ select here the Scanner Icon and press Ok. I mean just follow the location of installation file of your scanner. After that scan the image or else , you will get the success. Thanks & waiting for your success feedback.
Feb 18, 2010 | HP Office Equipment & Supplies
Cannot scan
Your printer is bundled with a printer and scanner in 1. But you need to install the two drivers for the device, the Printer driver and the Twain driver or scanner diver. To check if you successfully install the 2 devices, open My Computer Icon if you are using Windows XP or higher, you can see there Imaging devices or the Device name with the scanner icon. If you cant see it, you need to re install the driver, disconnect the USB cord form your PC and reinstall it using the autoplay installation, this installs all the required driver for your device. Plug in the USB of the device if the installer application says Searching for hardware or something, wait until finished.
Oct 21, 2009 | Brother MultiFunction Center MFC-440CN...
I want to use my Minolta biz 163 as a scanner. All print and scan drivers installed successfully. But when I try to scan with Vista's scan program, nothing happens. Program doesn't see 163 as a scanner and...
the easiest way to scan using this device is through the software that shipped with the device, failing that use the camera scanner wizard in Vista to add the device and then you will be able to scan via Twain (technology without an interesting name) if this answers your query and you succesfully manage to print please rate my response accordingly thank you
Aug 25, 2009 | Office Equipment & Supplies
Scanning error - cannot scan error code 2,155,0 ???
i found this while i had the same error msg... apparently its actully the USB cable where its does not suffice
here is the link : http://www.fixyourownprinter.com/forums/printer/49111
Thanks
Sanjieev
Jan 13, 2009 | Office Equipment & Supplies
Re : CanoScan N640P/Lexmark Printing Problem.
There could be a setting in your scanner drivers to fix that. It would be under background settings.
The other thing you can do is preview the document first and select the area you want to scan. Then press the scan button again. That way the black background that isn't needed will not print.
Jul 29, 2008 | Canon CanoScan N640P Flatbed Scanner
Epsom CX7800 Scanner Printer
Windows XP has its own scanning software found within the control panel under scanners and cameras. This appears to provide a more direct method of controlling the scanner because it is part of the OP Sys as opposed to 3rd party scanner software. If the scanner is installed and it appears as an installed option, then try using this approach instead of the actual scanning software.that came with the scanner.
Dec 23, 2007 | Computers & Internet
Canon imageRUNNER C3200 Copier Logo
old marine
old marine
