Question about Emporio Armani AR2022 Watch
Model ar2022 stops working - Emporio Armani AR2022 Watch
I received watch for x mas and Sat 4/2 it stopped wound it and it stopped again 4/4 is it not getting enough light or do I have a bigger issue. Thanks
Eco-drive watches do not need winding or batteries, so if you are winding it to make it work, then it is not a true Eco-drive watch.
Apr 04, 2016 | Citizen Eco-Drive watch
How do i get my emporio armani ar2022 started?
pull the plastic tab off the crown then push crown in
Oct 19, 2014 | Emporio Armani Slim Stainless Steel Mens...
Stopwatch second hand stops/jams at 57 seconds point jamming the whole works. Watch stops. Keeps excellent time otherwise if stopwatch not used. 2003 ss model. Bought new from rolex.
This may sound obvious but it needs to be repaired by a jeweler/watch repair shop. Although it is possible that the stop watch second hand is out of sync it would usually mean that the stop watch is starting at 3 seconds before 00:00 for 57 stop. If that's the case you should be able to readjust the start/stop position by pulling the crown out to 1st or 2nd position and then pressing the stop watch start stop buttons. One press, one position. Although I am not certain of the exact sequence.
However if you are unsure or it starts at the 00:00 position you need to find a jeweler you can trust to do the work. Check out a few places and ask to see the credentials of the watch repair person then compare and make an informed decision. Don't just use the jeweler at purchase point.
Most times, if it's a simple repair, like readjusting the hands a good jeweler will do it for nothing.
Good luck
May 14, 2010 | Rolex Daytona 116520 Wrist Watch
Hi.i just boughta tag heuer grand carrera xx007344.immediately i got home,it stopped working.so,after abit of winding it starta working.but if i just drop for a minute or two,it stops working.even when...
Automatic watches will generally run for 2-3 days before the spring is fully unwound, so you are likely to have bought the watch in the unwound condition.
It can be wound by gently shaking the watch from side to side (for about 100-200 times). This should give it sufficent engergy to operate and thereafter normal use will keep it wound up.
If it stops working when the watch is rotated out of the face up position, then it may be that the watch is faulty. (If the watch has been dropped in transit, it may have been damaged).
If normal operation is not achieved, then send it back to get it repaired under warranty.
May 04, 2010 | Tag Heuer WAF2110.BA0806 Aquaracer...
Wenger field chronograph only works when not in use
Take or send it back to your supplier, with an explanation of the problem.
Feb 06, 2010 | Swiss Army Wenger Sportedge Bracelet Watch
Model JR3XXX/Cal. No. C650. Stop wearing it and
The same thing happened to me. The fix is in the instructions. If you don't have them download them. You will probably need to do a full reset to get it working again then reset the hands to the "0" position so both the analoge and digital times match.
Sep 25, 2009 | Citizen Watches
It stop working, analog and digital
Unfortunately the watch may have been on display for some time and the battery may have run low. If you go back to the place of purchase they should change the battery free of charge. Make sure that you have the watch resealed to manufacturers water resistance rating or you void Sectors warranty. The retailer may also replace the watch with a model in stock but you may have the same issue with display time effecting the battery life.
Sep 17, 2009 | Sector 3251908015 Mountain Master watch
Mens Relic watch stopped working after battry change
I suggest that your watch has an oxidized contacts and electricity can not reach the movement.
Do as folloes:
Take out the batttery,
Clean (scrape) all battery related contacts till they are shiny (use hardened steel needle for that),
Use the dust blower to get rid off any tiny dust and dirt particles after cleaning,
Refit the battery back.
Now your watch should work again.
If all written above do not help, then there is a problem with your watch and you will need the help of the watchmaker.
Do not forget to rate, please.
Feb 09, 2009 | Relic 0504648FA
Timex 1440 sports digital watch time setting
  1. Press and hold the mode button until it starts to blink, then release.
  2. First the alarm time will come up.
  3. Press the mode button once to get to the time and date.
  4. The seconds will flash first.
  5. Press the st/stop button to toggle between the seconds, hour, minutes, date (month and day) and day of the week.
  6. Press the lap/reset button to change the values.
  7. When done, press the mode button again to return to normal.
Mar 09, 2008 | Timex 1440 Nylon watch
Emporio Armani AR2022 Watch Logo
24 people viewed this question
Top Emporio Armani Watches Experts
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you an Emporio Armani Watch Expert? Answer questions, earn points and help others
