Question about Goldstar DH504EL Dehumidifier
Ice build up
I have ice build up inside my dehumifier and no water is collecting in the bucket? I cleaned the screen and replaced it and with 20 minutes ice is building up on the back side. The setting is set at 35 %, same as I have had it for years. please help, my email is friday60@comcast.net
    Sergeant:
    Champion:
  • 214 Answers
I would say you need a humid control on your unit.it may be running more then normal.
Posted on May 08, 2009
AhhMy dehumifier runs but dosen't collect water.
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Aug 31, 2011 | Whirlpool AD50USS Dehumidifier
My dehumifier has an orange light by the picture of the fan. What do I need to do?
Empty the water collection bucket. But, before you do, turn the unit OFF & unplug it.
Jul 12, 2011 | Danby Dehumidifiers
Does not collect water in bucket but runs all the time
Does it have a filter?
http://whirlpool.custhelp.com/app/answers/detail/a_id/953
also:
It may be that the humidity level or temperature in the room where your dehumidifier is located is too low.
When the outdoor temperature is below 50 F, the indoor air will be dry even when the air inside is warm, therefore when it's cold outside the dehumidifier may collect little or no water.
Air conditioners will also remove moisture from the room, even if it's hot and humid outside, resulting in little or no moisture collecting in the dehumidifier bucket.
Some dehumidifiers have a deicer which turns off the compressor but keeps the fan running. When the compressor is off, moisture is not removed from the air. The deicer turns off the compressor when the room temperature is cold.
Some dehumidifiers do not have a deicer. If the room temperature is low enough, ice may form on the evaporator coil. The ice prevents the dehumidifier from removing and collecting water. If ice forms on coils, unplug dehumidifier until ice melts and room temperature rises."
Jun 21, 2011 | Whirlpool AD25BBK Dehumidifier
Sometimes my dehumifier (Goldstar) leaks. It is not full and the collecting bucket is fitted properly. I see that there is a flap around the pipe coming from the coils. Is it possible that this flap is...
Gary, most of the time, what you described is caused by 2 thing:
1. The cooling coils are icing up and not thawing as they should. This is usually caused by a dirty or clogged air intake filter. Solution: Turn the unit OFF, unplug it and remove and clean the air intake filter.
2. The drain hole or tubing, that drains water into the bucket is clogged. Solution: Using an 18" long plastic Zip Tie or something similar that is flexible (NO wire coat hangers, though) and appropriately sized to fit into the hole or tubing. Carefully insert the Zip Tie and continue to push it in, until to reach the bend in the tubing. You must gingerly work it past this bend, until it either bottoms out or you run out of usable Zip Tie. While slowly pulling it out, rotate (twist) the Zip Tie and as it reaches it's end, be prepared for some water to follow. That procedure will loosen any clogs.
Hope this helped you troubleshoot and solve the problem. Please let e know. Thanks.
Jun 15, 2011 | Goldstar Dehumidifiers
I have an ad50 dsr1 whirlpool dehumifier. Has been great for a couple years but now when turned on it instantly trips GFI. After further investigation I found the wires on top of the compressor are...
heatman101
Jun 02, 2011 | Whirlpool AD50DSL Dehumidifier
The dehumifier is running but it isn't taking water from the air. The bucket is empty. Maytag dehumifier Model #m3dh30b2a serial #as750118
The operation a dehumidifier is based on the amount of humidity, the house or room where you have it placed. If the humid level is low and you have the humidifier set on a low extraction setting, there would be little to no water in the bucket. However, if you have all the settings correct and you still don't get water in the bucket, the top 2 reasons for this are: The Filter needs cleaning and # 2 the drain tube or hole is clogged. The solution for cleaning the filter is a no brainer. The solution for unclogging the drain tube or hole is not that difficult. You will need a 12" to 20" long Plastic Zip Tie (or something similar, but no wire coat hangers), that's small enough to go through the drain tube or hole. When you remove the bucket look up and into the compartment that the bucket came out of and you will see the drain tube or drain hole. Slowly and carefully push the zip tie into the hole and continue to work it into the hole until you reach the curve in the tubing. This is the tricky part. Carefully and gently work it past the curve and about 4" more. Then start removing the Zip Tie as you slowly rotate it. This will dislodge any clogs. As you continue to pull it out, be prepared for water to follow it. If you have water draining out, your problem is solved.
If none of the above solved your problem, the condenser unit may be low on refrigerant. In which case, you will need a pro to service it.
Hope this information helps to solve the problem.
Mar 17, 2011 | Maytag M3DH30B2A Dehumidifier
My DeLonghi DE500P dehumifier whch I purchased last fall is no longer collecting water. Everything seems to be functioning as outlined in the instructions. The rooms humidity is about 55%. Any ideas?
heatman101
Feb 07, 2011 | DeLonghi DH40P Dehumidifier
Dehumdifier not collecting water.
The filter (on some models) may be dirty or clogged. If so, clean the filter. For instructions on cleaning the filter.
I hope this help to solve, if this answer solve it, remember to rate it. Good luck.
Oct 01, 2010 | Whirlpool AD50USL Dehumidifier
Fan works but not the dehumifying part
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Sep 03, 2010 | Kenmore 54501 Dehumidifier
The dehumidifier runs until it is hot to touch on the back. But no water is collecting.
It may be building up with ice. If you turn it off does any ice melt into the bucket?
Aug 31, 2009 | Dehumidifiers
Goldstar DH504EL Dehumidifier Logo
381 people viewed this question
Top Goldstar Dehumidifiers Experts
Gil Shultz
Jerry Greenberg
Jerry Greenberg
Dan Webster
Dan Webster
Are you a Goldstar Dehumidifier Expert? Answer questions, earn points and help others
