Question about Gaggia Syncrony Compact Coffee Maker/Espresso Machine
No steam when valve opened, spits out water in the beginning of frothing
I have been using my Gaggia Compact Digital for about 2 years and it worked well until now. The frothing suddenly stopped working. When turning the valve open it "spits out" the water but then it sounds like it is pumping inside, however, no steam and only a little water comes out. What can be do to fix it? This happened overnight because it frothed the milk just fine the other night.
    President:
  • 1,618 Answers
There is a small teflon piece on the inside of the steam tube, you will have to disassemble the frother to get to it. Remove this piece. Reassemble and the wand should work fine.
Posted on May 11, 2009
My Gaggia classic has suddenly stopped frothing
Hi There,
You are not getting enough steam, to produce the froth and there no blockage. I suggest you replace the thermostats. Takes 10 min max.. Gaggia thermostat set
Sep 28, 2017 | Gaggia Classic Espresso Machine
Hi My gaggia titanium is not frothing milk correctly. I've descents but that has still not solved the problem It's sounds like it's spitting Thanks
Try this remove the parnello wand and open the valve if you get a nice burst of steam then the problem is in the parnello wand, if you get the same spitting, then there is something in the valve or the steam boiler that is preventing the proper flow of steam.
Jan 02, 2011 | Gaggia Titanium Espresso Machine
My steam function more water than steam comes out. Yhe thermostat is turning on and off but when you open the steam valve you end up with more water than steam??? To froth the milk i have to do 4...
Replace the thermostat for the steamvalve, it is not keeping the element on long enough or you need to descale boiler because there is not enough room for water.
Jan 30, 2010 | Gaggia Classic Espresso Machine
I have a Gaggia Syncrony Compact Digital, almost 2 years old, recently the digital display has been fading and today once i turn the steamer off, it still steams at a slow pace and evenutally it stoped,...
The steam valve has been leaking on the inside for awhile, the steam condensed on the display board. You will have to replace the steam valve assembly and maybe the display board.
Jan 20, 2010 | Gaggia Syncrony Compact Digital Espresso...
I have a Gaggia Synchrony compact. I recently decalsified it and it stopped working. The low water light is on and nothing works except, for the water pump. It will flow only cold water through the steam...
If it leaks from the steam wand then you need to get a new steam valve assembly. For the heat you will have to open the machine it is possible that the steam boiler is damaged or that the thermostat on there is bad, use an ohmsmeter to check thermostats and element. There are 2 screws in the grinder, 2 behind the water tank and about 2 or 3 in the front behind the door.
Jun 09, 2009 | Gaggia Syncrony Compact Coffee...
Water is leaking, while the machine heats water for steaming
The steam valve tap rod needs to be replaced, or check machine if it has a plastic steam valve, Gaggia designed a new Stainless steel steam valve for the compact machine.
May 23, 2009 | Gaggia Syncrony Compact Coffee...
Steam wand works, but no water for espresso
I have found that I have to remove the group valve assembly about once every 1 or 2 months to clean out the .030" to .040" opening in the valve body. The manual gives instructions on how to do this. It becomes clogged with a thick paste like substance.
Jan 24, 2009 | Gaggia Carezza Espresso Machine
Gaggia Synchrony Compact Digital Problem
I think you have get air in the system, try to find a bellows pump or similary. Fill it with water, open the steam knob and take of the water tank, put the pump in the water inlet and press. When the water begins to flow, close the steam knob and put the water tank back.
Best regards
/Mirran
Nov 01, 2008 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
Machine is leaking
the valve is available at partsguru.com in the US
Apr 16, 2008 | Gaggia Syncrony Compact Coffee...
Gaggia Coffee
Hello, I have been experienceing the same problem since I bought this thing. I used to have the classic Gaggia until it died after 15 years. however, when I went to this one it just didn't function the same.I was having water leaks come from the group assy so I replaced the group valve assy which I saw a diffrence and it functioned properly for a few days, then It was acting up again. No steam to froth and water bypassing the group assy... I then removed the valve assy again and saw it was somewhat clogged of mineral deposits.I cleaned it and after a few days once again it wasn't frothing as it should. Yesterday I completely tore this thing apart but couldn't figure out how to remove the steam valve assy. Does anyone have any ideas?? I removed the 2 screws and it won't move. OH BEFORE I FORGET!!! It was working fine the other day and while I was in the middle of frothing, it suddenly went to half pressure.... ANY IDEAS?? Thank you in advance....
Apr 09, 2007 | Gaggia Coffee In White, White MDF...
Gaggia Syncrony Compact Coffee Maker/Espresso Machine Logo
299 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
