Question about Systat SigmaPlot 9.0 (000053608314) for PC
How to solve the error 1324 while installing Systat Sigmaplot 11
Sigmaplot 9 will not run with windows 7
1. Click the RIGHT mouse button on the icon for "SIGMAPLOT 9"
2. On the menu that appears click "PROPERTIES" with the left mouse button. This will give you a properties window.
3. Click on the "COMPATIBILITY" tab at the top right of the properties window with the left mouse button.
4. Tick the box "RUN THIS PROGRAM IN COMPATIBILITY MODE FOR:"
5. Click the drop down arrow and select the version of windows it ran in before or try "Windows XP Service Pack 3" and click APPLY.
If that doesn't solve the problem repeat steps 1 to 4 and this time select windows 2000. This should solve the problem.
Apr 20, 2012 | Systat SigmaPlot 9.0 (000053608314) for PC
Installation ended prematurely because of an error
I was also having the same problem previously. It is happening due to somehow the some sigmaplot versions could not find the correct path/permissions.
I have solved this problem by 1. open command prompt with administrative permissions.
2. go to sigmaplot package directory
3. type the name of installer /a. the switch /a results in network installation. choose a directory different than the c:\program files.
I choose D:\sigmaplot
install
go to the installation folder and open spw
update your license as received from the company or visit their website for trial license.
solved mine. later i added the shortcut to start menu.
Jan 10, 2012 | Computers & Internet
Sound Device not found! I just installed a new Xp Fresh Copy, but it seems like my Sound Doesnt work, I think its RTM866-845 .. Any help?
you will have to download the drivers for your soundcard.
And you can go to control panel, then device manager. Make sure the soundcard is enabled and drivers are up to date.
Jul 05, 2009 | Systat SigmaPlot 9.0 (000053608314) for PC
I have to download sigmaplot 9.0 pls tell me how to download?
It can't be downloaded, you can only purchase CD ROM at store
Jun 25, 2009 | Systat SigmaPlot 9.0 (000053608314) for PC
I just had my dell inspiron worked on by a pro to remove a bunch of nastys. Now, I have no sound and the computer says I have no audio output device when I click on the speaker icon. whats going on?
Most likely this "pro" formatted your computer
and did not install the Device drivers for you pc.
easy way to fix: You are going to need another pc with internet access and go to http://support.dell.com/support/index.aspx?~ck=pn
then go to drivers and downloads, type in your service tag number, download all the drivers, copy them to a disk(USB drive, CD, etc) and install them on the dell.
SigmaPlot won't open
hi go to my computer manager .. and go to service and .. there you can all service start from there sigmaplot service
thnx
May 12, 2009 | Computers & Internet
Sigmaplot graphing problem!
its a virus my dear,, or its a corrupted Windows XP?? can i ask u?? you are installing an original windows XP? or it is an imitation? in order for me to know the system file?
Nov 20, 2008 | Systat SigmaPlot 9.0 (000053608314) for PC
Get error 1324 while installing robohelp 6.0
Ran into the same problem some time back.
This has the solution:
http://www.pcauthorities.com/pc-maintenance/uninstaller/how-to-solve-uninstall-errors
Jules
Aug 15, 2008 | Computers & Internet
Computers & Internet Logo
186 people viewed this question
Top Systat Computers & Internet Experts
David Payne
David Payne
Are you a Systat Computer and Internet Expert? Answer questions, earn points and help others
