Question about Transcend StoreJet Computers & Internet
TRANSCEND STOREJET HAS NO BLUE LIGHT COMING ON WHEN PLUGGED INTO PC
  • 81 Answers
SOURCE: transcend storejet 25 mobile is not recognised
if your unit only uses one cord ( USB ) for data and
power , the unit side may be damaged , the life span
of the USB hubs and the cords that use them are not known sometimes for no reason whatsoever they stop
working , and is the most common reason for hard
ware to malfunction , and it is possible to replace
the outer closure , remove the HDD you can find
a suitable replacement closure at radio shack for
40$ that allows you to hook up a 2.5 SATA HDD
to any computer Gigaware makes a very nice
portable model , if the HDD works then you have
just trouble shot the closure to the HDD .
Posted on Jan 28, 2010
  • 104 Answers
SOURCE: MAC unable to read this storejet device
The format of your external drive is most likely NTFS which is used by Vista and Windows 7. At best the latest OS X can only read NTFS format with care..
You best bet is to put the data on dvd - r or (i prefer for DVD archiving) + r since you'll be able to port that to anywhere. Alternatively, after saving the data to an interim PC, reformat to FAT. Note FAT can only address 32 GB. so you might need to divide it into multiple partitions.
I hope this helps or you found out differently.
Posted on Mar 28, 2010
  • 10406 Answers
SOURCE: My Transcend external HDD (Storejet)
The "My Pictures" folder is a "child" folder of the "My Documents" folder.
Is there an option to "include sub-folders" when using the software to perform the backup?
Posted on Nov 04, 2010
dw24_uk
  • 97 Answers
SOURCE: my borrowed transcend storejet 320GB would not
the usb ports on your laptop may have insufficient power to operate the drive, you could try a double usb cable, it has a mini usb at one end and two normal usb at the other, so it shares the power from two ports.
Posted on Jan 18, 2011
  • 32 Answers
SOURCE: how to remove write protection my
try right clicking and going to the properties and and reset the permissions of the drive. some times the user account will be write protected and the default hidden admin account will have full access.
Posted on Feb 28, 2011
My wife used her laptop power cable for Transcend 3TB StoreJet 35T3. In result it doesn't work - I can see the blue light trembling, but the drive is not recognized. I believe that the HDD itself is Ok,...
The on board controller is most likely fried. It is not cost effective to repair. You can remove the drive itself from the enclosure, install it in a desktop PC and recover the files as long as the power surge did not damage the drive as well.
Dec 19, 2014 | Transcend "Ts2Tsj35T - Storejet 35 Turbo 2...
How can I retrieve saved data from my Transcend 2.5 StoreJet Portable HDD
Remove the drive and connect it to a known good USB adapter. If it still won't be recognised, buy a new drive. Sorry.
Jul 19, 2014 | Transcend 1TB 2.5 Inch StoreJet Mobile H2...
The driver switches on the blue light and run for about 10 seconds then stops and it cant be recorgnized by the pc, whats the matter please help i only have 3 months using it. my email address is...
Did you tried running it on other PC ? If it works on other PC then Try removing you USB drivers, restart your PC. and Insert your driver again.
If it doesn't, then try using other DATA cable.
Oct 08, 2013 | Transcend Information Transcend StoreJet...
My external hdd transcend 320 gb storejet is very slow while copying file to or from the hd and the blue LED keeps on blinking what might be the problem??
Well u may have it plugged in USB slot but needs to be USB 2.0 .if in regular. USB..will run slow...also external he'd when u not using. It unplug. From USB and AC plug...not good to just let run..they will were out..defrGment hdd to.good luck
Dec 21, 2011 | Transcend StoreJet 320 GB USB 20 Hard...
I have Transcend 1TB 25 inch StoreJet H2 USB 20 Portable Hard Drive... not long enough, it's broken; there's a sound "clutch - clutch - clutch"... I cries for my valuable data... Why...
Inside the plastic case of the Transcend StoreJet H2 1TB, is a small circuit board, and a laptop size harddrive.
The small circuit board is an Interface Board.
The harddrive plugs into it, or there are cables which come from the Interface Board, and plug into the harddrive.
The other end of the Interface Board has a USB cable attached to it.
Most of the time it is this small circuit board that fails. Very rarely does the harddrive fail.
(Unless the external harddrive was dropped)
I would suggest removing the harddrive from the Transcend, and putting it into an inexpensive external enclosure.
One example,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3195233&CatId=2783
Basic guide on how to open the case of the Transcend StoreJet H2 1TB
http://www.youtube.com/watch?v=GvGP6C-rH2U
There are other related videos to the right.
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 10, 2011 | Transcend 1TB 25 inch StoreJet H2 USB 20...
Describe your Transcend StoreJet 2.5 (TS120GSJ25T) 120 GB USB 2.0 Hard Drive Problem
I have Problem with the Transcend StoreJet 2.5 120 GB USB 2.0 Hard Drive.
I didnot register it on line.in time i was presented this nice device..
because it was working ok .when i just connect it to LapTop.
NOW..After almost 2 years .it s became not RECOGNISED BY MY pc.
And i cant find any driver for it.I have all my important documents in Transcend.
WHat can i do.friends.. Any help?
Please help old Lady.
Thanks if responded.
dearme9@yahoo.com is my mail and this is banner i see.
Jul 26, 2011 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
My Transcend StoreJet 500GB harddisk is not being detected on my Mac. The blue light keeps flashing.
If you are using the USB "Y" cable that has two male ends on one side then ditch it and try a regular usb cable. Regular being a cable that is USB to USB mini, one that as short as possible e.g. 36 inches or less. This solution is what solved my problem, so simple :)
May 30, 2011 | Transcend StoreJet 25 Mobile 500GB USB 20...
Hi.. i need help.. my external hdd transcend store jet 320gb have problem... when I conect HDD to pc blue led blink just one time and hdd stop working..
Check that the USB cable can provide enough power to the hdd. Check that the USB port is powered. Older USB slots may not have enough power to run larger external HDDs, there you may require separate power to be plugged into the hdd. Are you using the original USB cable provided with the external HDD?
Feb 28, 2011 | Transcend StoreJet 320 GB USB 20 Hard...
Computers & Internet Logo
16 people viewed this question
Top Transcend Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Josh Whitehead
Josh Whitehead
Are you a Transcend Computer and Internet Expert? Answer questions, earn points and help others
