Question about Korg X5d
Korg x5d no sound - Korg X5d
5 Suggested Answers
deeric27894
  • 167 Answers
SOURCE: Hi. My Korg X5d shows a sequence of small squares
You need a reprogramming done from the Maker . Contact Authorized Korg Service center . Be away from frauds.
Posted on Nov 18, 2010
dr_mosh
  • 41 Answers
SOURCE: Hi, my korg X5D have
The pitch and modulation wheels are on a separate circuit board, if they both stopped working at the same time, it's likely the connecting cable has dislodged.
Opening an X5(D) is relatively simple and you should be able to simply plug the cable back in. If you're not comfortable doing that, take it to a shop.
Posted on Jun 12, 2011
dr_mosh
  • 41 Answers
SOURCE: how to turn on en
For Combi/Multi patches you can disable control changes for each sound under EDIT 6D but this also switches off other control change instructions (pan, expression, pedal etc.).
Somewhere under GLOBAL settings you should be able to find the modulation wheel Depth setting and set it to 0 which should stop your mod wheel from working but you could achieve the same effect by just keeping the mod wheel pulled all the way down.
Posted on Jul 28, 2011
Testimonial: "thank you 4 your insrtuction"
dr_mosh
  • 41 Answers
SOURCE: Hello my Korg X5D on switching on shows
There's a watch type battery (flat disc) on one of the boards inside the X5D. This maintains the settings while the keyboard is switched off and could be the whole problem.
The keys are on two different circuit boards connected with a multi-pin cable. If the cable were dislodged I would expect it to simply cut off half the keys but it's probably worth checking.
Posted on Nov 20, 2011
When i star or on my korg x5d the display are just like cherismas light it does not finishe inistalation and logo of korg x5d then it will be empity lignht scren
How to Initialize (reset), and preload on the Korg X5/X5D/DR Initialization: Hold Page + and Page - while turning it on.
Preload: Global Screen 5A, then select "OK".
ROM Check: Hold Edit and Global/Multi while turning it on.
Apr 17, 2016 | Korg Music
My X5d displayed "05 31 1995" then stopped functioning..what shall i do?
That sounds like a manufacture date being flashed. Have you checked the battery? If you can't backup first, all your changes (custom sounds) will be lost, but that might be what you are looking at. Replace the battery, or have a service center do so. You'll want to reset after.
Try ROM check first.
Guide:
How to Initialize reset and preload on the Korg X5 X5D DR SweetCare
Jul 11, 2014 | Korg X5d
How to save x5d sounds in laptop
if you do not already use a midi sequencing software try "Bome's SendFX". After installing, go to X5D menu 04A MIDI DUMP, choose data you want do dump (e.g. "all"). Make sure, that no SYSEX FIlter is active while working with a sequencing software.
After transmission, you can save the "yoursounds.mid" file and send it back to the X5D later.
Apr 19, 2014 | Korg X5d
How can i have dual voice on x5d korg? I lke piano and strings
Just go to COMBI mode.
Press PAGE+. The display may look like this :dual-voice-x5d-korg-lke-piano-strings-v3bkdlfzxxldunukh1pdnvp1-3-1.jpg
In the example above, A03 and A49 is a sound PROGRAM number.
OFF and OFF is a Layer 3 and 4, were not activated.
So in our example, we only activate two voices (two layers).
X5D can combine up to 8 voice. To view the Layer 5-8, press PAGE +.
To change the sound of your choice, move the cursor to the corresponding layer, use this button:
then change the value with the slider / value key (YES and NO):
You can also set the level of each layer.
Press PAGE + until a menu appears LEVEL.
Move the cursor and sets its value
May 30, 2013 | Music
Where can i buy to korg x5d main board
Check the output socket for corrosion, this would stop the sound from getting to the amp. Plug in an output cable and wiggle it around to see if it works intermittently. Plug it in and out a few times and see. We are looking for a dirty connection.
Feb 28, 2013 | Music
Hello my Korg X5D on switching on shows 00:Initcombi0 on top display and "battery low" blinks on lower display, Keys from 33-40 are malfunctioning ( giving odd sound) other keys are working...
Oct 30, 2011 | Korg X5d
How to turn on en off the moulation of a korg x5d
Jul 28, 2011 | Korg X5d
My korg x5 keyboard only turns on but nothing comes out of the display.nothing is loaded and no characters displayed.
Download the owners manual from here and try doing a reset to factory settings
http://www.korguksupport.co.uk/page.cfm?pageid=391#Owners Manuals
Feb 18, 2011 | Korg X5d
Hi. My Korg X5d shows a sequence of small squares in the display panel and will not boot. Can you help?
Nov 18, 2010 | Korg X5d
Korg X5d Logo
Top Korg Music Experts
Michial Gueffroy
Wbix
Are you a Korg Music Expert? Answer questions, earn points and help others
