Question about Zyxel Computers & Internet
How do i reset my zyxel pk500z router?
Reboot
I donot remambar password
Most default user credentials are - admin/admin.
If you are unable to log in, then most routers come with a reset key. For Zyxel NGB-417N router, press the reset key with a pin. hold on the pin till the device reboots.
Login with the default user id and password and setup the router.
Sep 30, 2013 | Zyxel NBG-417N Wireless Router
I have a zyxel pk5001z router and when i try to connect a wireless device to it i get a message that tells me the password is incorrect. any suggestions
GENERAL ROUTERS RESETING 1-With the unit on, place a paper clip into the hole on the back of the unit labeled Reset.
2-Hold paper clip down for 10 seconds and release.
3-The unit will reboot on its own. Once the WLAN light stops blinking, the unit is reset.
Resetting the router does not reset the firmware to an earlier version. It will change all settings back to factory defaults
Apr 07, 2013 | Zyxel Computers & Internet
My password is forgot how to change the password
This process will reset the password to the default BUT it will wipe out ALL settings.
With the router powered on:
Get a paperclip and straighten it.
Locate the pinhole at the back of the router.
Gently put the paperclip into the reset hole and keep it pressed for 5 seconds or more.
The router will reboot and the userid will be admin, password 1234
Jul 26, 2011 | Zyxel (91-004-361002) Wireless Router
Zyxel NBG4115 disconnects quite often. Reboot of the router helps.
This kind of routers are, usualy, very sensitive to change in the flux of power. If you plug this router to a decent UPS should fix your problem.
Feb 28, 2011 | Zyxel (91-004-361002) Wireless Router
I dont know ho to change the password on the PK5000Z Wireless Router
I just set up my new ZyXEL PK500Z, so happen to know this answer. In the ZyXEL Qwest Modem Configuration (launch 192.168.0.1), select Wireless Setup, then Wireless Security. Scroll down to Enter Security Key/Passphrase. Unless you changed this, Use Default is selected. If you want to use a password of your own creation, select Use Custom, then enter the password you want. Finish with Apply. Everything connected to your network will be prompted to re-enter the password. Is this what you were after?
Dec 25, 2010 | Zyxel (91-004-361002) Wireless Router
I need router configuration password for Zyxel P-660H-D1 modem
Download a userguide from http://us.zyxel.com/Support/Download-Library-Result.aspx?mif=20050726121025
I think the password is 1234 for admin mode
Aug 01, 2010 | Zyxel Prestige 660H Router
Ever since we have put the fire wall in last week we have to keep rebooting the firewall to get internet connection.
Are all computers experiencing this problem?
Please do a hard reset with the router, then try again. If the same problem happens, reflash the firmware of the router.
Sep 15, 2009 | Zyxel P320W 802.11G Wireless Firewall...
I wish to restore the factory settings for my Zyxel router
You may call on 1-800-585-2494 toll free for support on zyxel support.
Dec 31, 2008 | Zyxel Prestige 334 Router
Reset problem, router won't start again
If the powerlight flashes the entire time.. even after a hardreset, your router is probably only good for a brick....
Dec 20, 2007 | Zyxel P660HW-D1 Router
Computers & Internet Logo
16 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
