Question about Nortel Networks T7316E NT8B27JAAA CHARCOAL MULTI LINE TELEPHONE
"No Free lines" status showing
Our phone is saying "No Free Lines" whenever I try make an external call. How do I fix this because all the lines are free?
3 Suggested Answers
SOURCE: Following conference call two of my five lines are
You may have to reboot the system. apparently the system was not set up correctly. By default the system has a setting for the lines of "supervised or unsupervised (i forget which) when it is set incorrectly, calls do not release as they should upon completion.
Posted on Jun 25, 2009
cnavarro
  • 2460 Answers
SOURCE: line # 3 lit
You're close. Unplug the cabinet. The quickest way to reset a system is to unplug it and start over. You probably have it tied to another phone through conferencing.
Carl
Posted on Nov 01, 2010
One day able to attach external drive/disk via USB port - next day unable to reconnect - Computer properties did NOT show EXTERNAL drive at any PORT
Whenever you use coaxial or phone lines make sure to use a surge protector power bar. They have a thermistor in them to blow up and protect your equipment. I'd say you have blown a diode or ic that supplies power and converts data from the usbs. It may just be one of your voltage wires from your power supply.
Nov 18, 2013 | 2wire PC Port Phoneline HomePNA 10Mbps USB...
Please help! My mothers computer started to have horizontal lines all across the screen, she powered it down and back on. This seemed to work for a moment and then the lines came back and now the screen...
Connect to a External monitor to verify the Graphics Adapter. If the problem/lines show on the External monitor it may be the Graphics Adapter is going bad. You didn't post the Make, Model of Laptop or the OS you are using? Boot to Safe Mode, do you still see the lines? Make sure the Laptop is free of dust. Clean with Compressed Air if necessary. Have you done ALL your Windows and Laptop Manufacturer's Updates. It sounds like a bad Graphics Adapter.
Mar 28, 2013 | Computers & Internet
We used to have a guy come in whenever we had phone problems but he retired. One of my co-workers somehow tried to transfer a person to one of our other locations but in the process have put lines 1 and 5...
When you transfer a call from the outside to an outside place, it will use two external lines for the duration of the call. Sounds like there the PBX is not configured for "disconnect supervision," (DS) meaning that it can't detect when the call finished on either side, so it holds those lines in use. Even if you set DS up on the PBX, the telephone company be sure the lines are programmed for COD (clear on disconnect).
If you do external transfers, you need to set up disconnect supervision on the PBX and COD from the telephone company.
This will probably involve the services of a professional, unless you are comfortable navigating the
internal menus of the PBX.
You can clear the lines by disconnecting the amphenol connector for the outside lines for a few seconds and reconnecting it (which will disconnect all outbound calls) or by rebooting the PBX.
Mar 21, 2011 | NorStar M7310 Corded Phone
Adding line to m7310
Programming is done on 7310, 7324 and 7316 type sets.
Enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow).
The display should now ask for an extension number. Enter extension number you want to change the line appearance on.
Press the show key (top right arrow)
The display should say Line Access.
The display should say Line Assignment
The display should ask for a line number
Depending on the version of system the line numbers can be lines 001-004, 025-028, 049-052 or 001-004, 031-034, 061-064.
The easier thing for you to do is to press the list soft key then the next key (bottom right arrow).
this will tell the line order and if the line is assigned to appear & ring or not.
Press the change key to change the status of the line on your set from unassigned to appear& ring on lines 001,002,003,004,and either 005,025 or 031 for line 5.
press the Rls key when finished
Jan 29, 2010 | NorStar M7310 Phone
M7208 phone help
Jan 28, 2010 | Nortel Meridian M7208 Corded Phone
Screen blurry
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free worldwide, and may also include free shipping both ways (free shipping varies with countries). This is regardless of your camera's warranty status. Please check this link for more info.
Applicable cameras include: A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/V3/300/400/430/500/II/IIs, IXY Digital 200a/300a/320/400/450/500/30/30a
Jan 12, 2010 | Canon PowerShot S500 IXUS 500 Digital...
Polycom SoundPoint 550-Only Showing 1 line
On the phone, press the menu button, then status, then IP status or whatever and get the phone's IP address. Write the ip address down. On your computer, open up a web browser and input the phone's IP address into the address bar and press enter. This should arrive you at the web gui for that phone. It'll probably ask you for login credentials; by default, the name is "Polycom" (yes , it is case-sensetive) and the password is 456. Once you are logged in, you should see several links like "General" "Network" "Sip" and "Lines". click on Lines. under "line 1", you will see the configuration for that line. simply duplicate the entries for lines 2, 3, and 4.
Jul 29, 2009 | Polycom SoundPoint IP 550 IP Phone
Line Redirection / No answer transfer
Nortel Networks is intentionally deceitful in their manual (forcing you to call them for assistance that you must pay for). While they say to use Feature 84/Line Direction for calls to an external line, this will not work. (Even when the phone tells you that all calls have been redirected.) Rather, use Feature 4/Call Forward. In the manual it says this is for other lines within the system, but it will work for an external line.
Nov 07, 2008 | NorStar M7310 Corded Phone
How do i turn the ringer on my M7310 when external calls come in.
No where have I seen this documented in the Norstar Manual. Follow these steps:
Feature **266344
PW: 266344 (note that this is different pw than provided in manuals)
Terminal Sets- press top right button
Enter the extension to which you want to turn the ringer off
Press the top right button again three times until "Show Line" appears. Starting w/ the first line you want to turn off, enter the line and then "change" the status to "appear only", scan through your remaining lines and do the same steps. Remember to do all of the lines in your trunk.
Mar 14, 2008 | NorStar M7310 Corded Phone
Nortel Networks T7316E NT8B27JAAA CHARCOAL MULTI LINE TELEPHONE Logo
371 people viewed this question
Top Nortel Lands Phones Experts
george  peters
george peters
dan4261
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Nortel Lands Phone Expert? Answer questions, earn points and help others
