Question about Whirlpool Microwave Ovens
Should the fan continue to run on my new whirlpool micro oveev
En after cooking time is completed?
    Top Expert:
  • Whirlpool Master
  • 12,223 Answers
Yes the FAN will continuosly until the cycle is END.
God bless you
Posted on Nov 27, 2013
MicrowaveSvc
  • 9047 Answers
SOURCE: KitchenAid KCMC155J
Sounds like a classic bad door switch or switch holder. If you or a friend decide to work on it, we have *critical* safety info, info on door switch testing and replacement, and oven disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your base model number (without the suffix) here: http://tinyurl.com/gv383
Posted on Mar 11, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: Sharp 1611
Quite often this is due to a bad door switch. Opening the door while cooking (without first hitting the STOP pad) is the primary cause of door switch failure.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
We also have the complete service manual for this model at our site.
Posted on Oct 13, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: Fan continues to run when I open the door.
It may be a door switch problem (see this file) or a stuck fan relay on the control circuit board, which we can repair for $39.95 in most cases.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Posted on May 28, 2010
miket756
  • 2702 Answers
SOURCE: Occassionally (about 5% of the time) the microwave
sounds like the program bord is faulty,, when your finished cooking leave the door open a little that will save the microwave from trying to cook nothing?
Posted on Aug 28, 2010
  • 78 Answers
SOURCE: no mater time salected only cooks for 17 seconds
i think you have a problem with your magnetron or the inverterpcb if your unit has inverter inside writen on the front it could be an expensive repair please contact me to let me know iffell up to tackling this repair as it can be dangerous
Posted on Dec 11, 2012
Mmv5165bas vent fan will not stop running
Check to see if there's a relay providing power to the fan. If there is, the contacts might be sticking in the closed position. Assuming that this is an over-the-range unit, disconnecting the vent fan completely might not be a good idea as heat/steam from foods cooking on the range would more likely damage the microwave.
Apr 29, 2014 | Microwave Ovens
The light and fan continue to run after cooking.
open the microwave cover & check micro switch attached with door lever.it may be displaced or damged. replace it
Apr 25, 2014 | Samsung SMH9187 Microwave Oven
Kenmore model 721 850 the cooling fan doesn't run all the time
This could be due to a intermittent micro switch, or a faulty cooling fan. This is critical in keeping the magnetron cool when cooking.
Apr 04, 2012 | Kenmore Microwave Ovens
Maytag microwave MMV4205BAW interior fan continues to run when door is closed
One of the micro switches has malfunctioned, and must be replaced for normal operation.
Apr 02, 2012 | Maytag Microwave Ovens
The vent fan on my over the range Whirlpool microwave (mh1150xmq-0) runs any time I use the microwave (as if I have turned the vent fan on "low"). This doesn't seem to affect cooking, but it...
You either have a shorted exhaust fan thermostat or a shorted fan relay on the control circuit board.
While we regularly repair these controllers by mail for $39.95 postpaid with a one-year guarantee, or you can order a new control circuit board (part number) from the Pros here, we strongly suggest that you or someone you know check the exhaust fan thermostat first.
It should read "open" on a continuity (ohms) test. If it reads closed (shorted) it is bad and the fan will run all the time.
Or you can simply unplug the oven's power, disconnect one lead from the thermostat, tape it over to prevent shorting, then plug the oven back in. If the fan still comes on, the problem is on the board. If it does not, the thermostat is shorted.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Oct 14, 2011 | Whirlpool MH1150XMQ Microwave Oven
I have a GE Profile Spacemaker model JVM1660SB005, maufactured in November 2000. I attempted to change a burned out bulb on the left side. I did not check the manual to see how to remove the bulb, nor...
I regularly see (and repair) this light and / or fan failure on model JVM1660SB005 and most any model of over the range microwave.
The problem is on the controller assembly, which I regularly repair very affordably.
At my Web site, you can get details, plus I have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
For more free DIY and other help & advice, feel free to contact me via my site.
Please include FULL model number*, FCC ID number*, + detailed symptom information. ( * on the tag in cooking cavity or around door frame or control frame or on back)
http://www.microwavecontrol.com
"Recycling by repairing since 1982"
Mar 05, 2017 | GE Microwave Ovens
Mar 05, 2017 | GE Spacemaker JVM1640SJ Microwave Oven
Occassionally (about 5% of the time) the microwave continues to cook and buzz after the timer has run out and the fan stops running.
Aug 28, 2010 | Whirlpool GT4175S Microwave Oven
Microwave still continues after cooking time is ended
It is the fan. Im guessing it only happens on combination cook and not when you are only using the microwave setting. It happens because the oven is hot and it helps to cool it quicker. It is normal. The microwaves are not working and neither is the oven-just the fan.
Mar 31, 2009 | Oster 0.7 Cu. Ft. Compact Microwave
Lights up BUT does not cook
was there any motor that should run as you turn it on, the fan inside and the rotating table motor. try to replace that micro switch at the door that bubbled out and burnt. try to test or replaced right away the industrial diode that is connected from the capacitor to the ground of the microwave.
Feb 17, 2008 | Panasonic NN-S763BF Microwave Oven
Microwave Ovens Logo
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jaime Hernandez
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
