Question about AMI - All Sales MFG 1998 Chevy C/K Pickup 1500 AMI Billet Aluminum Interior Dash Knobs
4.3 chev truck /want start unless you pour gas in trottle body
If you put about 20 drops of gas in throttle body it will fireup if you let it set for about one hour you will have to put more gas to start again
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 42 Answers
Well, are the fuel injectors not working? I dont mean clogged, I mean not functioning. They recieve a signal from a solenoid. If the solenoid fails then no fuel injection. OR Check ECM B fuse 20Amp and make certain it isn't blown.
Then go to the underhood power center and find the relay marked fuel pump relay and give it a light tap, if it starts, replace the relay.
It is very common for the fuel pump relay to fail.
Posted on Nov 27, 2013
Car not starting in morning
It sounds as though you are imitating a cold start injector by pouring fuel into intake. I would start there
Aug 03, 2014 | 2003 Pontiac Grand Am
1988 chevy S10 turns over but won't start getting spark put in new fuel pump,cpu and injector. If I pour A little gas in throttle body hole it will fire for a few sec. fueses all test good.
Hello, just had this problem myself. Check your EGR valve by pulling the vacume line off and pushing up under the valve put your finger over the vacume line hole and release the valve, if it returns to normal position then its bad if not its good. If its bad it needs replaced. Mine did the exact same thing and thats what it was. Hope this helps
Jan 20, 2013 | 1988 Chevrolet S-10
My 1985 grand Marquis won't start I can pour gas
Take the gas filter off. Should be located near the front of the carbeurator, take off the air cleaner and look for it, it takes 2 wrenches to take it off, a little gas may spill out but not much and replace it, however there is a strong possibility that he gas pump is out if the filter is fine. Hope this helps
Jul 11, 2012 | Cars & Trucks
Ran out of gas how do i restart car after putting one gal of gas in tank 1998LS 400
take lose the hose running to air filter or take the hose loose from the throttle body and pour you a little gas in to the throttle body put the hose back on and try to start it,it should start
Jan 10, 2012 | 1998 Lexus LS 400
I have a 92 chevy c1500,new fuel pump and filter but truck is hard 2 start.if i pour gas in throttle body bowl it starts right up. what could b the problem?
Sounds like the injector is not supplying the proper amount of fuel. Try unpluging the TPS first and then the IAC motor, both located on the trottle body.
Aug 30, 2011 | 1992 Chevrolet C1500
99 Durango will not start. It is getting fuel and spark. Poured small amount of fuel in trottle body and it will start, and then die when that fuel runs out.
If you have to put fuel in the throttle body to get it to start then its not getting fuel from the gas tank, a clogged fuel filter can cause this problem as can a failing fuel pump or pump relay.
May 29, 2011 | Dodge Durango Cars & Trucks
Fuel delivery s10 blazer
Did you change the fuel filter?
Mar 25, 2009 | 2000 Chevrolet Blazer
AMI - All Sales MFG 1998 Chevy C/K Pickup 1500 AMI Billet Aluminum Interior Dash Knobs Logo
Top AMI - All Sales MFG Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you an AMI - All Sales MFG Hardware and Accessory Expert? Answer questions, earn points and help others
