Question about 2001-2005 Dodge Stratus 2DR RT Custom Style Spoiler
Where is the blend door actuator located on a 2001 dodge stratus rt
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 46 Answers
Normally on the innermost and lowermost part of your dash ductwork, right in front of your evaporator coil. Major job.
Posted on Nov 27, 2013
  • 56 Answers
On or in the heater box wich is located under dash
1998 Dodge Stratus - Air conditioning is blowing through the defrost vents
Vacuum controls this circuit and leaks will cause blend air door to default to defrost. Check for bad check valve or hose leaks under hood first as these are the easy ones to get at and under hood heat causes deterioration.
Jul 08, 2015 | 1998 Dodge Stratus
How do i fix a stuck blend door on 2010 dodge nitro?
I would pull off the blend door actuator and swap it out with a new one. Or another option is to swap it out with one of the other actuators. The blend door actuator is interchangeable with the actuators for the mode-air doors and the recirculation-air door.
Disconnect and isolate the negative battery cable.
If equipped, remove the silencer from below the driver side of the instrument panel.
Disconnect the wire harness connector from the blend door actuator located on the driver side of the air distribution housing.
Remove the two screws that secure the blend door actuator to the actuator mounting bracket and remove the actuator
Feb 17, 2015 | 2010 Dodge Nitro
01 Durango has no heat in the rear, only blows cold air? Is this the blend door actuator, and if so, where is that located?
have the hoses checked if they are hot the blend doors may not be working in the raer hvac system
Oct 10, 2013 | 2001 Dodge Durango
2002 Dodge Status R/T Coupe 3.0. When you turn the A/C on the indicator flashes and it only blows warm air. Took it to Firestone to have problem diagnosed and they determined that it was not the...
If, as Firestone says, the compressor and all components are operating properly, then you should be able to feel the low pressure hoses/tubes and confirm that they are icy cold (and sweating usually) when the a/c is on. If this is the case, then your blend door is not working properly. The blend door is inside the HVAC unit under the dash, and it directs incoming air to either the a/c evaporator or the heater core, depending on what is selected on the control panel, or it 'blends' air coming through both units. The blend door itself is hard to get to, but the blend door actuator (moves the blend door according to what is selected) is sort of accessible without pulling the dash. See the link for location, and also how to self test the HVAC system.
Chrysler Sebring HVAC reset Watch before you pull dash Blend door actuator
Jul 13, 2017 | 2002 Dodge Stratus
Locate starter on 2001 dodge stratus rt
front side of motor easier to get to from underneath
Dec 11, 2011 | 2001 Dodge Stratus
No heat Heater core is hot
If heater core is getting coolant circulating through it then you may have a temp blend door, or blend door actuator not working properly. The blend door is located in the air box under the dash, and the actuator is located on the air box. You may be able to visually check the operation while turning the temp knob, by locating the coresponding actuator on the air box and monitoring the movement. If it is moving ok and still no heat then the blend door, or lever is broken, which will require removal of the dash.
Oct 17, 2009 | 2001 Dodge Ram 2500 Truck
Dodge stratus rt fuel filter location
were is fuel filter st on a dodge stratus 2001 4dr 2.4L DOHC
Sep 22, 2008 | 2001 Dodge Stratus
2001-2005 Dodge Stratus 2DR RT Custom Style Spoiler Logo
139 people viewed this question
Top Razzi Vehicle Parts & Accessories Experts
mike t.
Johnathan Lence
Johnathan Lence
Are you a Razzi Vehicle Part and Accessory Expert? Answer questions, earn points and help others
