Washer control panel beeps and lights flash when not in use
Can't seem to shut it up. Looking for a service manual, can't find one without entering into dangerous downloads. I have troubleshooting skills and basic tools and multimeter.
    Genius:
  • 1,198 Answers
Repairclinic.com is legitimate. See if they have your manual, good contact for parts and info.
Posted on Nov 28, 2013
4 Suggested Answers
  • 240 Answers
SOURCE: My Whirlpool duet washer lights flash/beep
probably your door then, look at the door itself, at the latch is it broken? should form a complete square hole with four sides. if broken some part is probably inside lock asm. if complete, look at lock and determine if its in the lock position with door open, a arm will be up preventing the latch from going in. replace as necessary. Old duets (red lights) use standard lock asm same as GE and samsung. New duets (green lights) use whirlpool/new maytag unique asm. New locks come in two interchageable models, German (made in china) and Mexican, Mexican model is more troublesome, get german.
If lights flash during a cycle or other time, its giving a code, note the F code displayed
Posted on Jul 19, 2009
  • 1028 Answers
SOURCE: kenmore he2 front load washer
remove bottom panel open pump port and ck for foreign objects lean washer toward rear wall this will help help keep water toward rear and reduce flooding floor might try opening door first and dipping out as much water as possible with bottom panel removed reach up to lock area there is a tear shaped plastic peace pull it down to release door
Posted on Jun 02, 2008
blueextc3221
  • 15935 Answers
SOURCE: removing control panel on a kenmore elite he3 front load washer
"F11" is a Serial Communications error between the Central Control Unit (CCU) and Motor Control Unit (MCU). The CCU is the main computer for the washer and is located directly behind the wash tub. The MCU is the Drive Motor Control board and is located in the rear of the washer adjacent to the Drive Motor on the left-hand side (facing from the rear with the back panel removed). The wiring harness can also cause the error, but it is not as common a problem.
Whirlpool is the manufacturer of both model washers and recommends the following troubleshooting advice. Remove the top panel of the washer by removing the three screws holding it in place in the rear. Once the screws are removed, the panel slides back, then off. Remove the rear panel of the washer for access to the drive motor and MCU. Now check the following:
- Check the wire harness connections between the CCU, the MCU and Drive Motor. Make sure all connections are attached and making good contact. Check for any broken wires or connector pins.
- Check the Drive Motor to see if it free spins and that the belt is still attached and not slipping. If the motor is seized, replace it. If the belt is broken or worn, replace it as well.
- Check the MCU. Connector 1 is the Serial Communications Link between the MCU and CCU. Connector 2 is the connector to the drive motor. Resistance checks across pins 1, 2, & 3 are the motor windings. Connector 3 is the power supply - 120VAC should be read across pins 1 and 2 with the door in the locked position. NOTE: The connectors are read 1, 2, and 3 from the bottom to the top with the MCU installed.
- Check the CCU. Verify connectors 7 and 11 are properly installed. Facing from the front of the washer, connector 7 is the 4th connector from the RIGHT along the front. This is MCU Power. Connector 11 is the Serial Communications link from the CCU to the MCU and is located along the left hand side of the CCU (the connectors are numbered 11 through 14 back to front).
- Check the Drive Motor. Remove the connector and perform resistance checks on the motor connector pins. Readings across pins 1 to 2, 2 to 3 and 1 to 3 should read 6 ohms.
In most cases this is an indication of a failed CCU. This is an easy repair that the average do-it-yourselfer can accomplish on their own. If the washer is still under a warranty, parts and labor would be covered. With no warranty, a replacement parts will vary in price depending on where you get them. There are several good websites available that you can order parts on line and have shipped directly to you.
NOTE: Remove all the connectors from the CCU ONE AT A TIME and reconnect to see if the error code goes away BEFORE you decide to purchase a new one. It is not common, but sometimes a flaky connection can generate error codes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 16, 2010
Ltf2140e
Hello Mike - Typically, if the water temperature combination is not appropriate for the cycle selected, the status lights will blink and signal will beep 3 times. Try resetting the unit by either unplugging it or flipping the household circuit breaker to the off position. Wait roughly ten minutes and turn on the washer. Select a normal cycle and verify if the washer continues to beep. If resetting the power does not correct the issue, your appliance could be experiencing a communication error with the control board or could have a wiring failure. I would suggest contacting an experienced service technician to determine the precise cause.
Apr 28, 2013 | Frigidaire ATF6000ES Front Load Washer
The lights turn on and cycle through even though not running
Many folks have experienced this issue. I feel it could be an issue with the Control Board. But no one so far has taking the time to work this issue. If you want to try the first step is to see if the Control Board will let you go into Service Mode
Some handy links;
FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference.
Enter / Exit Service Mode
To enter Service Mode press the Enviro Plus and Spin Only keys (simultaneously) for three seconds or until the control beeps and the LED display will read 00.
If you can get into Service Mode go to page 17 of the Service Manual Display Diagnostic Codes follow the steps to step thru diag code blocks. Recorded the diag codes that show up. Then let us know the results. If you had to use a DVM to measure +12VDC on the Control Board could you do that?
Rich
Apr 07, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Washer will not lock and wash seems lights on but holding
Here is the Service Manual for the FAV6800A/FAV9800A
http://www.fixya.com/support/r1655507-found_service_manual_neptune_top_load
See if the Control Board will let you into service mode;
Page 14 of the Service Manual;
Only keys for three seconds or until the control beeps.
If you can get into Service Mode see page 15 of the Service Manual and see if you can run a Quick Service Cycle check.
If you can't get into Service Mode then you may have a Control Board issue. This could require some deeper troubleshooting like checking +12VDC on the Control Board and make sure that is good. If you can't do this then it would be time to call in a Service Repair Company.
But let’s see if you can get into Service Mode……Rich
Apr 03, 2010 | Maytag Neptune FAV6800AW Top Load Washer
How do you put a fav6800 maytag washer into dianostic mode
You need the Service Manual;
Here are some handy links; The Service Manual for reference. Sears Parts Direct for reference.
From Page 14 of the Service Manual;
Enter / Exit Service Mode To enter Service Mode press the Enviro Plus and Spin Only keys (simultaneously) for three seconds or until the control beeps.
Rich
Feb 21, 2010 | Maytag Neptune FAV6800AW Top Load Washer
I can't change the default wash cycle without it switching
1 Beep/E10--Error: Water doesn't enter Cause: Water supply problem, Check kinks and faucets
1 Beep/E10--Error: Water leaks Cause: Water connections loose,household drain clog,oversudsing. Correct problems.
1 Beep/E10--Error: Dispenser drawer is open Cause: Washer will not operate if drawer is open.
2 Beeps/E20--Error: Water dosen't drain. Cause: Drain is kinked or household clog. Correct.
3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart.
4 Beeps/E40--Error: Door is open. Cause: Washer will not operate if door is open. Close door.
5 Beeps/E50--Error: Motor is overheated. Cause: Wait 30 minutes to cool down. Restart.
7 Beeps/E70--Error: Cold water doesn't enter. Cause: Hoses crossed,faucet problem.
15 Beeps/EF0--Error: Oversudsing. Cause: Too much detergent,or improper detergent for machine.
15 Beeps/EF0--Error: Hot water doesn't enter. Cause: Hoses crossed,faucet problem.
Jan 28, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Just had an Affinity front loading washer delivered today. Did four loads without any issues, clothes are clean and smell great. After the washer was idle for about an hour, it started beeping, and the...
try disconnecting the power for at least 30 seconds which might reset control if this fails call service the control is faulty you have a 1 year full warrenty
Dec 21, 2008 | Frigidaire ATF6000ES Front Load Washer
The wash beeps all the time
To stop the flashing and beeping, the customer may touch the Pause Cancel button. The error code remains stored in the control but once the problem is corrected, it does not effect the operation of the washer. If the failure is something that the customer can correct (such as the water faucets being turned off), the washer will operate normally the next time it is started.
Nov 18, 2008 | Frigidaire GLTF2940ES Front Load Washer
Electrolux washing machine xc6 aquacycle 1400
Maybe that the door is shut "mechanically" but the micro-switch that indicate the control unit that door is shut,is faulty.
May 24, 2006 | Electrolux EW1200i Front Load Washer /...
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
