Question about Harman Kardon AVR 500 Receiver
AVR 3700 no sound
I just bought a used but mint condition AVR 3700. I connect 2 Klipsch F-35 to the receiver, no sound ! Any idea ? Even after 2 resets processors , still not sound. What is the problem ? Somebody can help me pls ? Ty
  • 31 Answers
Do headphones work with or without speakers attached? does unit light up? Check fuses. If breaker pops, or replacement fuse blows, it needs repair.
Posted on Nov 27, 2013
  • 3422 Answers
SOURCE: No surround sound
As you already checked the speakers, the HK manual says to check if the audio analog chain is fine. That means selecting 6/8 direct channels as source and apply a sound source for each channel. You can use a CD and test each pair of the 6/8 inputs at a time or use the output from a PC sound card with a test generator software (some excellent free software available as from NCH swift). Adjust the volume and listen. I guess you will obtain sound from the right front channel.
If you have sound in all speakers at the end of the test it means all audio channels are fine end to end.
The good news according to HK manual is that you eliminated 90% of the component of the system. The bad news is the problem is in the DSP section. There are no instructions or tests for the DSP part so you will have to go to the service center.
Goodluck..
Posted on Feb 17, 2008
SOURCE: OSD not working (black screen)
Your 635 will not display the OSD screen through component. You must use either s-video or rca. It won't upconvert the screen menu this route.
I had one up until a week ago. There are two outputs on the back specifically for the OSD screen. I used a separate old 13" TV with s-video to do my setups. Hope this helps.
Posted on Sep 11, 2008
SOURCE: My Harman Kardon AVR 330 is locked. Can't unlock
youtube
myspace
facebook
Posted on Feb 12, 2010
dj_relly999
  • 4070 Answers
SOURCE: I cant get any sound out of my Harman kardon AVR
Hi! The rca output may be faulty causing it not to give sound to the speakers. If that will be the problem then you will have to have it replaced for it to work again. Hope this helps and have a good one!
Posted on Jul 24, 2010
muntejaya
  • 10421 Answers
SOURCE: My Harmon Kardon AVR 500 sound doesn't work, I
Hi it is seem there is no output from your device. Please check the circuit components and wires for malfunction in your Kardon then. Regards
Posted on Feb 09, 2011
My denon avr-985 has no sound coming out of it why could this be
Go though your menu on the reciever, Look for the speaker functions for your front end rear speakers ,It was probably turned off. Was it working before you got it from your friend,
Sep 20, 2012 | Denon Avr 985 7.1 Channel 945 Watt...
Cant get klipsch sub woofer to work. do is there a menu setting through receiver to do this?
What model is the sub? Is your Klipsch sub powered? If it's already plugged in and powered on make sure you have the RCA cable going to the correct LFE output on the Denon and have it set to 5.1.
Jan 03, 2011 | Denon AVR-1601 Receiver
Denon AVR 1804
You need to get the manual and do some reading first. I couldn't find the AVR-1804 but the AVR-1803 is avaiable. It should be close enough to get you through connection and setup.
Register with retrevo.com and download it for free.
Feb 23, 2010 | Denon AVR-1804 Receiver
Speakers way too loud
You don't say how the Samsung routes out to the receiver. I assume you're using its RCA audio L and R jacks. Inability to adequately lower volume usually means you're NOT using a Line Level input, but maybe a speaker feed.
Your TV may have a setting for variable audio out, but even if you use the fixed setting you should be able to lower the playback volume to something comfortable with the receiver's volume knob. It does go down to completely OFF, right?
Jan 23, 2010 | Denon AVR-3805 Receiver
DVD player and receiver will not play a dvd in surround sound ?
The dvd player is responsible for reading the surround sound track, and sending it to the receiver. First make sure you are playing the surround sound track on the dvd, many have a stereo track too. Next, try another dvd and see if you can play surround sound on that one. If you can't play surround on ANY dvd I would start looking at the audio connection from dvd to receiver. Are you using an optical cable? Red, white, and yellow RCA cables? Optical will transmit any sound over only one cable, RCA cables need one cable for each channel (LF, C, RF, LR, RR, sub.) If your connections are correct, is the receiver set to play a surround sound track? Is it set in 2 channel mode?
Dec 28, 2008 | Harman Kardon AVR 35 Receiver
Creating a surround sound system
Hi and welcome to FixYa,
Offhand should work more than OK. Even if the 520 is only pushing 75watts per channel, you have 2 X for the front KSB-2.1 (left & right) plus another 75 for the Polk Audio center in addition to 250watts built-in amp of the Velodyne CT-150. What would be better is another pair of KSB-2.1 or comparable for the surround (another 2 X 75 and widening the separation).
Good luck and Thank you for using FixYa. Happy Holidays.
Dec 16, 2008 | Harman Kardon AVR 520 Receiver
MID-RANGE DISTORTION
hi it is an amp module failure inside £129.00 plus vat 4 hours to replace total strip out £380.00 total to do these are made by samsung and rebadged horrible things dump it thats my advice regards kirk
Oct 14, 2008 | Denon AVR-3806 Receiver
Harman Kardon AVR 500 Receiver Logo
441 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Electro Med Services...
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
