Question about Sanyo 46" Class LCD 1080p 60Hz HDTV, DP46840, Refurbished
No hdmi channels
I am getting no signal on all 3 of my hdmi channels
    President:
  • Sanyo Master
  • 775 Answers
Your main board needs to be serviced.
Most of the time we're successful with those repairs, but I can remember at least one case where the problem must have been in the main processor (it's usually elsewhere) and we weren't able to restore functionality.
Oddly enough, though, I think the component input was working, so ultimately the TV could still be used as an HD receiver...only not through the HDMIs.
Go to our site and search for DP46840, then choose your particular model and read the listing.
There's a very little downside to trying it and, at least statistically, a good chance of getting it to work.
Only guarantee that if we can't make it work there'll be no service charges of any kind.
Before sending the board make sure all HDMI inputs are enabled in the configuration screen :-)
Posted on Aug 10, 2014
    Top Expert:
  • Sanyo Master
  • 75,581 Answers
It sounds that HDMI firmware might not have installed. Contact the authorized service center. Try this link to know more.
Posted on Nov 27, 2013
What channel should my Toshiba 32 in be on for cable
What channel? Do you have a cable box from a provider? If yes, then the HDMI output from the cable box will go to one of the numbered HDMI inputs of the tv. Use your tv remote to select the correct input (source button) and when you find the corresponding numbered HDMI input, your signal should be there. If you are not using a converter box and your signal comes in from your wall to your tv then you must go into the menu settings of the tv and select a channel search. Usually an "automatic search" will do .Click that and allow for all the channels to be scanned. You will be limited to how many channels the tv will allow. If you know the cable signal has channels 1-200 but your tv can only "detect" channels 1-165, then you will be short 35 channels. Only way to to get more is to get a converter box. The only time you should be choosing a channel (3 or 4) to view cable on the tv is if the cable signal is going through a vcr first and then to the tv
Apr 10, 2018 | Toshiba Televison & Video
Visio no signal
Do you have normal signal on broadcast channels, just the HDMI is not responding?
Sep 28, 2016 | Vizio M550SV 55 Inch Class Edge Lit Razor...
NO AUDIO
If it is the radio you are trying to get make sure you have an antenna that is strong enough and can receive the signal. With a digital tuner it requires a strong enough signal to capture any channels.
Sep 30, 2014 | Pioneer Vsx-520-k 5.1 Channel 3d Ready...
Pc reads tv through hdmi but tv says no signal still what do i need to do?
The TV reads the PC via the HDMI out from the computer. You must make a direct connection from the PC to the HDMI input on the TV with a proper HDMI cable. Once that is established, you need to be certain what HDMI Channel is represented on the TV, HDMI #1, 2 or 3? Etc. Best you turn on the PC AFTER all connections are made and the TV is in full operation and the channel HDMI 1,2,or 3 etc. are on. Now turn on the PC and see if you get a connection. You may have a picture if you are streaming a video, and NO sound. If so, reset the Audio by clicking on the speaker icon at the lower right of your computer screen, and in the Volume Control Options select the output you wish to use.
Jan 05, 2014 | LG 42" 5400 Series LED HDTV - 42LN5400
How do i get the TV to play satellite? it just says weak signal when I turn the tv on. JVC RM-C18G
It has to be on the right channel. If you are supposed to be on channel 3, 61, 73, 113 (ask the satellite company which one you should be on) then you'll have to change the channel. If you are not supposed to be on a channel you have to find out which input you're supposed to be on (video 1, video 2, video 3, av 1, av 2, av 3, hdmi 1, hdmi 2, input 1, input 2, input 3 for example).
Jul 19, 2011 | Televison & Video
Everything working except I can't get digital channels. It comes up with no signal. But all digital SBS channels are working fine. How could that be.
Is it saying no signal or one moment please? No signal is a dead give away; there isn't any. One moment please can be several things. Low signal or cable box isn't active. How do you have your connection from your cable box set up as? Coaxial cable, RCA, HDMI, or component? Also, make sure whatever connection you're using, connect from you cable box out into your TV's in (type of cable you're using) Make sure you're on the correct input. For example. RCA may be video 1 or 2 depending on where you plugged it in. Hdmi -> may be HDMI 1 or 2. Coaxial may be channel 3 or 4 on your tv set. Hope this helps.
Mar 02, 2011 | Hisense Televison & Video
Having trouble changeing my ps3 to hdmi
if your tv is like mine ....
your tv may have a several imputs in the back so it may have a channel hdmi1 or even hdmi6. juss make sure that the channel your own matches the imput number on the tv
Dec 27, 2009 | Video Game Consoles & Games
Playstation 3 HDMI No signal
You have to go into settings on your ps3 and change the output signal to hdmi
Nov 04, 2008 | Sony Playstation 3 (PS3) Console
No sound through ps3 hdmi
I have sound on video 2, and when on a static channel but not on the usual channel 3 which is TV. Just stoppen working one day and cant figure it out... Please help!
Oct 19, 2008 | Televison & Video
Sanyo 46" Class LCD 1080p 60Hz HDTV, DP46840, Refurbished Logo
47 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
