Question about Air Tools & Compressors
INGERSOLL RAND SD100DTF, DO NOT VIBRATION
CHARGE PRESSURE 150 PSI, LOW VIBRATION
virgils
  • 39 Answers
SOURCE: Air Compressor, low pressure
does the compressor keep running all the time but never gets above 40 or does it turn off at 40?
if it is turning off at 40 I would try using another gauge just to be sure it is 40psi, and if that is the case then you probably have a faulty pressure switch, if the compressor is constantly runnign but won't get past the 40psi then you may have a worn out compressor, check the oil for either a low level or if the oil is dirty, if it is you may just need to drain and refill but if that doesn't fix the issue then you will need to rebuild the compressor
Posted on Oct 11, 2008
  • 76 Answers
SOURCE: Ingersol T30 won't shut off and blows pressure release valve
the wire juction box on your compressor has a pressure switch that may be wound in to tight take the cover off the box there should be a switch with a machine screw with nut and washer and spring back this nut off and see if that helps if you go to far you just crank it back in until the switch hit although it may be the other way around you may have to tighten to lower the pressure some of them are made that way if this does not solve your problem send me a picture of the switch and can solve it from there
Posted on Jun 26, 2009
  • 583 Answers
SOURCE: need to know how to adjust pressure regulator for low/high limits
sorry to be contradictory here, but better not to mislead or scare someone... Thepressure relief valve has absolutly nothing to do with cut in cut out pressure settings.the pressure relief valve is abrass fitting on the outside of the tank hexagonal fitting with a thin shaft coming out of the centre normaly with a ring on it not unlike akey ring .THAT is a blow off valve a safety device, that long before the air pressure is too great for the tank,will blow offthe air pressure in the tank ,try it, grab the ring and pull it out and it will dis charge any air in the tank ,that ios what it will do if thair is too great in the tank.. tanks are pressure tested and the appropriate valve fitted. NOW FOR YOUR ORIGINAL PROBLEM .you will find a control box ,useualy black or dark brown bakerlite cover,the electric cord goes into it ,also there will be another electric cord coming out and going to the electric motor that drives the compressor . If you take the cover off this you will find the cut in and cut out adjustments that allow you to set the cut in and cut out pressure as high or low as you want,that is whith in the capascity of the unit.It is self explanitory and there will be ( or should be ) instructions inside the cover .If you have any difficulty come back to me preferably with themotor and compressor sizes and i will walk you through it NOW AS MUCH AS THIS GOES AGAINST THE GRAIN, SHAG79 IT WOULD BE FAR BETTER IF YOU KNEW A BIT MORE ABOUT THE THINGS YOU ARE ADVISING THEM ABOUT EXPLOSIONS AND DEATH !!! WHAT ARE YOU-----A ******???
Posted on Aug 13, 2009
  • 583 Answers
SOURCE: ingersoll rand compressor T30 model 7100
I would wonder A if the wiring was heavey enough to carry that sort of load with out overheating B if the motor is big enough to do it for the same reason( ?what is the duty cycle?) C if the receiver is big enough to allow reasonable time between shut down and start up --- remembering that at start up the motor pulls double the current to start up and if it doesn `thave sufficient time to cool alittle before being called on to do it again and that would prompt the question ,does it have sufficient ventilation? these are all queries that would need addressing before I would try to offer a solution ,one thing is certain ,--there is something wrong
Posted on Aug 17, 2009
al_kupchella
  • 843 Answers
SOURCE: I have an Ingersoll Rand
When the compressor comes up to pressure and kicks off, you should normally hear a gasp of air escaping. That gasp is the release of pressure from the compressor itself - not the tank, and it is supposed to get released so that the compressor can restart without being preloaded with compressed air. My guess is that the gasp is not happening. It is probably some debris or a gummy mechanism. The mechanism is supposed to be triggered by the same mechanism that shuts off the motor.
Posted on Aug 30, 2010
Troubleshoot overflow condition
Sounds like worn pressure control valve. I'd replace it.
Mar 04, 2015 | Ingersoll Rand XHP1170FCAT High Pressure...
WHY DOES A SM75 INGERSOLL RAND COMPRESSOR CUT OUT ON LOW PRESSURE OIL
Low oil pressure. Are you adding a lot of oil. Have you check the oil level. Switch could also be bad.
Dec 08, 2014 | Ingersoll Rand Air Tools & Compressors
My Ingersoll Rand UNI15-5-150-L rotary screw compressor only starts uo after trying to start between 10 and 15 times
image Regulator may difference on all set ups good luck
you may have a Regulator on Air-Compressor Mount on the Gauge or next to it this allow you to set a pressures from 0 - 200 psi this to helps you maintain steady and reliable operation of your air tools.
Apr 18, 2013 | Ingersoll Rand Stationary Air Cooled...
Ingersoll rand compressor type 30 is not unloading. Auxillary valve seems to be dirty with oil and at 150 psi the compressor is not unloading.
It sounds like the pressure switch is bad or out of adjustment. Typically the pressure switch is set at 175psi on a 2340. If the auxillary valve you are speaking of is on the pressure switch and is constantly blowing air from it you have a bad receiver tank check valve. Also if you are getting a lot of oil out the valve at the pressure switch you may have some oil control rings bad.
Feb 07, 2011 | Ingersoll Rand Type 30 Reciprocating Air...
I have an Ingersoll Rand T30 10 HP compressor that runs OK and will bulid up 150 psi without any problems. But when the pressure drops enough to kick the pressure switch, the motor won't start. just tries...
Aug 30, 2010 | Ingersoll Rand Type 30 Reciprocating Air...
Capacities and pressures of Ingersol Rand Air compressors
Model Number: SS3J5.5GH-WB Manufacturer: Ingersoll Rand Tank Size: 8 Gallons Engine Engine HP: 5.5 HP Engine Type: Honda GX 160 Fuel Tank: .8 Gallon Pump CFM @ 90 PSI: 11.8 Max Pressure: 135 PSI Certification: UL/CSA/ASME Overview Dimensions: 43" x 18" x 26" Product Weight: 175 lbs
this can be a reference.
May 06, 2010 | Ingersoll Rand SS3J5.5GH Wb Ir Portable...
Unit trips breaker wont run . pulling high amps
when electrical all is ok, try if it wil run from zero psi. then you are sure that it dont have to start against a high pressure. if it runs then, check checkvalve and minimum pressurevalve.
Oct 09, 2009 | Ingersoll Rand UP6-30-150 w/ Int. Dryer...
Air Tools & Compressors Logo
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
