Question about Fostex Mr16hd 16 Track Digital Recorder
I can only hear static through the headphones on my Fostex MR16. The recording sounds fine when I transfer to computer, but I can't hear myself playing.
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 46 Answers
They make headphone amps that will take a line level and boost it in volume until it can drive headphones. I'd get one of those, and plug it into any available "line out" or "rec out" on the back of your Fostex. Sounds like the D/A converter section that feeds the headphone output has gone bad, and my solution will get you around that.
Posted on Nov 27, 2013
  • Thomas Nicol
    Thomas Nicol Nov 27, 2013
    Thanks for quick response. I just got lucky and got the idea to reformat it. Which completely fixed the problem. This old warrior has recorded about 700 of my songs and still has life!
  • 5603 Answers
SOURCE: my Fostex mr8 hdd "full"
If you can reformat the drive after dumping out anything you want saved MIGHT fix the problem...
The unit MAY not be able to tolerate fragmenting when you delete a snippet here and there... It may require large blocks of contiguous space.
Posted on Feb 27, 2010
Testimonial: "thanks mate, that was it"
SOURCE: Fostex MR-16 Multitrack Recorder The screen
Hi, try and reset it. it will come back to normal.
Take care.
Posted on May 18, 2010
  • 5603 Answers
SOURCE: For a long time I have been recording on my MR16
Likely you will need an updated driver software compatible with WIn7 for the Fostex. Check the Fostex site for update.
Posted on Sep 10, 2011
  • 1212 Answers
SOURCE: Transfer music form fostex 440 to a PC
Step one- download the open source program Audacity. http://sourceforge.net/projects/audacity/?source=directory
Get an 1/8 inch stereo jack to stereo RCA outputs (some digital cameras with vieo capability have these cords.)
Plug your tape deck "Line Out" to the "microphone" input of your sound card if it does not have a "Line level Input." You will have to adjust the microphone level once you enable it in the microsoft windows audio settings accessible through the control panel file.
If you are using a mac, you will have to open the CDEV to set it up.
Then it is simply a matter of getting used to using the program, which does not take too long. Just remember to save either each tape side or each song as it's own project.
All open audio files in the display will play simulataneously, which is why you want to close them and start new.
If you need other tweeking types of programs to reduce hiss or potentially disk pops, there are some offerings also at sourceforge http://sourceforge.net They cater to Windows, linux and Mac.
The sampling rate you choose- if not variable- will affect sound quality and file size.
Posted on Feb 05, 2012
  • 1212 Answers
SOURCE: I refcently purchased a MR16 Fostex it comes on lights up and shuts down . What is possibly wrong ?
Power supply. Most likely an electrolytic is failing. It may or may not show any signs of it. Other possibilities are bad solder connections, loose wire connections, or possibly a bad MOSFET if it uses a switchmode power supply. Also check the general construction to make sure nothing is shorting internally. Sometimes wires get pinched.
Posted on Feb 15, 2012
How do I transfer track data to computer?
Why you have to convert to mp3 ?. Did not the card can be removed and installed on the computer and then copied?
Where you convert the file? BR or computer?
What software you use to convert?
Mar 26, 2015 | Roland Boss Micro BR Multi Track Recorder
How can I record my songs to my tablet or my laptop
The best way is to use the USB output from the Fostex. Connect the USB cable from the Fostex to the USB input of the notebook. A Windows computer should show a USB Audio Device in the device manager. If not, you'll have to get a driver from Fostex and install that. But it should just work, it did in my Vista notebook. Then simply get any number of recording software packages (Windows 8 may have a built-in app). I've used Cool Edit and Reason 4 for recording and editing. You should not record the songs using the notebook's microphone input because (1) the analog noise of a recording generated by the notebook's A-D converter is horrible, and (2) you'll have level and impedance matching problems, even after purchasing something like a pair of Bogen WMT1A line matching transformers. Once you've got it recorded, put it in the cloud and download it onto your tablet. I don't think tablets have USB ports, but maybe yours does.
Jan 12, 2015 | Fostex Mr16hd 16 Track Digital Recorder
Why does my mixer take so long to select something from the menu and why does it freeze up?
Sounds like you need more ram or computer space. You didn't list what time of mixer or computer so can only answer basicly. If using a computer (which it sounds like) see how much the mixer needs andhow much space available on your hard drive. This is called a latency problem. Basicaly how long does it take for the computer to respond to commands while it is doing a task. either get a bigger hard drive and more ram or clear out some files on your computer. You can also go into settings and change the settings. You'll have to look through the manual on latency problems.
Nov 22, 2014 | Fostex Mr 8hd CD 8 Track Recorder with CDr
Feb 14, 2012 | Fostex Mr16hd 16 Track Digital Recorder
Feb 05, 2012 | Fostex Music
My Fostex mr8 hdd "full"
Feb 27, 2010 | Fostex Mr 8hd CD 8 Track Recorder with CDr
I have the Fostex MR-8 mk II without the burner. I'm having trouble as of late at exporting my finished song to a laptop computer. It's worked fine in the past. Could it be my USB cord is bad? The computer...
USB cords are cheap and can often be found even in Thrift stores... try a new one to eliminate that possibility... I will say they RARELY go bad unless they have been abused.
Remember that reading a USB stick by the computer is FAR different than transfering data from the Fostex...
MAKE SURE the driver for the Fostex in your computer is intact...
OFTEN the stupid DLL files that were working get CLOBBERED by new software and suddenly old things that used to work don't anymore... Thank MS for the stupid thing of allowing new software to change DLL's.
Jan 07, 2010 | Fostex Mr 8hd CD 8 Track Recorder with CDr
Hard drive failure
First thing is to open the unit and make sure the drive is connected. Sometimes cables get knocked off.
Next get a new drive... they are relatively inexpensive, like $69 or so and try it.
Take the old drive in your hand and snap your wrist to impart a spin to it. Then try the drive again... If it comes back to life, SAVE ALL THE DATA from it quick, and transfer to the new drive.
Dec 27, 2009 | Fostex Mr 8hd CD 8 Track Recorder with CDr
Obsolete instuction manual
  • http://static.fixya.com/Manuals/F/Fostex/Mr_8hd_CD_8_9560CD0193FD88FFF2BDF0CB4FC4A17E.pdf
or
  • http://www.fixya.com/support/p926153-fostex_mr_8hd_cd_8_track_recorder_with_c/manual-31688#
May 02, 2009 | Fostex Mr 8hd CD 8 Track Recorder with CDr
Fostex Mr16hd 16 Track Digital Recorder Logo
51 people viewed this question
Top Fostex Music Experts
Ben Armstrong
rhodesworks
Are you a Fostex Music Expert? Answer questions, earn points and help others
