Question about Electrosport 1995 Yamaha Yfm400 Kodiak Atv Plug-in Electric Regulator Rectifier
1995 Yamaha Kodiak reverse light will not disengage and bike won't start without pull starting it
Reverse light will not disengage and bike won't start without pull starting it. Trying to find original manual and can't locate it.
  • 109 Answers
Hi Guys and Gals, the reverse lock out sensor is on top the transmission under the battery box . There are 3 in a row with 2 close together towards the outside edge and one more alone, toward the middle. the one in the middle is the reverse lock sensor, check it with a Ohms meter by see if closes the circuit when you cycle thru the reverse setting, The sensor gets very dirty and oily in this location, so clean it well, around all the sensors there. clean the wires and make sure they connect well. Hint You can ground this sensor and it will disengage . If you can get in there put some electrical tape on the connectors to the light its the green/ white wire.
Posted on Sep 27, 2016
    New Friend:
Nick, having the same problem. wiggle the two wires that go into reverse light bulb on dash, while pressing starter button. this seems to be where my fault is. shorting in there somewhere. very frustrating i know!
Posted on Jan 30, 2014
How do I fix My kodiak 400 that will not shift into reverse or park
as soon as your bike begins to high idle it will not fall into gear you probably will need to set your linkage on your shifte
Sep 01, 2014 | Yamaha 2004 Kodiak 400 Auto 4x4
Where is the neutral saftery switch on 1995 Kodiak - the reverse light remains on and will not disengage
problem might be the two wires that go into reverse bulb on dash are shorting, give them a wiggle while pushing starter button
Nov 27, 2013 | Electrosport 1995 Yamaha Yfm400 Kodiak Atv...
Yamaha quad 1994 kodiak
it might be the points
Jul 04, 2013 | Motorcycles
Yamaha kodiak 450
Your float adjustment is incorrect, asis your fast idle
Jul 02, 2013 | Motorcycles
Datatool alarm won't disengage on bike alarm fob
Hi, Anonymous for more information about your question and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
http://www.pistonheads.com/gassing/topic.asp?t=1037031
Datatool S4 won disable
Yamaha FJR1300R Service Manual
OEM parts for Yamaha
YAMAHA FJR1300 Owner Manual
May 27, 2012 | 2002 Yamaha FJR 1300
What's your problem?1995 yamaha virago 1100 that sometimes you you put into gear and immediately dies
The Clutch on some bikes will disengage the starter motor. Yamaha will not allow you to engage gear when the side stand is down. Hope this gives you some idea
Nov 27, 2011 | Yamaha Motorcycles
I have a 1996 Yamaha 400 Kodiak.Will not start with electric start.Nutural light and reverse light will only light after pull start with lights on,have replaced battery.
you have a switch going bad or a wire grounding out to one of the switches
either the neutral safety switch or the reverse light switch
Jan 19, 2010 | 2000 Yamaha WR 400 F
I have a 2003 yamaha kodiak ATV, reverese indicator light stays
MAKE SURE THAT FORWARD AND REVERSE ARE FULLY ENGAGEING AND DISENGAGING
Jan 18, 2010 | 2003 Yamaha YZ 450 F
1995 900 sp clutch does not disengage when lever
hi,this may help,it sounds like your clutch plates are stuck together,this is quite common on bikes that have been parked up for a while,mine does it ocasionally,i fix it by getting the bike moving and crash starting it,once you have got it running and moving with the bike in the highest gear you can get it into(you can change up and down the gearbox without the clutch and not do any damage)simply pull the clutch lever in and roll on and off the throttle a couple of times and the clutch should disengage...hope this helps
Aug 02, 2009 | 1998 Ducati 900 SS
Electrosport 1995 Yamaha Yfm400 Kodiak Atv Plug-in Electric Regulator Rectifier Logo
1,479 people viewed this question
Top Electrosport Scuba Diving & Snorkeling Experts
David Bugden
David Bugden
Bill Boyd
ray gallant
Are you an Electrosport Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
