Sony str av720 reset
Protector mode
3 Suggested Answers
ginko
  • 19396 Answers
SOURCE: Sony str-d715 flasses protector
Protet mode is a special diagnostic mode that starts when a fault is detected.
When in protection mode the unit is prevented from starting by protection circuit, so to prevent further damage.
Check the speakers and speakers wiring, a contact in speaker wires, or faulty speakers can send the unit in protection.
Try unplugging power cable for one hour or so. then connect cable back and see if you get rid of protect state. Sometimes accumulation of electrostatic charges inside circuit capacitors can kick in protect mode. In that case unplugging the unit from main for some times can get rid of electrostatic charges, and reset circuits by draining power completely.
If that was the problem, you will not get Protect when plugging back power cable.
If you do all the above and still get Protect, then there is a real fault.
In that case the unit may be disassembled and tested to find the fault.
If that is the case I suggest contacting the manufacturer at the number listed on the owners manual, or asking a quote on repair to a local technician.
Posted on May 29, 2009
Ganx
  • 113 Answers
SOURCE: My sony str de605 am/fm reciever flashes
Hiya, not sure if i remember correctly but try reset it. First disconnect the speakers (make sure error isnt there)
When it is ON, press and hold the power button for about 4 seconds. It should then ask reset, clear or something and press enter. When its finished, try it again. If ok, reconnect speakers. If it happens with speakers, there is a problem. If it doesnt work and goes straight back to protect, then there is an internal fault (if i have the reset procedure correct)
Best of luck
Posted on Jul 16, 2009
Problem with SONY STR-DA555ES home stereo receiver popping & going into protector mode
You may have the speakers incorrectly connected or the speakers you are using have an impedence that is too low for the amp to support.
Sep 15, 2013 | Sony STR-DE875 Receiver
How do i get my sony DA30ES am -fm reciever out of protector mode
Here is a guide for you: STR DA30ES Protect
let us know how , if you need further assistance.
Jun 09, 2012 | Sony STR-DA30ES Receiver
Sony str-DE435 Flash Protector
this is not a reset problem, you have a defective audio output, is either the outputs transistors or the drivers IC's ( integrated circuit) and sometimes if you are lucky is just loose connections on the drivers IC;s.
good luck
Jun 18, 2009 | Sony STR-DE435 Receiver
May 03, 2009 | Sony STR-D700SS Shelf System
Sony str-de525 system "protector" problem
You've blown it. It recognizes a potentally harmful situation and goes into protect mode.
Mar 15, 2009 | Sony STR-DE935
Receiver goes into protector mode
Nope, power supply it would not even power up.  The capacitors are fried
Jan 04, 2009 | Sony STR-DE635 Receiver
Sony STR-DE525 Protector mode
Download service manual of STR-DE525 here and fix your receiver.
Must download all 4 files at web site.
Need further help, let me know.
Sep 24, 2008 | Sony STR-DE525
Protector mode SONY STR D1011S am fm receiver
I've had this happen, it's when you have speaker wires crossed.....
Dec 27, 2007 | Sony STR-DE945 Receiver
Protector mode..
Cambiale los IC de audio que esten dañados.
Oct 13, 2007 | Sony STR-DE825 Receiver
Protector message
The only way to reset protect is to eliminate the problem which activated it. Problem may be insufficient line voltage or unit's output circuit. Have unit checked out by prof, tech
Sep 30, 2007 | Sony STR-DE825 Receiver
87 people viewed this question
 Grubhead
Grubhead
