Question about Kamp Kitchen 30 QT. Stainless Steel Turkey Fryer
Push button wont stay down - Kamp Kitchen 30 QT. Stainless Steel Turkey Fryer
My dyson DC25 Animal, wont turn on. Is there something I can do to fix the problem
I called Dyson because I had a similar problem. When I pushed the red button down on my dc25, but it would not stay down. The vacuum would turn on when the button was pushed down, but of course when I let go of it the vacuum would shut off. The helpful telephone tech. Recognized the symptom right away and told me to push down on the button fully and let It flick up like a lighter. I about fell off my chair when that worked right away! Anyway for what it's worth, she said sometimes the mechanism in the buttons gets consnarlitated (my tern, not hers!) and this resets the spring...
Feb 28, 2017 | Dyson Vacuums
Why wont my coby tv stay powered on
Most likely the power board is defective. A new power board will cost $40 to $100 depending on your model. ShopJimmy.com is a good place to look for boards. They are not too difficult to replace if you have a minimum of electronic repair experience.
Dec 11, 2014 | Coby Televison & Video
Air button wont stay on. Pressing button startts air but shuts off as soon as button is realeased. Any idea?
If you push your air button to turn on the pump and it is will not stay running then the issue is not with the air button but rather the air switch located on the motor.
You can find the air switch by following the air tubing from the air button down to where it attaches to the pump.
A replacement air switch will cost you about $21
Rod
US Parts Center
May 04, 2014 | Home
Bass pro turkey fryer wont stay lit
wire around timer or set something on button so runs all time. but also set a cheap alarm or use one on cell phone to remind you time is up.
Feb 25, 2012 | Bass Pro Steamer/Fryer Combos Turkey Fryer
2002 buick lesabre. rear electric window not supposed to go all the way down but was pushe down. it is still on the track and moves when button pushed but does not go up and down properly. even if pulled...
the window regulator has to be changed indefinately if the window can be pushed either way up or down the window regulator assembly is bad . . . . in nowadays terms there is no such thing as "window off the track" if a window is not working properly there is a reason for it ;) dont forget to rate :)
Aug 18, 2010 | Buick LeSabre Cars & Trucks
Pilot wont light
If the pilot light goes out when you release the primer,then the thermocouple is bad.You can try to adjust the thermocouple,if it can be.It needs to be in the pilot flame.If the thermocouple is not in the flame,it will not stay lit.If you can not get the pilot to light at all,with the primer pushed down,then replace the regulator.To light the pilot light,you need to turn the dial to pilot.Then press the primer button down and hold it.The primer is either built into the turn knob,or it is a res button.Hold the primer down,and light the pilot,continue holding the primer down for at least 40 seconds.Then release the primer slowly,and if the pilot light starts to get weak,and try to go out,then push back down,and hold 30 seconds more.After the pilot stays lit,turn the knob to furnace or low,or whatever the directions say.
Oct 19, 2009 | Heating & Cooling
Push to start button will not stay on.
clean lint fromsafety switch no pay no stay
Oct 10, 2009 | Dryers
My dyson wont stay on
you have a defective switch, they are fairly easy to replace but i would call and sheck you probably still have it under warranty and can get it done for free
Hope this helps
Sep 14, 2009 | Vacuums
Wont find headset
Fold the mike boom to rear, push center football shaped button down for about 3 sec until it stays lit (not blinking) unfold the mike boom make sure it stays steady lit (no blinking) scan for bluetooth Walla!
Jan 02, 2009 | Motorola Mobility HS810 Consumer Headset
TOM TOM 910 won't charge/turn on
there is a little push button on the back. use a niddle and push that down at the same time hold the power button. you will hear the unit turning on itself and then it should work fine
Aug 10, 2008 | Tomtom GO 910 GPS Receiver
Kamp Kitchen 30 QT. Stainless Steel Turkey Fryer Logo
44 people viewed this question
Top Kamp Kitchen Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kamp Kitchen Kitchen Appliances - Other Expert? Answer questions, earn points and help others
