Question about Cell Phones
How to pass emissions test
My HC (PPM) are at 137 and max is 67 at 25mph what can I do to reduce the
    New Friend:
  • 3 Answers
My friend sent uninor i recevid docomo how to see mms
Posted on Nov 27, 2013
I have a 93' Ford Taurus that failed emissions
run the fault codes to find the faulty sensor
sensors that control the exhaust emissions are the HO2S ( heated oxygen sensors in the exhaust manifold/s
the O2 sensor ( oxygen sensors after the cat converters ) and the EGR unit that recycles exhaust gas back through the engine to re-burn the gasses
Oct 17, 2017 | 1993 Ford Taurus
My 1997 Honda Civic failed it's Emissions Test. See below the ASM Emission Test Results. What do you suggest I do to get the car to pass the smog test? ASM Emission Test Results: 15mph - RPM = 1587...
Jose, I don't know if this will give you the answer you are looking for because there are many things to consider here. The exhaust gas recirculation valve (EGR) is one of the main things involved in reducing NO emissions. This valve is controled by the power control module. (PCM) This is your vehicles computer. The PCM monitors the vehicles speed and will command the EGR to open when the vehicle attains a certain speed, which is why the ASM test being done is recorded at two different speeds. At 25 MPH your vehicle failed the hydrocarbon (HC) emissions limit and this could be for a number of reasons. When is the last time you car was tuned up? Old spark plugs, wires, clogged air filters, oxygen sensors, leaking injectors (personal experience) or the PCV valve could be contributing to the results of the test. I guess that the easiest way to go is to tune up the engine replacing the spark plugs, wires, air filter and the PCV valve and don't forget to have the oil changed at the same time. Only then should have the vehicle retested and see what the results are. Should it fail again you may have to consider having the EGR or the catalytic converter replaced depending on what portion of the test fails. If the NO fails I would consider the EGR. If the HC fails then I would consider the catalytic converter. Good luck with this.
Apr 05, 2011 | 1997 Honda Civic
My 1990 chevy astro van didn't pass smog. Paperwork says it failed the following; Ignition timing: 99 ATDC. Also, ASM Emission Test Results; 15mph HC (PPM) max is 122 measured 127, 25mph max is 102...
the smog test looks like the engine is miss firing, that could cause the timing to be out of whack also, try a old fashioned tune up, new spark plugs, wires, and filters also replace the PCV valve. any time you see the NO that high suspect a miss fire.
Feb 24, 2011 | Chevrolet Astro Cars & Trucks
Failed smog check
How well does the vehicle run?
Assuming that the engine did pass the EGR function test on the emission test results, and the MIL (Malfunction Indicator Light) or check engine light is not on when the engine is running, and if you are not sure when the last time it was that the engine had a complete tune-up, with distributor cap, ignition rotor, spark plugs, spark plug wires, air and fuel filters, then a complete tune-up would certainly help, and if the engine oil and oil filter have not been changed in a while, then they should also be changed before an emission test because long used engine oil traps carbon and it will show up as higher CO on the emission test because the emission analyzer will be able detect the higher CO from the engine oil through the PCV valve.
However, it would seem from those HC readings that there is a vacuum leak, and carefully inspect all of the vacuum lines for any cracks or damage, (especially the vacuum line to the fuel pressure regulator) because cracks in the vacuum lines seem to like to hide underneath the lines.
The emission label under the hood should have the vacuum line routing diagram printed on it, and the vacuum lines should all be checked to be certain that they are all connected correctly.
Here is the firing order diagram for that vehicle to help assist you tune-up the vehicle.
Jul 09, 2010 | 1997 Honda Civic
FAILED EMISSIONS
possible but could be head gasket or valves , or worn rings and is by passing the pistons going straight out the end ...or maby settings are wrong ? try carb cleaner and inspect visually air-filter etc.
Aug 26, 2009 | 1986 Ford Mustang
Failed Emission Test with high NO(PPM)
Sort out the fuel/air mix and check for oil burning or replace the van.
Sep 17, 2017 | 2000 Saturn Ls 4dr Sedan
ASM 2525 NO ppm TAILPIPE EMISSIONS failure
have you had the the engine codes pulled and reset?
and if so what are your engine codes?
i dont know of any car that will pass emissions test with the engine light on.
we cure your trouble that caused your engine light to come on and you will pass your test.
later
paul
Nov 24, 2008 | 2002 Toyota Sienna
Test no pass
Have you got all your hoses running to the emmission control box (usually a round or rectangular box on the passenger side near firewall). Is the box old and needs replaceing? If you don't want to change because is very dear to do you could change your spark plugs and fuel filters? Also change your oil with a lighter oil a 55w/10 and oil filter and your spark plug leads with new ones 8mm diamiter would be good as it is less resistance for the spark which will aid in fuel burn and air filter change is good idea to, maybe 200 dollars or so to do this but all will help reduce your emmissions if emmission box isn't working properly. Hope this helps
Jul 23, 2008 | 1997 Dodge Caravan
Cell Phones Logo
18 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
