Question about Kenmore 73952 Gas Dryer
Dryer is noisy. rollers are new. sometime the dryer starts fast
And then slows and then speeds up again.
  • nehogs May 08, 2009
    could this be a motor problem?
    Sergeant:
    Champion:
  • 214 Answers
I would say the belt may have sliped off the pully.Make sure the belt is on correct.
Posted on May 08, 2009
Drum Noise and not drying proerly
a dryer drum usually rides on rollers. when center of roller wears out then they start to get noisy
Dec 21, 2013 | Zanussi Dryers
Noisy machine AEG Lavamat 35600 Tumble Dryer
moter 1st i would say thx nick
Feb 10, 2008 | Dryers
DLE2050 making strange spinning noise
I guess I wasnt clear enough. The dryer works ok, except for the rattling sound now. It will start when i push the start button, it heats, and dries the clothes. Just noisy where before the flow sensor went off, it was pretty quiet.
Jan 07, 2013 | Dryers
I have a maytage dryer model# mde2706ayw and it is making a loud squicking noise on and off. it is sometimes really loud and only last a few seconds on and off during the whole cycle
Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time.
Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it.
Jan 09, 2011 | Maytag MDE2706 Electric Dryer
Dryer squeals when start up
Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time. Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it. Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them.
Nov 26, 2010 | Whirlpool Dryers
When the dryer is turned on, it usually starts slow
Could just be the drive belt, or the motor starter is faulty.
Feb 22, 2010 | Dryers
Squeaking noise when dryer in oepration
if the noise is very fast like motor speed oil or replace the idler also ck the belt / if idler is bad so is belt . other noise would be a slow sounding noise / the speed or the drum. so ck the rear rollers ond lube or replace . best solution is to pull the drum / clean the lint out and change or lube these things .. mm hopt this helped m feed back pls .
Dec 22, 2009 | Maytag PYE2300AY Electric Dryer
When dryer start button is pushed it hums and whirrs but most of the time it won't start. WHen it does start it seems to overheat.
Sounds like your problem may be a broken belt or a belt that is slipping. ALL WAYS UNPLUG YOU DRYER BEFORE DOING ANY WORK ON IT.
It will turn the drum slowly and cause the blower not to turn up to speed causing an overheat problem. Sometimes the overheat problem is also caused by the thermostat/thermistors being faulty. You would have to remove the back of the dryer to look for the air tube going from the blower to the drum. This is normally where the thermostats/thermistor is located.
If you have to replace your drum belt and if you have a front loading machine.
First you will need to unplug your dryer from the electric.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would also recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
Good luck,
I hope this helps
Oct 14, 2009 | Maytag Dryers
Model no. LDE8506ACE has a noise when running seems like maybe drum rollers or belt. how do I get to drum?
This link is provided by www.repairclinic.com and shows parts breakdown/disassembly procedures, etc.
A faulty blower could also cause a noise during operation and as the motor slow rpms on stopping.
http://www.repairclinic.com/Dryer-Electric-Maytag-Style-Appliance-Diagram
If your dryer is noisy, check these:
Rollers
Idler pulley
Glides
Rear drum bearing
Blower wheel
Rollers Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time.
Idler pulley Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it.
Glides Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them.
Rear drum bearing Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace them when they're worn.
Blower wheel Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace it.
Aug 18, 2009 | Maytag Dryers
Maytag MDE8000 dryer noise
Blower wheel Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace it.The following site provides mor troubleshooting info:
http://www.repairclinic.com/0088_8_1.asp#Level1_4
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Sep 28, 2008 | Dryers
Kenmore 73952 Gas Dryer Logo
85 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
