Question about Electrosport 1995 Yamaha Yfm400 Kodiak Atv Plug-in Electric Regulator Rectifier
Where is the neutral saftery switch on 1995 Kodiak - the reverse light remains on and will not disengage
Problem might be the two wires that go into reverse bulb on dash are shorting, give them a wiggle while pushing starter button
Posted on Jan 30, 2014
Reverse lights stay on in all gears
Back-Up Light remains always ON you should check the Park/Neutral Position Switch (A/T) .The park/neutral position switch detects the shift lever position and sends signals to the ECM.
The ECM receives signals (NSW, R, 2 and L) from the park/neutral position switch.
Jul 26, 2014 | 1999 Buick Regal
2004 yamaha kodiak 400, ran great, now it won't start the next day. kill switch was left on. slid it over, turned it on like i usually do to start it, nothing but a red light (temp ?). it was very cold...
hey Tammy... does the neutral light come on??? if not... find neutral..see what happens.. next.. have your batteries CCA checked.. (Cold Cranking Amps)...the amperage is what makes the starter work..NOT voltage...you can take it to Oreilly's, autozone, batteries and bulbs, or your local battery store...
Aug 16, 2017 | Yamaha 2004 Kodiak 400 Auto 4x4
1995 Yamaha Kodiak reverse light will not disengage and bike won't start without pull starting it
nick, having the same problem. wiggle the two wires that go into reverse light bulb on dash, while pressing starter button. this seems to be where my fault is. shorting in there somewhere. very frustrating i know!
Nov 27, 2013 | Electrosport 1995 Yamaha Yfm400 Kodiak Atv...
Neutral light dosnt come on no elec to starter
Left brake switch would normally permit crank,remove lever,unscrew the tiny guy out ceck it.Neutral light bulb or switch(in the gearbox)if it goes right in the neutral just does not show.
Oct 22, 2013 | Yamaha Kodiak 450 A 4x4 03 Airbox Air Box
1997 chevy Pickup wont come out of 4WD
solenoid is sticking have had this probem before
Jan 30, 2013 | 1995-1997 Chevy 1500 Truck Ignition...
I have a 95 jeep loredo . reverse light is not working , I checked the bulbs and fuses and they all good, I also change the neutral switch, still han no reverse light, any suggestion?
The neutral switch is so that you can't start your vehicle in a gear (drive, reverse, ect.) your looking to replace the backup lamp switch. Not sure where its located on your jeep but that sounds like the problem. Happy hunting!
Dec 17, 2011 | 1995 Jeep Grand Cherokee
I have a 1996 Yamaha 400 Kodiak.Will not start with electric start.Nutural light and reverse light will only light after pull start with lights on,have replaced battery.
you have a switch going bad or a wire grounding out to one of the switches
either the neutral safety switch or the reverse light switch
Jan 19, 2010 | 2000 Yamaha WR 400 F
I have a 2003 yamaha kodiak ATV, reverese indicator light stays
MAKE SURE THAT FORWARD AND REVERSE ARE FULLY ENGAGEING AND DISENGAGING
Jan 18, 2010 | 2003 Yamaha YZ 450 F
Back up lights won't work. How do I determine if
Hi. Remove the reverse lamp bulb. With a 12 volt test light, check for voltage at the wire that is NOT white with a black tracer.
If you have voltage, the neutral switch is good. The White/black wire is the ground.
Nov 25, 2009 | 1995 Toyota Camry
No head lights but all other lights work including
you have a bad lighting control module. $499 new, $250 from tascafordparts.com or less from ebay or car-part.com.
It is under dash above brake pedal.
Section 17-01: Lighting, Exterior 1995 Town Car, Crown Victoria, Grand Marquis Workshop Manual
REMOVAL AND INSTALLATION Lighting Control Module Removal and Installation
  1. Open hood. Disconnect battery ground cable .
  1. Disengage three pushpins and remove lower driver side instrument panel finish panel.
  1. Locate lighting control module above accelerator pedal.
  1. Disconnect bottom two electrical connectors from lighting control module.
  1. Remove two screws retaining LCM to bracket and unclip from bracket.
  1. Remove lighting control module from bracket and disconnect two remaining electrical connectors.
  1. To install, reverse Removal procedure. Check lighting control module for proper operation.
Mar 15, 2009 | 1995 Lincoln Town Car
Electrosport 1995 Yamaha Yfm400 Kodiak Atv Plug-in Electric Regulator Rectifier Logo
129 people viewed this question
Top Electrosport Scuba Diving & Snorkeling Experts
Bill Boyd
ray gallant
Are you an Electrosport Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
