Question about Precor Exercise & Fitness
Error 44 have it set on while pedaling error 44 shows on screen. the pedals then have no resitance
  • Precor Master
  • 914 Answers
Precor Error 44, Un-commanded Lift Motion Probable Cause 1. Intermittent or bad connection in the lift position sensor(potentiometer).
2. Lift position sensor (potentiometer) is bad.
3. Lower PCA is bad.
Corrective Action
  1. Bad or intermittent connection of the lift position sensor (potentiometer) is the most common cause of the error 44. Inspect all wiring and connections related to the lift position sensor (potentiometer). Repair or replace wiring connections as necessary.
  2. Monitor the lift position number displayed while operating the lift in diagnostics mode. If the reading makes large changes or is erratic, the lift position sensor (potentiometer) is likely bad. Replace the lift position sensor (potentiometer) or lift motor if the lift position sensor (potentiometer) is internal to the lift motor.
  3. If the lift moves without any command entered either manually or through a program, replace the lower PCA.
Precor Error Code 44
Posted on Sep 03, 2014
Bleed rear brake on 2004 fatboy
Hi Anonymous, this is a two man opperation, one guy pumps the pedal and the other opens and closes the bleeder screw on top of the calliper. WARNING!!!!! it is imperative that during this procdure you not expose the small holes at the bottom of the master cylinder to air, keep that reservoir full. Use only DOT 5 or higher brake fluid and fill the resivoir. You should put a clear plastic hose on the bleeder screw nipple and route it to a drain pan otherwise brake fuid will squirt all over the place and DOT 5 eats paint. With the bleeder screw closed pump the brake pedal with full strokes 10 times or untill some resitance is felt. Hold the pedal in the down position and o,pen bleeder valve to let air excape then close snugly. check the reservoir and fill as necessary. Keep repeating the process, the stiffer the pedal gets make your strokes shorter and faster. When the pedal gets nice and hard and does not feel spongey and there are no more air bubbles in the clear plastic line, top off you reservoir and replace the accordion gasket compressed as flat as it will go and the top cover, clean up your mess and you are good to go . Good luck
Apr 14, 2014 | 2004 Harley Davidson XL 883C Sportster...
Foot pedal error
Yep same thing .....the thing is possessed started running by itself when I was at the iron. Dealer said never heard of such a thing and acted like it was me. Also will not stop sewing when take foot off pedal. Dealer charged me $95 to clean machine and said nothing wrong with foot pedal. Ugh. Has anyone replaced foot pedal and found the problem to stop properly?
Mar 15, 2012 | Janome Memorycraft 6500P Computerized...
The sustain pedal is broken on my PX-700 and I would like to know if there are any replacement pedals on the market that are compatible?
Getting back to the Casio PX-700 - yes it is possible to use a new £14.30 (EBAY) metal pedal which is more durable than the original.
The original pedal has two internal switches (semi-sustain, full sustain) depending on pedal position.
The replacement single-switch pedal is switcheable (normally open or closed) - for this mod, it should be set to 'normally OPEN'.
There are now 2 choices:
i) Are you just interested in Sustain only?
ii) Do you need the other 2 pedals working (mid/left hand)?
For choice i)
Turn off power. You can now cut the old cable where it enters the pedal assembly & remove the pedal bar (held by 2 large screws).
Discard the pedal bar & old pedals.
Open new pedal base & desolder the screened cable (note the screen connection pad position).
a) Run the black cable wire to the new pedal screen pad & solder in place.
b) Join the grey & brown wires & solder to the other pad.
Insulate the unused (yellow/red) wires.
Replace pedal base - JOB DONE!
For choice ii)
a) Dismantle pedal assembly
b) Without removing any wires, solder the two pedal wires to the existing coloured wires as described above - OK to join grey & brown wires.
Problem. The above pedal is 9" overall, so may be placed sideways, so as not to be too far forward.
OR use a smaller guitar-type footswitch (non-latching, normally open).
Jun 13, 2011 | Casio Portable Keyboard Touch Sensitive...
Setup steering and pedals up on my ps3, for need for speed shift, steering work fine but the pedals wont work, one pedal changes the veiw of the screen on the game, other pedal does noth i i have the P3...
You need to go into the input settings for the game, and change the button presses for gas and brake to match the pedals that you are pushing. Hope this helps!
Feb 27, 2011 | Video Game Consoles & Games
Pedal Malfunction RP250
You will have to recalibrate your pedal. If you don't have your manual anymore try going to www.digitech.com. The procedure for the RP350 so that you don't lose your presets is : 1. Press and hold the UP/DOWN Footswitches until PDLCAL appears in the display (BYPASS,TUNER and EXIT will be displayed before PDLCAL is accessed after about 5 seconds). 2. When the display prompts you with TOEDN, rock the EXPESSION PEDAL forward (toe down) and press either FOOTSWITCH.
3. When the Display prompts you with TOE UP, rock the EXPRESSION PEDAL back (toe up ) and press either FOOTSWITCH.
4. The Display now prompts you to calibrate the V-Switch sensitivity (VSWxxx), where xxx is the current V-switch threshold. Rock the EXPRESSION PEDAL forward and press firmly on the toe once to turn the V-switch on (WAH ON) and again to turn the V-switch off (WAH OFF).
5. If the V-switch is too sensitive, press the right UP FOOTSWITCH to raise the threshold (range is 0-2000. Keep testing the V-switch sensitivity and adjust the threshold until it only engages when you want it to ( too sensitive a setting will lead to the V-switch falsely triggering on or off when using the Expression Pedal).
6.When the V-switch sensitivity is set to your satisfaction, press both UP/DOWN FOOTSWITCHES simultaneously to exit. NOTE: IF the DISPLAY shows ERROR, an error has occurred and steps 2 through 5 should be repeated. Sorry fo the caps but thats how the instructions appear in my sons manual. You can also dowload the manual and an editor librarian (for the 350 at least) at their site. They might even have an update for your pedal. Hope this helps. Keep playing.
Jul 09, 2009 | Music
My clutch wont engage it was working fine one day the next i had almost no resitance on my pedal
Check master for fluid level, check line going to slave unit, check slave unit (any leaks, you have found problem) If master is full, it may be internally bypassing in that case it may not leak but will not put pressure into the line. (fluid goes around piston instead of being pushed) If master is low and no obvious leak found, look under dash where clutch rod goes into the back of the master. you may find fluid there.
Apr 18, 2009 | 2001 Mitsubishi Eclipse
My GT Logitech Driving Force GT wheel does not work. The pedals d
try this fix. The pedal issue is common with the Logitech Driving force series wheels. Also try going into Controller settings within the Grid game and set to configuation that suits the wheel that you have. http://merc460racing.com/GT/repairing_logitech_driving_force.htm
Feb 20, 2009 | Logitech DRIVING FORCE FEEDBACK STEERING...
I have a Casio LK-44 lighted model. I am looking for a set of pedals to add to the unit. Is there any pedals that will fit my model.
hello sure visit any professional sound store and they may have it.......dont forget model,connector,feeds so it matches right on...........saludos
Nov 22, 2008 | Audio Players & Recorders
Diagnostic code P2299 for 2004 Dodge Ram 1500 5.7 hemi?
P2299-BRAKE PEDAL POSITION / ACCELERATOR PEDAL POSITION INCOMPATIBLE
Set Condition:
The PCM recognizes a brake application following the APPS showing a fixed pedal opening. Temporary or permanent. Internally the PCM will reduce throttle opening below driver demand. One trip fault and the code will be set within 5 seconds. ETC light will illuminate, the light will only stay illuminated while DTC is active.
Possible Causes
DRIVER PRESSING ACCELERATOR PEDAL, THEN PRESSING BRAKE PEDAL, AND CONTINUES TO HOLD THEM DOWN SIMULTANEOUSLY
STOP LAMP SWITCH
APP SENSOR
The most likely cause of this DTC is Brake Torquing the engine by pressing the Accelerator pedal and the pressing the Brake Pedal.
Jul 17, 2008 | 2004 Dodge Ram 1500
Exercise & Fitness Logo
242 people viewed this question
Top Precor Exercise & Fitness Experts
Howard
Howard
Ross Metcalfe
Ross Metcalfe
Tom Chichester
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
