Question about Lasko 6410 Designer Ceramic Electric Compact Heater
How to clean a lasko 6410 - Lasko 6410 Designer Ceramic Electric Compact Heater
How do I clean the blades on my lasko E20739 fan
Do you have the still have the e20739 lasko fan, i need the plastic blade on the unit
Jul 19, 2010 | Lasko 48" Xtra Air Tower Fan with Air...
Clean the filter : Lasko Model #5812
First make sure heater is unplugged. Next, on the side of the heater locate two holes (see image) these are what's keeping everything in front together. unscrewing these and genty pulling sides out lwill release the top filter and front where control knob is and bottom filter where the heated air comes out. Clean filter & re assemble.
Nov 30, 2009 | Lasko 5812 Heater
How do you clean a Lasko® High Velocity Blower Fan w/Remote
you need to dismantle the fan,
the top back pry off.
then you will see screws.
Aug 01, 2009 | Lasko High Velocity Space-Saving Blower...
How do I clean my Lasko fan with Ion?
Yes unscrew the screws and thre will be more screw to undo insode to take it apart. I had to do mine an it was filthy! Good luck!
Apr 23, 2009 | Lasko 48" Xtra Air Tower Fan with Air...
How to clean filter on Lasko tower ceramic heater
Thanks for the response = I blew the filter clean with a forced air canister.
Nov 29, 2008 | Lasko 5540 Ceramic Compact Heater
Lasko 5350 will not power up. Tempermental.
I had the same problem with mine,, I called the 800# and they told me to either vacuum it out weekly or use a hair dryer to blow out the vents, both solutions seemed to have work for me ~ good luck
Nov 14, 2008 | Heating & Cooling
Lasko 6410 Designer Ceramic Electric Compact Heater Logo
37 people viewed this question
Top Lasko Heating & Cooling Experts
Steve
Craig Butler
Craig Butler
Are you a Lasko Heating and Cooling Expert? Answer questions, earn points and help others
