Question about AT&T CL82209 Cordless Phone
Program numbers - AT&T CL82209 Cordless Phone
How do I program the Flexible Outside (CO) Line Buttons? The manual doesn't say!
if you want to save extension number
program + button + 1 + EXT + store
example : program + button + 1+ 103 + store
if you want to save co
program + button + 0 + co number + store
example : program + button + 0 + 1 (for co1) + store
if you want to save external number
program + button + 2 + 9 + external number + store
example : program +button+2+9+0097259970... + store
Jun 09, 2015 | Panasonic KX-T7730 Corded Phone
I want to reprogram some numbers on AT&T 822 (21213)
1. Lift receiver, touch "program" (above number keypad, on the bottom left of programmed numbers).
2. Enter phone number (1-AC-Number).Touch button for quick dial station (e.g., Name of Person to Call).
3. Hang up phone.
4, Lift and touch programmed button to dial (new) number.
Oct 06, 2013 | Lucent AT&T Speakerphone 822 (21213)
Panasonic KX-T7730, we have a 824 phone system and cordless handsets (kx-tg1711) we cannot make outgoing calls on these handests but can take incoming calls and can transfer calls. how do we programme
  • Locate the program and auto-store button on your telephone. You will be using these to customize many of the features on your KX-T7730. The program button is used to enter or exit programming.
  • 2
    Program your outgoing line preference, i.e., the line you prefer to seize when you go off hook. Press "Program" "1" "1" "store" for no line. Press "Program" "1" "2" "Store" for an idle outside line. Press "Program" "1" "3" "Outside Line Number" "Store" for an assigned outside line. The outside line number will be a single or double-digit number that is set through your phone system.
  • 3
    Program your incoming line preference, i.e., the line you prefer to answer when you go off hook. Press "Program" "2" "1 "Store" for no line. Press "Program "2" "2" "Store" for ringing line. Press "Program" "3" "Outside Line Number" "Store" for an assigned outside line.
  • 4
    Program your flexible CO buttons. These are the inner row of 12 lighted buttons. Your outside lines need to be programmed to these--you can choose any of these 12 buttons in any order. Press "Program" "CO Button" "0" "Outside Line Number" "Store." The outside line number will be a single or double-digit number that is set through your phone system.
  • 5
    Program any other unused flexible CO buttons for an extension number or any frequently dialed phone number. Press "Program" "CO button" "1" "Extension Number" "Store" or "Program" "CO Button" "2" "9 + Phone Number" "Store". A "9" must be entered at the beginning of a phone number to tell your phone system to seize an outside line before dialing, e.g., "9-1-212-555-1234."
  • 6
    Locate the programmable feature buttons (the row of 12 solid buttons on the right). These buttons are basically one-touch buttons that can be set for extension numbers or phone numbers. Press "Program" "(PF) Button" "Extension Number" "Store" or "Program" "(PF) Button" "9 + Phone Number" "Store." Remember to press "Program" again to exit programming.
  • 7
    Locate your "FWD/DND" button. This button is used for setting "Call Forward" or "Do Not Disturb" on your telephone. To set call forwarding, go "off-hook" either by lifting the receiver or pressing speakerphone. Make sure you go to intercom and not an outside line. To forward all calls, go off-hook, press "FWD/DND" "1" "extension number" (the extension number that you wish to forward all your calls to) "#". After you hear a confirmation tone, place the receiver on-hook. The steps to set call forwarding for busy/no answer are the same as above, except you will press "2" in place of "1". To cancel call forwarding, press "0" in place of "1".
  • 8
    Program "Do Not Disturb," which stops your phone from ringing--any callers will just hear a DND tone. To program, go off-hook, press "Program" "4" "#" on-hook, to set. Press "0" instead of "4" to cancel.
  • 9
    Locate the message button--this works in coordination with your message light at the top right of your telephone. If the light is lit, press "message" to hear a message left to you either by another extension or a voice mail system. The message button can only be programmed as a message or one-touch button. To program as a message, press "Program" "Message" "3" "Store." To program as a one-touch, press "Program" "Message" "1" "Extension Number" or "Program" "Message: "2" "9 + phone number."
  • 10
    Return your KX-T7730 to its default settings by pressing "Program" "#" "*" "Store."
  • Read more: How to Program a Panasonic KX T7730 ' eHow.com http://www.ehow.com/how_7159736_program-panasonic-kx-t7730.html#ixzz1eYPzbevZ
    Nov 23, 2011 | Panasonic KX-T7730 Corded Phone
    Program personal speed dial numbers on a NorStar M7324 Telephone
    For external numbers press FEATURE *1, then press the button you want to store the number on, then enter the phone number using the dialpad.
    For internal numbers press FEATURE *2, then press the button you want to store the number on, then enter the extension number using the dialpad.
    To determine what is currently programmed on a button, press FEATURE *0, then the button to identify and the display will show what feature or autodial number is programmed on the button. If the button is a line button or line pool button, you will not be able to clear it through user level button programming. System level programming must be accessed to change line appearances.
    Mar 02, 2011 | NorStar M7324 Telephone
    I have download a trial version 4.15 and i have given a serial number but after that it was not working so please provde me smark movie of nokia e72 which work successfully in it with serial key
    The computer program with a serial number require comaprtible computer systems to perform. For example, the program is provided a serial number from the manufacturer as referecne to the particular software distritubuted. Once the program has been installed on the computer with serial number keyed, the computer has to have the resources either recognied as being compartible with the manufacturers product. For example, purchasing apple mac programs mayhave been provided a functioningseriel number however would least fucntion when installed on microsoft computer. usually with computer programs, verify the computer systems prior to acquirng programs or ascertain the programs compartibilities before attempting to install.
    Feb 15, 2011 | Computers & Internet
    I have panasonic kx-t7730. How to set the intercom name and number?
    Changing the name and extension number can be done through system admin programming from a phone extension allowed by the class of service assigned to that extension by the phone system installer. Typically the attendant phone is allowed this ability. From the programming phone press **1234(1234 is the default password) to access programming. Once in programming dial 003 for extension numbering then press . Enter the current extension number of the phone you want to change followed by the new extension number then press . Lift the handset to end programming. Access programming again by pressing **1234. Dial 004 for extension name programming then press . Enter the new extension number you programmed then enter the name for the extension. Press then lift handset to end programming.
    It is possible that your phone has not been assigned an extension number, in that case system installer programming would need to be accessed to assign the port an extension number. The port number the phone is connected to would have to be determined. This could require tracking the wiring back to where it is connected into the phone system. If this is the case I advise calling a qualified service technician.
    Dec 08, 2010 | Panasonic KX-T7730 Corded Phone
    I WAS RE-PROGRAMMING MY AUTO DIAL BUTTONS AND WAS ON MY 3RD ONE WEHN IT DECIDED THAT ALL MY BUTTONS WOULD NOW DIAL THAT NUMBER. i CAN'T TOUCH A SINGLE BUTTON WITHOUT IT DIALING THAT NUMBER.
    To Program Buttons On Your Phone:
    For External Numbers:
    1. Press the Feature button, then * 1
    2. Push the button you want to program
    3. Display will read "Program and OK"
    4. Enter the telephone number, then press the OK softkeyFor Internal Numbers (Extensions.:
    1. Press the Feature button, then * 2
    3. Display will read "Intercom #:__"
    4. Enter the extension number
    For Feature Codes:
    1. Press the Feature button, then * 3
    3. Press the Feature button then enter the Feature Code
    Aug 12, 2009 | NorStar M7310 Corded Phone
    I AM HAVEING PROBLEMS WITH INSALLING 007 QUANTUM OF SOLACE CAN YOU HELP ME PLEAS!!!!!!
    Before you can install James Bond: Quantum of Solace you'll need to find the serial number that came with the program. Quantum of Solace requires that you enter a unique serial number before using it.
    If you've lost your serial number, there may be a way to find it as long as James Bond is still installed. You might be able to find your serial number if you've uninstalled the program but only if the serial number information was left in the Windows Registry.
    The James Bond: Quantum of Solace serial number is actually more of a product key than a serial number but the terms are often used interchangeably.
    Answer: The best way to find your James Bond: Quantum of Solace serial number may be with a product key finder program. Using a free product key finder program would certainly be the easiest way to find your unique James Bond: Quantum of Solace serial number. Product key finder programs automatically search your computer for the product keys and serial numbers that your software programs store in the registry.
    If you knew the exact registry key that stored your James Bond: Quantum of Solace serial number you could find it manually but that information is usually hard to come by.
    Most product key finder programs are designed to find serial numbers and product keys for operating systems like Windows XP or Windows Vista but some of them find serial numbers for several other programs too - programs like James Bond: Quantum of Solace.
    I've reviewed several product key finders but I haven't been able to personally confirm if any of them will find your James Bond: Quantum of Solace serial number. The best key finder programs are quick to download and completely free so feel free to try them all until you find one that will show your James Bond: Quantum of Solace serial.
    Here are two of the more popular programs that find serial numbers and product keys:
    If neither of the above programs find your James Bond: Quantum of Solace serial number, give some of the other key finder programs a try from my Free Product Keyfinder Programs list. Be sure to let me know what programs did or did not find your James Bond: Quantum of Solace serial so I can keep this page updated.
    Important: You may have come across James Bond: Quantum of Solace keygen programs or other kinds of James Bond: Quantum of Solace cracks but keep in mind that these are not legal ways of obtaining serial numbers or product keys. The only legal way of installing this program is by using a valid James Bond: Quantum of Solace serial number obtained through a legal purchase of the software.
    tk cr and all d best buddy.
    Jun 14, 2009 | Computers & Internet
    Changing numbers?
    To program the personal directory Its diferent to program the system directory. the personal has 8 number capaciti and the system has 999 number. To program the System directory
    1.- Enter to PBX program mode from your station 101
    2.- Choose program 001 to enter the quick dial numbers
    3.- Choose program 002 to enter (Or change ) the Labels
    Jul 05, 2008 | Panasonic KX-T7630 Corded Phone
    AT&T CL82209 Cordless Phone Logo
    13 people viewed this question
    Top AT&T Lands Phones Experts
    george  peters
    george peters
    Paul C.
    Level 1 Expert
    Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
