Question about Panasonic TH-46PZ800U Plasma TV
Green snow Picture has a green glow over it. It's not the tv signal as it's visible with DVD play. It sometimes goes away but usually comes back and stays.
    Top Expert:
  • Panasonic Master
  • 74,106 Answers
A greenish tone to entire display denotes a faulty panel. If you wish to get more details to this, check the site linked here. It has screen-shots to faulty plasma display. You can see it and compare to that of your TVs' and can make sure. Pull up older posts. Good Luck.
Posted on Nov 27, 2013
  • 8 Answers
SOURCE: TV screen turns off, green light stays on
As posted for a similar problem:
This is an issue with IC 803 on the Z board. This is a 3.3 V regulator that supplies this voltage to the slot card cage. Most input boards use this voltage EXCEPT the component board which is why it keeps playing along whike the DVI, HDMI, or composite signals will cut out after warm-up.
This is a surface mount multi-pin IC and is a bit tricky to replace.
The entire board is PN# TNPA3198xx with suffix determined by what model 7 series plasma you have.
This was a problem from around Nov. 2004 to Mar. 2005
T Wiz
Posted on Mar 25, 2008
  • 4234 Answers
SOURCE: green interference on Panasonic TH-PX75U
Since the set is only 8 months old, it should still be under warranty. This may only be an internal connection problem, but opening up the unit will void the warranty. I would suggest that you call for warranty service. This is a problem with the set and has nothing to do with external devices or interference.
Keep us posted.
Dan
Posted on Jul 10, 2008
  • 58 Answers
SOURCE: intermittent 3 inch green vertical line-5 inches from right side
it you have a repair skills you need to open the TV and make sure all the ribon connectors around the circuit boards are proper connected
and if all seems to be ok, the DG board will need to be replaced.
If you dont have any repair skills I would recommend you to take you TV to a repair shop since this is complex repair
Posted on Jun 16, 2009
toolkits
  • 1099 Answers
SOURCE: LG 32" Plasma TV power-on problem
Your power supply board is dead, u know basic electronics’ and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
hope this helps...
Posted on Jul 02, 2010
eagle338
  • 4889 Answers
SOURCE: hi, recently my flat screen tv screen turned a
The picture turns green if the component input cables are not connected in. Can you confirm that it is what you are using when you get the green picture? If yes can you please clarify the connection sequence of the RBG cables and the repective ports like Yb, Pb,Pr?
Posted on Apr 17, 2011
I have Soney TV KDL-46EX713. Green lines come on/off the screen. Sometimes screen goes entirely green with background picture still visible. Sometimes only green lines flicker like in picture below.
Looks like power supply board fault. If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Line faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD screen are similar, irrespective of its brand and screen size.
Apr 17, 2016 | Televison & Video
My DVD is playing my videos in black and white .. It's a Panasonic tv model is tc-L32c5
follow the steps. God bless you
Insert a DVD lens-cleaning disc into your player and press "Play" to clean the DVD laser, eliminating picture problems due to read errors. Do not use a CD cleaning disc as the brushes on these discs can damage your laser.
  • 2 Wipe your DVDs clean of all visible marks and dirt using a lint-free cleaning cloth moistened with rubbing alcohol or glass cleaner. This further fixes read errors which can damage the quality of picture and sound.
  • 3 Disconnect your DVD player from the TV or receiver you have it connected to. Reconnect the DVD player directly to the "AV" or "Video In" port of your television, firmly pushing the plug into place, to eliminate possible noise from the receiver and ensure a clean connection.
  • 4 Connect your DVD player using an S-Video, component video or HDMI cable. Standard yellow/red/white RCA connectors cannot carry the high-quality signal that DVD discs are capable of transmitting, and will display a particularly poor picture on flat-screen high definition televisions. Use an HDMI cable, if your television and player support it, or a red/blue/green component video cable.
  • 5 Press "Setup" on your DVD remote and enter "Picture Settings." Make sure your DVD player is set to display images in the correct screen format ("Widescreen" or "16 x 9" for HDTV sets, "Standard" or "4 x 3" for older square sets) and scan mode. If you are using a DVD player that supports "Progressive Scan" on an HDTV or flat-screen set, activate this setting; for older sets, choose "Interlace" if given a choice.
  • Nov 14, 2012 | Televison & Video
    Picture clarity
    Sounds heat circuit related, and if under warranty you should notify them before you have to pay for the tuner or sync board.
    Feb 03, 2008 | Westinghouse LTV-37WI 37 in. LCD...
    Green Glow
    Suggest that the CRT Purity has gone off
    Check that there is nothing magnetic near the set
    The CRT may need to be degaussed
    Or the degauss circuite is faulty this would require a engineer to look at
    Regards
    Roll56
    Jan 30, 2008 | iLO 2600 Television
    Green Picture
    The problem sounds like one I had. If so, the cause is as follows.
    The Daewoo ouputs synchronisation information on the green channel of the RGB outputs (which are pins in the SCART socket) The Panasonic TV automatically preferentially selects the RGB input in the SCART rather than the composite video signal in the SCART. The video circuits in the Panasonic should ignore the sync on the green channel but instead interpret the sync as green signal information which means the adjustment of the green channel is upset leading to a very green picture.
    Possible solutions:
    1. From the TV, manually select composite video input, not RGB. This may not be possible - I think the TV automatically goes for the RGB if it is present.
    2. Disconnect the wire to pin 16 in the SCART socket. This is the signal from the VCR/DVD to indicate that RGB is available. Disconnecting it means the TV defaults to the composite video. This is what I did.
    3. Connect the TV to the VCR/DVD using component or S-VHS leads only.
    Jan 13, 2008 | Daewoo DV-6T955B DVD Player/VCR
    Hitachi screen goes snowy and sound is totally distorted
    Sounds like bad solder connect in tv tuner....can usually be
    repaired or replaced.......................T.
    Nov 30, 2007 | Hitachi 43FDX01B TV
    Mitsubishi CS31305 TV turns on then goes to snow and then back on
    snow basically is a symptom of weak signal.
    as you say it becomes ok after 5 minutes or so there no question of any components gone wrong except loose or print intermittent
    please check.
    1  input weak like cable or antenna or loose wire from the source..
    2  in tv antennae socket loose.
    3  near tuner any thing loose or track loose.
    4  cable wire might be old.
    hope this will help.
    Oct 09, 2007 | Televison & Video
    Mitsubishi WS-65819 2002 rear projection
    1)possible bad RF modulator (the small box the A or B signal first goes thru) 2)Bad tuner (mounted on signal board) 3)or missing voltage to run tuner You could replace signal PCB,but that gets a little pricey.
    Oct 03, 2007 | Mitsubishi WS-65869 65" Rear Projection...
    Panasonic TH-46PZ800U Plasma TV Logo
    Top Panasonic Televison & Video Experts
     Grubhead
    Grubhead
    Jaime Hernandez
    Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
