Question about Craftsman 10" Inch Miter Saw Sears Model 113.235110 Compound 12 Black Stand Amp
How do I replace the spring in the lock off lever?
Replaced the power cord, but I need a diagram showing where the spring for the lock off lever belongs in the handle housing.
    Scholar:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 69 Answers
This is page 28 of the manualhttp://www.manualslib.com/manual/490926/Craftsman-113-235110.html?page=28#manual.
Posted on Jun 26, 2014
Z71. shift lever return spring broken
Sounds like it needs to be replaced.
May 13, 2016 | 2002 Chevrolet Avalanche
How to install throttle control spring on Honda GVARA lawnmower engine
There should be an empty hole in the throttle lever that one end of the spring goes into. The other end is attached to a stationary post directly in line with the throttle lever. Hook the spring in the throttle lever first and look for something to hook the other end on, probably in the direction away from the engine.
Aug 23, 2014 | Garden
Auger clutch lever disengages even though drive clutch lever is squeezed
On mine (Honda HS55) it turned out to be gummy old grease on the shaft and the lever that are supposed to lock the auger lever down. The spring couldn't overpower the sticky old grease. If nudged or given enough time, it would slowly turn and lock, but not instantaneously, as it should.
10 mm wrench to remove the nut (bottom left) and bolt (under handle) holding on the metal cover.
Once cover was off I could see the locking lever, spring, and the shaft that had the gummy grease on it.
The third photo shows the locking lever as it should be engaged. I had to push it to engage it, due to the spring not being strong enough for the gummy grease on the shaft.
There are flat sides on the shaft, behind the threads for the nut that has already been removed. Use a wrench on those to turn the shaft out. Disassemble. Clean. Oil. Reassemble. Works great now.
Another possibility is that your locking lever or spring are broken.
Dec 17, 2013 | Honda Snowblower Cover Silver Hs928,...
Explorer hatch release
There is a spring in the latch assembly that pulls the catch open when you press the button/lever. It may be broken which will need the unit to be replaced. Use something like a round blade of a screw driver and open the catch as you press the button/ lever.
May 11, 2013 | 2003 Ford Explorer
Turn Signal Lever is Loose
Just fit a new one the ball bearing spring loaded thingy ahd broke away
Dec 19, 2012 | 1994 GMC Jimmy
Problems with pull cord ,pull cord not engageing,pull cord is slipping freely.it acts like a bad spring on a briggs,but iam not familiar with this make.
Pull cords are all pretty similar so if you've seen one then etc.....
Does the cord retract?
If it's a broken spring then the pull cord would not retract.
If it is retracting then it's probably dirt, grass clipping interfering with the spring loaded locking lever.
Either way the only way to be sure is to remove the top cover and inspect it visually and clean it out and spray some lubrication on it.
You should be able to do this without taking apart the actual cord and retracting coil spring. It should come off as a unit.
Once you have inspected it if you you have any other questions please let me know.
Hope this helps.
Jun 16, 2010 | Tecumseh Lawn Boy Push Mowers Insight...
Kitchenaid stand mixer will not stay in the off position.
There is a spring, item #4, which hooks on to the bottom of the control plate, item # 25, and pulls it back when you move the lever to off. Remove the rear cover and see if that spring is still connected to the control plate and to the lever arm, Item # 3. Here is the diagram:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208212369.pdf
Mar 31, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
Need technical diagram of single hole faucet
Not sure where to find the diagram, but what type of faucet is it and where is it leaking? It it's a single lever, remove the hot/cold indicator to uncover an allen set screw. Loosen it and remove the lever, then the outer bushing nut. Now you'll have access to the interior parts around the cartridge (make sure you turn the water off to the supply lines before proceeding further). If it's the two handle type, remove the index buttons from the top of each handle to uncover a screw with either a slotted or phillips head. Remove the screws and remove the handles. You now have access to the valves and seats. If it's a 12-year-old faucet, the o-rings and seats will probably need to be replaced and this will fix your problem. If it's a single lever type, you'll need to replace the seats and springs and it will probably solve the problem.
Jun 14, 2009 | Grohe 40367000 Chrome Accessories Single...
Error 1200
Lexmark X4270 Error 1200 Fix - Click here for document link
1. Unplug printer from wall and remove power supply.
2. Unplug any phone lines or USB cords connected.
3. Remove printer attachments, paper trays and phone.
Figure 1 - Printer paper holder and completed print tray
4. Lift the front cover of the printer and remove the white rubber bar by pulling the blue lever on right towards you.
Figure 2 – Top view of printer showing the white rubber feed bar with purple attachment
5. Remove the screws underneath the front cover (6 screws), back of printer (2 screws), and bottom of printer (1). View the images below to find where to remove the screws.
Figure 3 - Top view of printer showing which screws to remove.
5. Cont…
Figure 5 - Bottom view of printer. Image on left is cover to screw. Gently remove ribbon cable to reveal the gold screw beneath
6. Flip the front cover open and gently lift the top of the printer cover. Keep front cover open.
7. Remove the ink cartridges out of their carriage.
Figure 6 - Displays ink cartridge carriage with ink cartridges removed.
Caution: Electrical hazard. Keep hand and metal pieces clear of board or any other electrical wires or parts.
NOTICE: The ink cartridges are all the way to one end. If the X4270 is plugged in, the cartridge carrier is stuck and doesn’t move. After further investigation a noticeable small black plastic lever is preventing the ink cartridges from moving. Photo below shows lever up and down (cartridges already moved in image below).
Figure 7 - Shows inside of X4270 and the lever that causes error #1200. Image on left displays lever up. Image on right displays lever down.
8. Push lever down clockwise so it is flush with plastic wall. Refer to image on right in Figure 6.
9. Lift the front cover open (if not already open) and plug in the X4270. Cartridges should move to center as if preparing for replacement.
10. Unplug the X4270 and remove power supply.
11. Remove bottom assembly carefully.
Figure 8 - Displays bottom assembly with lever and spring
Note: The cause of this problem is the spring slides out of place over time, probably because of ink shed on one end of its loop and loop attachment.
Figure 9 - Displays loop attachment
12. Place spring in loop attachment and use hot tip of heated tool to melt top of loop attachment to prevent further errors. Melt top of loop attachment similar of that to a mushroom top.
Figure 10 - Displays fix for jammed carriage.
13. Reattach the lever to the bottom assembly and slide back into place inside the X4270.
14. Plug in and check if operational.
15. Reassemble X4270 using steps 3-7.
Oct 03, 2006 | Lexmark X4270 All-In-One InkJet Printer
Craftsman 10" Inch Miter Saw Sears Model 113.235110 Compound 12 Black Stand Amp Logo
123 people viewed this question
Top Craftsman Saws Experts
Mike
Are you a Craftsman Saw Expert? Answer questions, earn points and help others
