You shouldn't need to bleed the air out-if you filled back up with fuel and its not starting you probably have a bad fuel pump-sorry- to bleed the fuel line look where the fuel line connects to the fuel injector rail-on the rail there should be a thing that looks like a tire inflator valve-turn the key on and push in the center of the valve and fuel should come out of it -if not then for sure pump isn't working- cheers Denny
SOURCE: 91 vw jetta diesel ran out of fuel
At the rear of the injection pump there are four lines, each goes to an injector. loosen the flare nut at just one injector. crank the engine over until you see fuel spitting out. Close the fuel line,vehicle should be running. If not then its something else check the fuel filter, fuel shut-off, and check for any fuel leaks.
SOURCE: HOW TO BLEED FUEL LINE ON LANDROVER
on most Discovery's the fuel rail will have a schrader type valve (usually on the right side of rail -US pass side). let the car sit a while before you do this and have some rags to collect any fuel that shoots out. (wear protective eyewear, and dont stand directly in line wiht this as it can shoot a distance). press the valve (like a tire valve) slowly, and fuel will squirt out until the pressure is equalized. in some cases, wiht weaker pressure regulators, you may not get much out at all. thx
