Question about Brother HL-2070N Laser Printer
HL-2035 ALL Leds light up solid
Hi! When the printer is turned ON, all Leds light up solid Cant remove them and obvioulsy cant print Anychance to fix this problem?
  • 1 more comment
  • macmil
    macmil Dec 13, 2013
    Thank you for the answer Disconnected Reconnected Nothing changed: all the lights are still ON The printer is "offline" for the PC
  • Bestway Dec 13, 2013
    Did you try going to START, DEVICES & PRINTERS, and check 1. your printer is default printer. If not make it. 2. go into Printer properties and try printing test page. 3. If still not ok, check if drivers are ok. And uncheck printer off line.
  • macmil
    macmil Dec 15, 2013
    Yep! I did check the status: the printer is default one but off-line - And I did check the driver too: after reinstall, it ask to connect the printer, but cant connect with it- the printer is turned ON, but doesn't take the next next: no initialization
    Master:
  • 966 Answers
Try resetting the printer. Disconnect power and reconnect after a minute. If not ok, make sure the drivers are uptodate.
Posted on Nov 27, 2013
Testimonial: "Thank you for the answer Disconnected Reconnected Nothing changed: all the lights are still ON The printer is "offline" for the PC"
How do I reset the consumables counter on myBrother HL-2035 printer printer
1.) Turn the printer off.
2.) Hold the 'go' button while turning the printer on. All panel lights should be on.
3.) Release the 'go' button once all lights are off.
4. )Press the 'go' button 2 times.
5.) Pause.
6.) Press the 'go' button 5 times.
7.) The toner light should be off.
8.) The paper light should be on.
9.) Close cover. The ready light should be the only light on.
Once all steps are successfully completed your "low toner" light should be fixed.
Jun 16, 2013 | Brother Hl-2035 Drum
How can i reset my HL brotherW printer ?
If you ned to get a default network config use:If you want to reset the print server back to its default settings (resetting all information such as the password and IP address information), follow these steps:Using the Go button 4a) Turn off the printer.b) Make sure that the front cover is closed and the power cord is plugged in.c) Hold down the Go button as you turn on the power switch. Keep the Go button pressed down until the Toner, Drum and Error LEDs light up. Release the Go button. Make sure that the Toner, Drum and Paper LEDs are off.d) Press the Go button seven times. Make sure that all the LEDs light up to indicate the print server has been reset to its default settings.
Jan 12, 2012 | Brother HL-2170W Laser Printer
When trying to register my brother hl2035 printer i get error code 406
hi,
pls try with the below site
PRINTER, EPSON - STYLUS BX300F - EPSON, EPSON - STYLUS SX215 - EPSON
Error communicating with the server. Show Details Show Details ... View My Account View My Account; My Orders My Orders; My Profile; My Address Book. About Us ... To login or register securely click here ..... BROTHER Part No HL-2035. Order Code CS16669, PRINTER, MONO LASER HL-2035, BROTHER - HL-2035 - BROTHER ...
cpc.farnell.com/1/1/index410.html - United Kingdom - Cached
May 30, 2011 | Brother Office Equipment & Supplies
Why does the drum light blink on my brother hl-2140
The blinking indicates that the drum unit is near the end of it's life. It will shut down soon and you will lose the ability to print until it is changed or reset.
To reset the drum counter. Press and hold down the white button (shown as blue in the image below) for about 4 seconds until all the LEDs light up. Once all 4 LEDs are lit, release the button.
Nov 18, 2009 | Brother HL 2140 Laser Printer
All the Lights are flashing on my HL 5250DN
If printer is blinking all the LEDs then try to turn off the power switch, wait a few seconds, and then turn it back on and try to print again. If all the LEDs are still blinking, press Go and Job Cancel buttons together and let me know what LEDs stay on.
Jun 23, 2009 | Brother HL 5250DN Laser Printer
All lights on solid, not flashing, wont print
Recommendation: See HL-5240/HL-5250DN USER'S GUIDE: Section (4), Control Panel: LEDs, (light emitting diodes) starting on pg. 44.
Apr 14, 2009 | Brother HL 5250DN Laser Printer
Brother HL 5250 red light flashing
I found this solution on the web-- Hope it helps.
The HL-2070N gets stuck in a toner end-of-life error condition. Perform the following to clear :
With paper loaded, new toner in,
Open front door
Turn off printer
While holding down the GO button, turn printer back on
When all four LEDs light up release GO button. All LEDs will turn off
Press the GO button 2 times. The 3 LEDs (toner, drum, paper) will light up solid
Press the GO button 5 times
Paper light will be blinking
At this point the toner end-of-life condition has been reset. Close front door.
BTW, I got this from Brother Support. Also, just a reminder, timing is important here so don't pause between button presses.
Jan 28, 2009 | Brother HL-2070N Laser Printer
Toner light doesnt go away in our printer and the printer doesnt print. We changed the cartridge please help us
The HL-2070N gets jammed in a toner end-of-life error condition. Perform the following to clear (I have 120 in the field so I know it works!):
  1. Open front door
  2. Turn off printer
  3. While holding down the GO button, turn printer back on
  4. When all four LEDs light up release GO button. All LEDs will turn off
  5. Press the GO button 2 times. The 3 LEDs (toner, drum, paper) will light up solid
  6. Press the GO button 5 times
  7. Paper light will be blinking
  8. At this point the toner end-of-life condition has been reset. Close front door.
Mar 11, 2008 | Brother HL-2070N Laser Printer
BROTHER HL-2040
I think the previous post applies to resetting the drum light after replacing the drum.
You need to reset the toner end-of-life condition.
  1. Open the Front cover
  2. Press and hold the GO button
  3. Power ON the printer while continuing to hold the GO button
  4. All 4 LED's will light up and then 3. Once the 3 LED's are lit, release the GO button
  5. Press the GO button 2 times. This will cause the
    LED's to light solid
  6. With the LED's lit solid, press the GO button 5 times
  7. At this point the Paper light should be blinking. Toner end-of-life has been reset
  8. Close the front cover.
Dec 10, 2007 | Brother HL-2070N Laser Printer
Brother HL-2040 All LEDs stay lit and the printer no longer works
Turn it on and when all the LEDs light up, THEN press the Go button. One or more LEDs will stay lit and the others will be off. Look in the user manual (you can find it online at the Brothers site if you don't have one). There is a chart in the Troubleshooting section that will tell you what problem your particluar combination of "lit" buttons indicates. It may suggest fixes, or depending on the problem, tell you to see a repair person.
Nov 19, 2007 | Brother HL-2040 Laser Printer
Brother HL-2070N Laser Printer Logo
71 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
